Glenn A Samba Member
Posted: Tue Jul 20, 2010 9:17 am Post subject: Doing the tranny mount shuffle |
I had be searching here for different ways to change a front tranny mount in my bus. I didn't want to take alot of stuff apart because I'm kind of lazy. Here's what I came up with. and it worked pretty well.
I removed the bumper and apron. The shiftrod coupler and clutch cable. the two large cradle bolts and the front tranny mount bolts. Of course there is a jack under the engine and the bus is on ramps. I took a bottle jack and a piece of wood that fit between the back of the rear tires. As I pumped the bottle jack spreading the rear tires apart the motor and tranny moved back. I was able to pull the tranny mount out with ease. After installing the new mount I let the preasure off the bottle jack slowly while checking the alignment of the tranny mount. Some prying with screwdrives and crowbars was needed towards the end. For the most part it was pretty simple. My daughter helped me hold the clutch peddle up while I reattached the cable in the rear.
The jack and 2X4 are on the rear portion of the rim.
I used clamps to hold the 2X4 up to the heaterboxes and also to the block ontop of the jack.
I don't own a portapower, But I'm sure one of those could be used as well.
The jack rolled back and forth as the motor moved backwards and back into place.
mannys66 wrote: |
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it. |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Tue Jul 20, 2010 11:29 am Post subject: |
good job! Did it solve all your troubles? You still need to rebush the nosecone? _________________ 1957 Beetle
1966 Bus |
Posted: Tue Jul 20, 2010 3:00 pm Post subject: |
GLHTurbo wrote: |
good job! Did it solve all your troubles? You still need to rebush the nosecone? |
Yea shifts perfect now. I wish I had a nosecone seal and shiftrod seal. There's allways next time. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Tue Jul 20, 2010 3:09 pm Post subject: |
Glenn A wrote: |
GLHTurbo wrote: |
Yea shifts perfect now. I wish I had a nosecone seal and shiftrod seal. There's allways next time. |
glad it all worked out GA. Last thing you need is another car problem to deal with. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jul 20, 2010 7:16 pm Post subject: |
Glenn wrote: |
Glenn A wrote: |
GLHTurbo wrote: |
glad it all worked out GA. Last thing you need is another car problem to deal with. |
I'm going to need to daily the bus while the TDI is in the bodyshop _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Brokenbus Samba Member
Posted: Wed Sep 22, 2010 2:36 pm Post subject: nose cone mount |
Just what i need to do! But can I ask how does spreading the tires apart move the trannny aft? I assume from your pic that the rear tires stay on the ramp at all times? Can or should this be done with the tires off the ground? Many thanks for posting this as I need to replace this mount but dread pulling the tranny. Any other info appreciated.
Peace, Ken |
Posted: Wed Sep 22, 2010 3:33 pm Post subject: |
After I got everything unbolted I pryed at the tranny mount with a prybar just to see if I got everything apart and how much it would move. I noticed the back of the wheels moving outward . I thought if I just gave them a little help by spreading them apart the mount would fall right out.
The reason the trans moves backwards is the axles are firmly bolted to the drums. Yes the bus remained on the ramps. The motor was resting on the floor jack.
The only added advise I could give is make sure that nothing binds while jacking the wheels. I made sure multiple times that the jack was rolling backwards freely and I also helped move the motor&tranny back with a prybar and pulling it by hand. If you leave something bolted or the trans binds You could probably bend a rim or break something.
I need to do this job again as I broke the new mount already . Maybe I'll video it next time. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Wed Sep 22, 2010 5:42 pm Post subject: trans mount |
Really??? How did the mount break? Just curious...........
Ken |
Posted: Wed Sep 22, 2010 5:52 pm Post subject: Re: trans mount |
Brokenbus wrote: |
Ken |
This is an example of my driving.
Any questions? _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Wed Sep 22, 2010 6:07 pm Post subject: Re: nose cone mount |
Brokenbus wrote: |
Can or should this be done with the tires off the ground? |
I did not see this part of your question. The answer is NO. If the spring plates have no presure on them (the weight of the bus) they rest on the bottom stops of the torsion housing. If the spring plates pop off the stops and are allowed drop down past the stops it could be a problem.
Again I would not use this method with the bus on stands. Only ramps. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Thu Sep 23, 2010 7:25 am Post subject: trans mount |
Glenn A, thanks for the clarification on the wheels. BTW nice baja bussing, post some more pics.... |
der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
Posted: Thu Sep 23, 2010 8:12 am Post subject: Re: trans mount |
Glenn A wrote: |
Brokenbus wrote: |
Ken |
Any questions? |
_________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Strictly Vintage 2s |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Sep 23, 2010 8:34 am Post subject: |
Good job.
You removed the rear bumper? Damn, you wasted like 30 minutes right there. |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Thu Sep 23, 2010 8:50 am Post subject: |
One of those steel posts with a screw top as used in a basement for holding up floor beams works perfect for this as well. And two scraps of wood on each rim. |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
Posted: Thu Sep 23, 2010 10:21 am Post subject: Re: Doing the tranny mount shuffle |
Glenn A wrote: |
I had be searching here for different ways to change a front tranny mount in my bus. I didn't want to take alot of stuff apart because I'm kind of lazy. |
Don't be shy, The best ideas you find will come from a lazy 'engineer'. _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Posted: Thu Sep 23, 2010 7:10 pm Post subject: |
campingbox wrote: |
Good job.
No luck. The tail pipe hits the bumper and rather than mess with the exhaust I took the bumper off. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Thu Sep 23, 2010 7:13 pm Post subject: |
mattcuddy wrote: |
Yea I like it. Milk crates and cinder blocks instead of ramps too! Philly style. _________________
mannys66 wrote: |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Glenn Mr. 010
Posted: Thu Sep 23, 2010 7:19 pm Post subject: |
GA, by now, the engine should know how to remove itself. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Dec 03, 2010 2:21 pm Post subject: nose cone mount |
Well I finally got around to doing this job. I had a very difficult time using the wood and sideways bottle jack method. I had to buy a Porta Power. It worked fantastic and did the job in minutes. $89 at local Harbour Frieght. Will probably never use it again but its a cool tool. Highly recommend. If your in the Dallas / Ft Worth area drop me a line you can use mine for free.
Ken |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Fri Dec 03, 2010 8:31 pm Post subject: |
I've done 2 so far, mine and Surfcity's. Used the scissor jack from the wife's toyota with wood blocking. Surfcity couldn't find his replacement so we through bolted it. There is an earlier post that shows how to do this. |
