attaching "Volkswagen" script to rear hatch
dirigible
dirigible is offline
PostPosted: Tue Jul 20, 2010 11:24 am    Post subject: attaching "Volkswagen" script to rear hatch Reply with quote
I've got the original "Volkswagen" script that attaches to the rear hatch, and the hatch has the holes in it that the script fastens into. However, the script is missing the little dowels on the backside that slide into the holes.
Do you know any good ways to attach the script? Ideally, I'd like a solution that wouldn't leave a mess if I had to take it off again.
'71 Campmobile.
robjarman
robjarman is offline
PostPosted: Tue Jul 20, 2010 11:26 am    Post subject: Reply with quote
glazing mastic bead (the type used for oiled wooden window frames) - works a treat holding the VW insignia on to the front panel of my 72 crossover!
Rob
VDubTech
VDubTech is offline
PostPosted: Tue Jul 20, 2010 1:20 pm    Post subject: Reply with quote
Why wouldn't you just get a new or used emblem that has the correct mounting posts?
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
Mr.Mexi
Mr.Mexi is offline
PostPosted: Tue Jul 20, 2010 1:52 pm    Post subject: Reply with quote
yeah^ however I neatly used super glue on the script of an old beater that worked well.when I took it off 5 years later the paint was fine.
my resto thread: http://forum.earlybay.com/viewtopic.php?f=2&t=15384
dasdachshund
dasdachshund is offline
PostPosted: Tue Jul 20, 2010 2:35 pm    Post subject: Reply with quote
Maybe he picked up a used one off Samba classifieds here that had the posts missing, like I did, for a little less money....... Rolling Eyes
I am going to use the two sided tape that they sell at auto parts stores to put on things like front spoilers, cutting it to exact shape with a sharp x-acto. This should seal the holes, also. I like the super glue idea, too.
Hope I helped.
-dasdachshund
dirigible
PostPosted: Tue Jul 20, 2010 5:51 pm    Post subject: Reply with quote
When I bought the bus, it was buried in the included milk crate full of spare parts--just getting around to putting it on 10 years later. I thought I remembered it having one or two pins still on it, but apparently I was mistaken.
Thanks for your suggestions!
'71 Campmobile.
tom62
tom62 is offline
PostPosted: Tue Jul 20, 2010 5:58 pm    Post subject: Reply with quote
clear silicone will work It's held mine on for a year now!
dasdachshund
PostPosted: Thu Jul 22, 2010 9:00 am    Post subject: Reply with quote
Here we go…. Very Happy
Here’s the emblem I got here off the Samba classifieds. Very nice except…….
The pins are broken off. Crying or Very sad
Hummmmmm, lets try SUPER TAPE Think
Ready…
Set…(the ¾ inch wide fit perfect)
Go, with a sharp x-acto knife…
Pretty much finished, except for the K…
Off to the victim, Fred, my 1970 Riviera. PO says Plumbers Putty will plug those pesky ‘ol emblem holes…Shocked
Cleaned up…
Yep, she’ll fit…
VOILA!!!!!!!!! Another one saved. Dancing Dancing Dancing
Bookwus
Bookwus is offline
PostPosted: Thu Jul 22, 2010 9:14 am    Post subject: Reply with quote
Hiya Das,
Excellent job!
It's great to see folks taking what others consider to be trash and making it "live" again. Nice work.
Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com
aeromech
aeromech is offline
PostPosted: Thu Jul 22, 2010 11:29 am    Post subject: Reply with quote
clear rtv
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
sofakingcool
sofakingcool is offline
PostPosted: Thu Jul 22, 2010 11:44 am    Post subject: Reply with quote
How did you make your bus change colors?! Very Happy
dasdachshund
PostPosted: Thu Jul 22, 2010 12:40 pm    Post subject: Reply with quote
That is kinda cool, isn't it? Cool
I had one of those big blue cheep Harbor Frieght tarps over it when I took the first pic's. It was flapping and generally being a bad boy so I 86'd it half way through.
EDIT- Bookwus, thanks. Appreciate it.
-dasdachshund
SGKent Premium Member
SGKent is offline
PostPosted: Thu Jul 22, 2010 12:46 pm    Post subject: Reply with quote
silver solder new posts on.
machine work recommendations: http://kentcomputer.com/77VW/machinework.pdf
Pointers on rebuilding an engine:
http://kentcomputer.com/77VW/rebuilding_a_vw_engine.pdf
Setting Engine Timing: http://kentcomputer.com/77VW/Timing.pdf
djdh68dlux
djdh68dlux is offline
PostPosted: Fri Jul 23, 2010 2:22 pm    Post subject: Reply with quote
I think I paid less than $30 for a new one and the clips a couple years ago and it was on in less than 5 minutes. Just sayin... Razz
1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org
ned
ned is offline
PostPosted: Sun Jul 25, 2010 6:05 pm    Post subject: Reply with quote
Weld it.
panic_fan
panic_fan is offline
PostPosted: Mon Jul 26, 2010 12:17 pm    Post subject: Reply with quote
I was missing only one.....but I used a pencil eraser.
Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
Teal Bay Bus
dirigible
PostPosted: Mon Jul 26, 2010 1:56 pm    Post subject: Reply with quote
Yep, they're going for around $30--WAY too much for a little piece of aluminum, I think.
Anyway, I soldered the pins in and then used silicon caulking. Worked great!
'71 Campmobile.
alikatcraig
alikatcraig is offline
PostPosted: Mon Jul 26, 2010 11:13 pm    Post subject: Reply with quote
I did make one in stainless to see how it would look - and it was great. I brazed in small studs so it can be attached to the rear hatch with nuts in the stock location. I did think about making a small run and using a stud gun (stud-sert) in a fixture to attach the stainless studs.
Al
1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug
Lettuce
Lettuce is offline
PostPosted: Tue Jul 27, 2010 12:10 am    Post subject: Reply with quote
if you use the clear 3M Scotch Clear Mounting Tape #4010, it will definitely be attached. Make sure everything is clean and it wont come off until you want it to.
quartermilecamel
quartermilecamel is offline
PostPosted: Sat Nov 12, 2011 2:46 pm    Post subject: Reply with quote
Is it really possable to silver solder aluminum? Got a video of that so us solderally inept people can try that?
Waiting for santa to drop off funky green. I can wish can't I????
