Plastic Sleeves on Engine Case Bolts
Morris_82
Morris_82 is offline
PostPosted: Wed Jul 21, 2010 1:30 pm    Post subject: Plastic Sleeves on Engine Case Bolts Reply with quote
The Search is not strong with me. I've tried all day and found nothing. So here goes:
When taking my 2.0L AC engine apart for rebuild, I found all the plastic sleeves on the thru-case bolts (6 of them, I think) broken or in otherwise terrible condition. Now I'm almost ready to build the engine and was wondering: where I can get some replacements?
FYI, searches of BusDepot and Van-Cafe have proven fruitless.
Any info is much appreciated! Thanks!
Volksaholic
Volksaholic is offline
PostPosted: Wed Jul 21, 2010 1:41 pm    Post subject: Reply with quote
I may have some left over from my aircooled days. Of course mine would be from the early (1.7/1.8 liter type IV engine). I'll try to remember to check when I get home. I'm thinking these are the white (or whitish) things shaped like a football with a cross-section like a starfish... working from memory here... is that what you're talking about?
pd
1988 Wolfsburg Edition, 2001 Subaru EJ251
edgood1
edgood1 is offline
PostPosted: Wed Jul 21, 2010 1:43 pm    Post subject: Reply with quote
are you talking about those little star like plastic pieces?
I remember when rebuilding up a 2.0L for my '74 WAAAY back in the day the gasket kit came with new ones. That engine has since been retired.
I'm not sure if newer/aftermarket gasket kits include them nowadays.
1987 Syncro Westfalia powered by Subaru
Volksaholic
PostPosted: Wed Jul 21, 2010 1:52 pm    Post subject: Reply with quote
That's true... they used to come in the gasket kit. If you're tearing it down you're going to need most of the gaskets anyway... have you bought a kit? Maybe that's the reason you're not seeing them priced separately.
pd
Wildthings
Wildthings is offline
PostPosted: Wed Jul 21, 2010 3:23 pm    Post subject: Reply with quote
The Victor Reinz gaskets sets still have them.
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Jul 21, 2010 4:04 pm    Post subject: Reply with quote
Known as "case insulators".
And yes they do come in the Victor gasket kit.
CessnaJon
CessnaJon is offline
PostPosted: Wed Jul 21, 2010 6:01 pm    Post subject: Reply with quote
I left them out when rebuilding my 2.0 type 4.Don't know what they are for.I've gone 30,000 trouble free miles without them.let me know if u want them.
1973 Westy (shared birthday)
1990 Westy Multivan
1998 Diamond DA20
2015 Sportwagon TDI
Wildthings
PostPosted: Wed Jul 21, 2010 9:16 pm    Post subject: Reply with quote
Don't really know what they do. Maybe they are only there to keep the bolts from vibrating against the case, but they could also be there to prevent the vibrations from damaging the bolts themselves.
If you don't have them you can get a fat o-ring and stuff it in the hole around the bolt and backfill it with high temperature silicone.
Morris_82
PostPosted: Thu Jul 22, 2010 6:21 am    Post subject: Reply with quote
and now i have been educated.
i have the victor reinz gasket set; i'll rifle through it when i get home (and the garage temperature allows for human habitation).
thanks sambanistos!
Volksaholic
PostPosted: Thu Jul 22, 2010 7:34 am    Post subject: Reply with quote
My general rule of thumb: If you don't know why the engineers put them in, you best leave them in! Smile
I used them on my Type IV rebuilds. Checked the old gasket stash... I've only got 4 (I don't know how I ended up with 4... whatever).
pd
MarkWard
MarkWard is offline
PostPosted: Thu Jul 22, 2010 7:40 am    Post subject: Reply with quote
I always thought they were to hold the case bolts in place while you assembled the case halves. The type 1 engine had case studs rather than through bolts. You build the case with the one half on it's side. Without the holders, the bolts would be difficult to hold in place gravity and all. If you can get them still use them.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
Morris_82
PostPosted: Thu Jul 29, 2010 6:06 am    Post subject: Reply with quote
And the award goes to rsxsr. I posed the question to the guys at Aircooled Technology (I'm building a Camper Special) who said the insulators were used at the factory to ease engine assembly. They don't use them in their performance engines.
Thanks guys. One less thing to buy for my van. Very Happy
