mpate Samba Member
Joined: October 16, 2004 Posts: 672 Location: Miami, Florida
Posted: Sun Jul 25, 2010 6:53 pm Post subject: Will Kadrons Clear the Stock Decklid |
Does anyone know if the Kadron setup with the stock filters will clear the decklid arms and brackets? I have not installed them yet. Thanks! _________________ Matthew Pate
87 VW Puma GTC |
theadmiral1000 Samba Member
Joined: September 27, 2007 Posts: 251 Location: Bothell, WA (near Seattle)
Posted: Sun Jul 25, 2010 11:26 pm Post subject: |
Need shorter air cleaners to clear the decklid springs. _________________ Zach S.
71 Ghia
75 R75/6 |
mpate Samba Member
Posted: Mon Jul 26, 2010 6:15 am Post subject: |
Will the cone filters clear the springs? Any idea who makes these low profile filters? _________________ Matthew Pate
87 VW Puma GTC |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Mon Jul 26, 2010 6:21 am Post subject: |
mpate wrote: |
Will the cone filters clear the springs? Any idea who makes these low profile filters? |
The cone filters just cleared the springs on a '72 'vert
we restored. We had about 5mm to spare, no more than that.
You should also note the intakes can be supplied in various lengths.
If you have the long or tall version, clearance will be more of a challenge. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
iradi Samba Member
Joined: August 24, 2007 Posts: 211 Location: Miami, Fla
Posted: Mon Jul 26, 2010 11:02 am Post subject: |
This is my engine, KG 74 with dual kadrons. I ordered the hole set to AJ Sims.
Plenty of room, works real nice. _________________ Ivan
74 Guia Coupe Daily Driver |
ripreston Samba Member
Joined: May 16, 2006 Posts: 147 Location: U.K. to L.A.
Posted: Tue Jul 27, 2010 1:21 am Post subject: |
I solved the clearance issue by using turbo air filters.
Cobey Samba Member
Joined: March 31, 2004 Posts: 2022 Location: Lost in NorCal Space
Posted: Tue Jul 27, 2010 8:52 am Post subject: |
Another option is to remove the springs and either use a prop or a strut to hold the engine lid open for you. _________________ (0)(=|=)(0) 68 Ghia Vert - Gina
N.A.G
Home Solar Power |
