hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Jul 28, 2010 6:48 pm Post subject: Unusual 383 distributor |
i have an unusual 383 distributor. number on tag is VE 4 BRS 383.
the points contact plate has some kind of built in resistor or condenser? there is no wire going to it. the holder for it is secured to the points plate and riveted shut. there is also a dedicated "dimple" in the points plate, so it's not something that somebody just stuck on there randomly. i think the 6J may be the date code?
the housing is not date stamped, but has the numbers 8, 9, 10, 11 stamped in it.
everything else internally seems to be the same as my other 383 distributors. i have not checked the advance properties of this distributor.
anyone seen anything like this?
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76908 Location: Sneaking up behind you
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Jul 28, 2010 8:50 pm Post subject: |
I have not seen one of these Jon but I have read about them.
According to my copy of Progressive Refinements page E8:
" 26 September 1953 until 17 October 1953 engine # 647 490 to 654 500"
"Now XF condenser inside distributor housing formerly counted outside."
I have seen that notation before and always wondered about it. Nice find _________________ Roads Scholar &
Posted: Wed Jul 28, 2010 8:56 pm Post subject: |
The 6J date stamp does make some sense. J is indeed 1953 but 6 is June a few months before PR listing. That's a pretty narrow production window something like 23 days... _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Wed Jul 28, 2010 9:10 pm Post subject: |
After closer inspection I see that the date stamp is on the condenser. That makes the whole thing very believable. _________________ Roads Scholar &
Posted: Thu Jul 29, 2010 6:27 am Post subject: |
interesting info. so does that mean there should be a wire attached to the end of the condenser, and if so, where would it connect to? it almost looks like there could have been a tab on the end at one point that got broken off, but it's hard to tell. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Glenn Mr. 010
Posted: Thu Jul 29, 2010 7:01 am Post subject: |
If it's an internal condenser the wire needs to connect to the points "pass through" bolt.
Is there a hole in the body for mounting an external condenser? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jul 29, 2010 7:08 am Post subject: |
Glenn wrote: |
Is there a hole in the body for mounting an external condenser? |
yes. there is a threaded hole for the mounting screw, and there is a recess on the underside of the housing for a condenser to fit, just like on a "regular" 383, 019, or BR8, just like in this pic (not the same distributor).
hazetguy: invested?
Posted: Thu Jul 29, 2010 12:02 pm Post subject: |
Bosch probably was not ready to change the shape of their distributor housing before finding out if their "experiment" worked or not. Thus the pocket for an external condenser remains.
The only real design change that I see is to the points plate everything else is common to all 383's.
Interesting that they went back to an internal condenser during the cast iron 40 hp run from 1961-1964. _________________ Roads Scholar &
uberwagen Samba Member
Posted: Sat Jul 31, 2010 7:47 pm Post subject: |
There is one in the october 53 canadian standard sunroof I recovered last year. I was just looking at it today searching for a date stamp. |
Posted: Mon Aug 02, 2010 12:16 pm Post subject: |
correction, the one on my 53 is a VE4 CR 407, bu also has the internal condensor. |
Glenn Mr. 010
Posted: Tue Jun 16, 2020 6:06 am Post subject: Re: Unusual 383 distributor |
Here's another with a 10J date code.
Member #1009
#BlueSquare |
