Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Wed Jan 25, 2012 10:46 am Post subject: |
agggilli wrote: |
Airkewld wrote: |
Its been a while since we updated this.
Hooked up a New Fuel Management System in the 58
I really like this Pete, this looks like something that would work nice in my 66. Are these like corpses, one to a box, or can you hook me up with one similar that fits in the 66 cubby hole?
Gregg |
That plumbing does look nice, but you do realize that pressure regualtor is about the shittiest one available right? |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3150 Location: Goodyear, AZ USA
Posted: Thu Feb 23, 2012 6:51 pm Post subject: |
Attention Type 3 Owners (Fastback, Squareback, Notchback and Razor Ghia): Bolt on 4" Ultimate Beams in both torsion adjustable and Air Ride applications are coming soon. With an Industry-First built-in Caster adjustments, setting up your type 3 has never been easier. No cutting, no body mods, no sacrifices in ride quality or handling characteristics. Pre-73 factory disc application models can retain their factory disc brakes, factory drum applications can now run 2 & 4 piston Wilwood BAD Series brakes in any bolt pattern with stock height or with forged drop spindles. Please share with all your VW friends. Thanks and enjoy your evening! Sneak Preview can been seen March 24th at our Grand Opening. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Mon Mar 12, 2012 9:30 am Post subject: |
Hello Pete,, installing a pair of your air shocks on a friends 64 bug.. I know i need about 170 190psi to lift the frontend but the air tank max reads 150psi?? Can i push it to 200? Thanks! |
Posted: Mon Mar 12, 2012 10:21 am Post subject: |
Easy Duz It wrote: |
Yes with no problem. See below for the explanation.
Edit - People sure read into this way to much. Do I recommend running 200psi, NO. Can it go that high yes and I have done it in my car for 9 years. If you want to lessen the psi, try some shock relocaters here http://airkewld.co/nqWm80 and it will lessen the pressure by 30psi.
If your pump is purchased through us and it fails, I will replace it. If your tank is purchased through us and fails, I will replace it. If you purchase from me, I will treat you like a customer for life.
Please understand that there are rules in place, do not abuse them. There are reasons why they have these warnings, ask us before doing so and we will guide you in the right direction. _________________ TheSamba members-only discount - Samba24
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Mon Mar 12, 2012 11:40 am Post subject: |
bad advice, from a legal standpoint, Pete.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Mon Mar 12, 2012 11:54 am Post subject: |
Thanks for all your help! My buddy was very pleased with your new hangers and through rods! Looking forward to your open house! |
Jaysix Samba Member
Joined: April 18, 2010 Posts: 74 Location: Portage, Pennsylvania
Posted: Mon Mar 12, 2012 4:48 pm Post subject: |
bugninva wrote: |
bad advice, from a legal standpoint, Pete.... |
Agreed |
Posted: Mon Mar 12, 2012 5:01 pm Post subject: |
I did edit my original post with some clarification.
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Mon Mar 12, 2012 5:43 pm Post subject: |
Ive noticed that Airkewld stands behind thier product and has the guts to put it all out there for sambians to critique on a daily basis. Hats off to Airkewld. |
Posted: Mon Mar 12, 2012 7:24 pm Post subject: |
vaughn bros. wrote: |
my hat is off to Pete, also... Don't get me wrong, that I why I commented.... I, myself, run my airtank a bit higher than it is "rated" for...most pressure vessels are tested to 1.5x what they label as "safe"... that said, it is not smart for any business(or individual) to advise someone that it's okay to exceed limits that a manufacturer puts on a part. If one has never seen an air tank rupture, it can be violent, and can cause major damage.... I'd hate for a well intentioned reply to put someone straight into position of liability if something went wrong.... _________________
xilly Samba Member
Posted: Fri Mar 30, 2012 4:03 pm Post subject: |
Hello,
I just have my Air suspension installed in the front of my Karmann 64
My mecanic switch the gauge from 150 max to 200 max
But can I drive the car with only 120 PSI? or even lower?
Tx
William |
71weekender Samba Member
Joined: August 07, 2005 Posts: 187 Location: olympia wa
Posted: Thu Jun 07, 2012 1:35 am Post subject: |
Airkewld wrote: |
Project Frido-laid on its way to the Classic. |
looking good cuz. :lol: |
6d6vdub Samba Member
Joined: August 08, 2003 Posts: 449 Location: Jacksonville, nc
Posted: Wed Jun 19, 2013 2:48 pm Post subject: |
ready to see this one!
Airkewld wrote: |
Attention Type 3 Owners (Fastback, Squareback, Notchback and Razor Ghia): Bolt on 4" Ultimate Beams in both torsion adjustable and Air Ride applications are coming soon. With an Industry-First built-in Caster adjustments, setting up your type 3 has never been easier. No cutting, no body mods, no sacrifices in ride quality or handling characteristics. Pre-73 factory disc application models can retain their factory disc brakes, factory drum applications can now run 2 & 4 piston Wilwood BAD Series brakes in any bolt pattern with stock height or with forged drop spindles. Please share with all your VW friends. Thanks and enjoy your evening! Sneak Preview can been seen March 24th at our Grand Opening. |
_________________ "64 Sunroof Notch project-The beginning |
