DirtGhost Samba Member
Joined: September 19, 2007 Posts: 547 Location: Greensboro,NC
Posted: Wed Sep 06, 2017 12:32 pm Post subject: Re: Len's spoiler buggy |
This buggy build is one of the better ones I have seen in a long time. The attention top detail in the pan bottoms are just fantastic. The attention to detail on the dash I was like wow. All kinds of Idea floating around now. _________________ Orange Boxx Design and Fabrication |
Hot Air Samba Member
Joined: February 25, 2007 Posts: 664 Location: Baltimore, Maryland
Posted: Sun Sep 10, 2017 3:47 pm Post subject: Re: Len's spoiler buggy |
Wheels are on. Ready for the motor and body..just need to send the body off for paint.
_________________ 73' Bug
85' Porsche 911 Carrera 3.2 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sun Sep 10, 2017 4:44 pm Post subject: Re: Len's spoiler buggy |
That's lookin' super nice!!
What are ya gonna do to keep the parking brake cable away from the chrome shock? _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Mon Sep 11, 2017 9:23 am Post subject: Re: Len's spoiler buggy |
I think I will put a piece of hose over the line to help protect it. Not much I can do there, Suggestions are welcomed. _________________ 73' Bug
joescoolcustoms Samba Member
Posted: Mon Sep 11, 2017 9:38 am Post subject: Re: Len's spoiler buggy |
Hot Air wrote: |
I think I will put a piece of hose over the line to help protect it. Not much I can do there, Suggestions are welcomed. |
You are already sealed up, but I swap calipers side-to-side, clock the bracket at 12'O clock and run the e brake cable up from the bottom.
_________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Sep 11, 2017 12:20 pm Post subject: Re: Len's spoiler buggy |
damn you Joe, I guess I will have to take it back apart, Looks like that may work. I will have to re-bend the brake lines.
Thanks for the info
len _________________ 73' Bug
Posted: Mon Sep 11, 2017 12:38 pm Post subject: Re: Len's spoiler buggy |
Look closely at it before puling apart. I use the bent brackets for the calipers. Yours are the cast brackets, and the webbing may not fit over the spring plate if it is positioned at 12 o'clock. The bent brackets do not have side webbing.
If it does work, I use the bottom shock bolt to install one of the rubber covered SS loops to run the cable through keeping it up from catching anything low lying and to keep it from flopping around. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Sep 17, 2017 5:12 pm Post subject: Re: Len's spoiler buggy |
Good day today. I bleed the brakes with DOT5 fluid all went well. I had a few fittings that needed to be a little more tight ..bleed and bleed and then re bleed to make sure. Nice and hard pedal. Next will be to shorten the cables and install the motor this week. _________________ 73' Bug
Posted: Mon Sep 18, 2017 4:33 am Post subject: Re: Len's spoiler buggy |
Well not so good..i checked it this morning and the one back fitting is wet...😭 i guess I'll take it apart tonight..
Does anyone know where to get flexible brake lines made with a banjo fitting on one end.. I may hay to redo the rear lines and eliminate some of those fittings. _________________ 73' Bug
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Bluggy Samba Member
Joined: September 12, 2017 Posts: 151 Location: Caribbean
Posted: Mon Sep 18, 2017 6:41 am Post subject: Re: Len's spoiler buggy |
All I can say is wow, words cant describe how awesome your build project is.
Simply amazing and the way every project should be done..if time and resources is unlimited. I did a similar build on my 89 Euro E30 which is in Canada..you have one of the best projects I have seen...great work. |
Posted: Mon Sep 18, 2017 5:46 pm Post subject: Re: Len's spoiler buggy |
Well I have to order new lines. I tried again tonight but the one fitting will not seat..i did install the e-brake cables . I used throttle cable clamps on the ends. Work like a champ.
Installed the long block so now I can shorten the cable . Getting there one day at a time..not years now _________________ 73' Bug
Posted: Mon Sep 18, 2017 6:00 pm Post subject: Re: Len's spoiler buggy |
I have bought flex braided lines from Pete at AirKewld and have had great success with them. Custom for the calipers so the hug close. Can get short ones or long ones to run straight to the brass junction block. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Sep 18, 2017 6:16 pm Post subject: Re: Len's spoiler buggy |
Joe I talked to pete today .I will be ordering them tomorrow. _________________ 73' Bug
Posted: Thu Sep 21, 2017 12:50 pm Post subject: Re: Len's spoiler buggy |
I just sent out my Kadrons tio Kaddie Shack for an overhaul, I want to make sure the car runs good before I try to experiment with the center dcoe weber.
I put the engine in but have to wait until I get the tins painted before I will be able to finish putting all the goodies back on. _________________ 73' Bug
Rockbound Samba Member
Joined: September 06, 2017 Posts: 303 Location: Pennsylvania
Posted: Wed Sep 27, 2017 10:22 am Post subject: Re: Len's spoiler buggy |
great looking build so far! love it! |
Posted: Wed Sep 27, 2017 5:06 pm Post subject: Re: Len's spoiler buggy |
Big thanks to Airkewld for the brake lines and brakes to hold the emergency cable and brake cable from hitting the shock..maks for a very clean look..breals are all sealed now.
Posted: Wed Sep 27, 2017 5:54 pm Post subject: Re: Len's spoiler buggy |
That looks good. Should have a good service life. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu Sep 28, 2017 4:27 am Post subject: Re: Len's spoiler buggy |
WOW , I just read my post from last night, I guess I should have had my glasses on, Or spelled checked it.
Big thanks to Airkewld for the brake lines and brackets to hold the emergency cable and brake lines from hitting the shock. Makes for a very clean look.. breaks are all sealed now with no leaks. onto the motor and paint hopefully soon. fingers crossed _________________ 73' Bug
