52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Wed Aug 04, 2010 5:42 pm Post subject: 25hp industrial motor? |
hello all what is the difference in a 25hp industrial motor and a car motor?.i have a chance to buy one for a spare for my 52 or should i even bother with it? and can you make it look correct for the year? thanks |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
Posted: Wed Aug 04, 2010 6:44 pm Post subject: |
If it's the same configuration as the later industrial engines, the crankshaft and connecting rods can't be used in a non-stationary (IE vehicle) application. Carburetor and distributor will probably be different too. Expect to only be able to use the case, pistons/cyls, cylinder heads etc. _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
EverettB wrote: |
I like your fork. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Aug 04, 2010 6:49 pm Post subject: |
tstracy39 wrote: |
the crankshaft and connecting rods can't be used in a non-stationary (IE vehicle) application. |
can you please explain why? thanks. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Wed Aug 04, 2010 6:52 pm Post subject: |
hazetguy wrote: |
tstracy39 wrote: |
can you please explain why? thanks. |
I read in the forums that the crank and rods are a single assembly (can't be taken apart) and designed to run at a constant RPM, will fly apart if used in an ungoverned engine. _________________ Check my classifieds for kewl gauges:
EverettB wrote: |
I like your fork. |
Posted: Wed Aug 04, 2010 6:57 pm Post subject: |
interesting. i have never heard of that nor seen pics of that. any further info about it? i would like to see pics. are you talking about a roller crank? _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
BUGBOY1976 Samba Member
Joined: August 21, 2004 Posts: 278 Location: Australia
Posted: Wed Aug 04, 2010 7:52 pm Post subject: |
I have a 36hp motor and its rated as a 25hp and this is only due to the fact that the mag will only let it rev to a certain rpm. Saying this thats why its rated as 25hp. |
HeSa Samba Member
Joined: January 15, 2007 Posts: 466 Location: FINLAND
Posted: Wed Aug 04, 2010 11:13 pm Post subject: |
25 hp industrial engines are the same as car engines. I have owned 5 of them. The only parts you need to change are the carb jets and in some cases the valve springs. |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Thu Aug 05, 2010 1:33 am Post subject: |
The internals of 25 and 36hp engines, are the same as the car engines.
To answer the OP, yes it can be used in a car. You just need a dizzy and carb from a car. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Thu Aug 05, 2010 4:05 am Post subject: |
I drove all kinds of industrial engines in cars.
As written, beside carb details, distributors and sometimes tin details,
they are the same as car engines and can be used without problems.
You just will have a 122-.... number on them. _________________ Master of my domain! |
1500king Samba Member
Joined: January 05, 2007 Posts: 209 Location: Adelaide, Australia
Posted: Thu Aug 05, 2010 6:02 am Post subject: |
tstracy39 wrote: |
hazetguy wrote: |
tstracy39 wrote: |
I read in the forums that the crank and rods are a single assembly (can't be taken apart) and designed to run at a constant RPM, will fly apart if used in an ungoverned engine. |
Really? I would love to see that..! Don't believe everything you read... |
vwrobert Samba Member
Joined: February 10, 2002 Posts: 370 Location: England
Posted: Thu Aug 05, 2010 6:06 am Post subject: |
I run a NOS industrial motor from a firepump in my vert, It was stored in Sweden for 40 years no hours on the timer. I fitted it and found that it wouldnt run above 1500rpm so i fitted an Okrasa cam and it runs like a dream.
So YES you can use an industrial motor in a car. _________________ 1973 1303 RHD Vert Project
WWW.TheVolksmeister.Com |
splitjunkie Samba Member
Posted: Thu Aug 05, 2010 6:52 am Post subject: |
as has been stated, the distributor, carb need to be changed. I have heard that the camshaft is different as well but other than that all of the internals are the same. _________________ Chris
coad Samba Scapegoat
Posted: Thu Aug 05, 2010 7:44 am Post subject: |
splitjunkie wrote: |
I have heard that the camshaft is different |
That's true with the Porsche industrial engines, and people have said it about the VW's but no one has ever posted any information, and I've never seen an industrial cam for sale.
Anyone know for a fact one way or the other? |
Posted: Thu Aug 05, 2010 7:58 am Post subject: |
You are right. I have only heard that about the cam shafts, I don't know that for a fact. Seems like I have seen some info on the industrial engines somewhere. I will have to dig and see if I can find it.
Edit: Found the '56 industrial engine parts manual.
The part numbers are the same for the cam so that must just be a myth. At lease for '56.
Here is the complete manual.
http://www.thesamba.com/vw/archives/manuals/july56_industrial.php _________________ Chris
Posted: Thu Aug 05, 2010 8:11 am Post subject: |
another interesting tidbit.
Look at item 1 and the two options above it.
- 160 watt generator
- 90 watt generator
1 generator housing with shaft. For applications where you didn't need a generator.
[url][/url] _________________ Chris
Posted: Thu Aug 05, 2010 8:21 am Post subject: |
1500king wrote: |
tstracy39 wrote: |
hazetguy wrote: |
tstracy39 wrote: |
definitely not true.
Posted: Thu Aug 05, 2010 10:09 am Post subject: |
I used some of the pump tinware and some off my original motor, as i previously stated i swapped out the cam and found that i had better Revs when i accelerated, not sure if it was the cam but it worked, I used the OG carb no new jets and otherwise i made no other alterations.
I have the NOS pump cam sitting here on a shelf, it has the same part number as previous post. _________________ 1973 1303 RHD Vert Project
IN2VWS Samba Member
Posted: Thu Aug 05, 2010 2:16 pm Post subject: |
vwrobert wrote: |
So YES you can use an industrial motor in a car. |
Here is an Industrial motor from 1955 with very low hours on the meter. It runs higher than 1500 rpm in the pump format, so there is no reason it won't run higher than 1500 rpm in a car with the correct dizzy and carb.
http://www.vimeo.com/4011678 _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Thu Aug 05, 2010 7:01 pm Post subject: |
great info guys, looks like i will pick this motor up. it does need 1 piston cylinder set. are they the same size as in a car set up and what size should they be. i have not seen this motor only verbal over the phone. all info will be greatly appreciated. thanks again |
