shenan-agon Samba Member
Joined: May 11, 2005 Posts: 423 Location: Portland, OR
Posted: Fri Aug 06, 2010 8:35 am Post subject: Cutting swivel seat base out of donor van |
I found a junkyard donor van that I want to pull the seats out of to swap into my Westy. The donor has a swivel on the passenger side, which I'd really like to swap over as well. I haven't taken a close look yet, but I'm going to assume it's a factory install with the lower piece welded in place.
What's the best way to cut the base out of the van? I can borrow a cordless sawzall...just not sure what the easiest cut location is going to be both in terms of getting it out and reinstalling later.
I have a wire-feed welder, so will be using that for the install. |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Fri Aug 06, 2010 9:05 am Post subject: |
I found it a little easer to use a cordless drill and a centerdrill bit and drill the welds. Then with a flat chisel breaker loose. But Iv also found one that was instaled with Alum. rivets?? I was able to give that one a few good yanks and out it came. _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
danfromsyr Samba Member
Posted: Fri Aug 06, 2010 9:23 am Post subject: |
no way that's easiest, they're NOT spot welds, they're bead welds..
what I do is a cordless sawzall (plenty of spare batts in car)
I make a cut down one side only (the outside) thru the sheet metal and then via the wheel well cut the outside totally free. cut the thin metal the thick stuff wastes precious battery life.
then I hinge/lever it up against the welds on the inside edge (do have to score a little weld that goes side to side so it'll crack)
but I lever it up & down and it stresses and fatigues the weld to crack.
so that I can deal with cleaning it up at home.
Best of luck they're worth it and not side specific. _________________
Abscate wrote: |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Fri Aug 06, 2010 10:11 am Post subject: |
Hmm, so you actually go from the outside of the van through the wheel well? Having a hard time picturing where to cut (though would probably make more sense if I had the van sitting in front of me)... |
Posted: Fri Aug 06, 2010 12:35 pm Post subject: |
shenan-agon wrote: |
no. take the seat off and the top swivel part. look at the piece you need pillage. there are weld beads on both sides. cut at the weld beads on one side...once that side is free of the van, twist it up to break the other side and it will come free. you then need to weld this part into your van at the same spots it was previously welded.
heres mine after welding it in. you can clearly see what is new and old:
_________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
Posted: Fri Aug 06, 2010 4:06 pm Post subject: |
Let me clearify. I took the hole rail off. I drilled out the spot welds from the factory rails. then chisel under the rail. Sorry.
I bought one off C/L that was cut off inside the welds and there was not enough left to reweld it in. Thats why i would take the rails and then grind off the welds when i got home. There are a lot of wrecking yards that dont let you grind or flame cut in the yard.
jcl _________________ 87 gl powerd buy 2.5subaru
VR Fox Samba Member
Joined: November 28, 2009 Posts: 9 Location: Ridgeley, WV
Posted: Sun Aug 08, 2010 6:56 am Post subject: |
A cordless angle grinder with a waffer wheel is the way to go. You can cut directly on the welds inside of the stock seat rails with no harm to any of the surrounding metal.
BTW, a cordless grinder and spare batts are an invaluable junkyard tool. I've used one for everything from cutting heads off of stuck bolts to salvaging entire quarter panels. |
Robw_z Samba Member
Posted: Fri Nov 12, 2010 10:04 pm Post subject: |
Just adding my experience from the junkyard today...
I think using a sawzall SUCKED, and I mean SUCKED. I rented a 1000W generator($20 for 2 hours) and brought it to the yard. A grinder with a cutting disk would have been 10 times easier, and I had one, BUT the yard has a no grinding policy so I had to leave it in the car.
I went through all kinds of angles and approaches and cusswords to get one side cut(side to center of van) then levered it up and broke the welds on the other side.
PS: A 1000W generator is NOT sufficient, it barely did the job.
tencentlife Samba Member
Posted: Sat Nov 13, 2010 3:52 pm Post subject: |
When I wanted some swivel bases out of a van at the wrecker's a few years back, Trey brought the van over near the shop on the forklift, and went at them with a sawzall. I politely waited and watched him trying to find an angle that would work, and getting very little purchase with the blade, before I said what I was thinking before he even started: "dontcha think an angle grinder with a cutoff wheel would do a good job on that?" He tried for another minute with the sawzall and went off the fetch the grinder. Took about two minutes per base to make nice clean cuts thru the welds, no damage to the bases at all, no crazy contortions involved. Sawzall is a great too for demo work but this is not the kind of cut it's any good at. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sat Nov 13, 2010 7:42 pm Post subject: |
heh, yeah well I've sawzalled many.. like 4 sets and it's fast and easy..
but most of the u-pull pick-n-puls here will NOT ALLOW a grinder in. and trust me I have a very nice 18v Dewalt grinder with a very thin titanum grade cut off wheels.
the dewalt sawzall still gets the job done easily. just not on the welds, _________________
Abscate wrote: |
Robw_z Samba Member
Posted: Sat Nov 13, 2010 7:54 pm Post subject: |
danfromsyr wrote: |
the dewalt sawzall still gets the job done easily. just not on the welds, |
I think you must use a strategy which is not immediately apparent to the eye, or against a Vanagon owners tendency to not want to cannibalize a van, even one which will never see the road again
I read your post above from months ago before going to the junkyard, and while there could not see how you do it. Do you cut a line parallel to the doorjam, in the middle between the jam and the seat track, and then go at it from below the wheel well?
-Rob
Posted: Sat Nov 13, 2010 8:23 pm Post subject: |
yes parallel to the outside rail then under the track along the "secret space' and connect the 2 parallel cuts to free the outward side.
I do cut thru the plastic expansion bottles, it is not reverseble.
and I use a BFH to cave the panel some to make the connecting cuts easier. _________________
Abscate wrote: |
