Bones 53 Samba Member
Joined: February 19, 2005 Posts: 661 Location: Reno NV
Posted: Tue Aug 10, 2010 8:28 pm Post subject: Where can I get a decent clutch cable? |
The picture says it all! My son only gets 6-7 months and about 5000 miles out of these clutch cables. They all break in the same place. The hook has been radiused ans there are no rough surfaces. The clutch is just a Stage 1 kennedy.[img][/img] |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Aug 10, 2010 8:55 pm Post subject: |
All the VW stores were closed when i really wanted to replace my clutch cable so I checked at Checkers. They had it! I was soo surprised. It was thicker cable too and comparing the aftermarket replacement to the Checkers one there was a clear difference. The head that attaches to your pedal was thicker as well. Good luck ). _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Wed Aug 11, 2010 6:09 am Post subject: |
Aren't the Kennedy's stiffer than stock components? Maybe not. BUT if so you could try a taller arm on the trans. Bowden tube sag may need adjusting. If the hook is fine on the pedal shaft and not gouging out the cable eylet (does the eylet just break or snap?), then they're either crumby cables or you may want to consider the taller arm. The taller arm reduces the effort to engage/dis-engage the clutch, thus reducing wear on all associated parts. There was a guy on here a few years back that had lots of the taller arms for sale. I ordered one from him and have it here. Turns out I didn't need it, but rather a new Bowden tube instead. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
AlteWagen Troll
Posted: Wed Aug 11, 2010 8:21 am Post subject: |
I dont see any greas on the head of that cable. Grease will add years to the life of the cable AND hook |
Posted: Wed Aug 11, 2010 9:10 am Post subject: |
Quote: |
Aren't the Kennedy's stiffer than stock components? Maybe not. BUT if so you could try a taller arm on the trans. Bowden tube sag may need adjusting. If the hook is fine on the pedal shaft and not gouging out the cable eylet (does the eylet just break or snap? |
It's a1700 pound PP and it has a long arm. I think stock PP is 1300 pound
The grease was wiped off to take the picture.
I think they are just crap metal on the cable end. |
74 Thing Samba Member
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Wed Aug 11, 2010 11:02 am Post subject: |
I know this works for accellerator cables, as I'm using one now.. but doesn't Morse make a cable that can be used for the clutch too?
I got my Morse cable at an offroad shop, but i'm sure they're available at a lot of places..
a quick google for "morse cable" finds this to be like the 3rd link down: http://www.jegs.com/p/JEGS/JEGS-Morse-Push-Pull-Cables-and-Accessories/763984/10002/-1
if you want strong, I think these are some of the best.. _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Wed Aug 11, 2010 11:46 am Post subject: |
You could swich to a hydrolic set-up.Look into CNC stuff. |
Posted: Wed Aug 11, 2010 11:53 am Post subject: |
vwinnovator wrote: |
That's a real expensive fix. He would have to fab hydraulic lines, fittings, etc. Worst, the clutch is not as responsive as a stock set up. That's the reason I'm selling my billet set up. You have to run a stiff clutch. Stick to a stock set up and replacement. Leave the hydraulic set ups to the racers and piperail guys. _________________ 2276 IDA's 86C 11-1 DD !
Eric_S Samba Member
Joined: August 12, 2007 Posts: 862 Location: Sparks (think Reno) NV
pupjoint Samba Member
Posted: Thu Apr 07, 2011 8:01 pm Post subject: |
do work on something similar for RHD... |
Eric_S Samba Member
Posted: Thu Apr 07, 2011 8:22 pm Post subject: |
pupjoint wrote: |
Do you have a specimen I could borrow to work off of? _________________ --
Eric_S
What are all these extra parts? |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Apr 07, 2011 9:36 pm Post subject: |
I have a KEP stage 1 and cable from CB Performance, it's still going with very little wear after 3 years. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
SRP1 Samba Member
Posted: Thu Apr 07, 2011 9:37 pm Post subject: |
Typically when a cable ends wears like yours, I have found that the hook or pedal arm the cable rides in is torn up too, causing the cable to wear prematurely.
Not saying that's the case in your situation, but just a thought. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Apr 07, 2011 10:27 pm Post subject: |
aye
I have made a few deals like that that uses a rollerskate bearing and the stock cable snaps into it.
This way I get to use all those cables with the end worn through........don't throw em out! |
