rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Fri Aug 13, 2010 1:04 pm Post subject: Foam on your OEM Factory Oil Cooler ? |
Anyone got data on putting foam on aluminum cooler to seal inside dog house ? I know originally there was an approx 1" wide strip to seal it within the shroud. Was gonna buy a cheapo piece at a foam store but employee says it won't last and is suggesting this gray colored with sticky back. Tips, suggestions, specs/dimensions much appreciated. I would buy the gray foam but have to see if it will be thick enough as it may only be 1/4" wide. Thanks, Bill. |
stoneloco808 Samba Member
Joined: June 15, 2007 Posts: 658 Location: Pakalolo Country, HI
Posted: Fri Aug 13, 2010 1:41 pm Post subject: |
I bought a small roll of this 1" wide gray foam strip from the local Lowes hardware store. IIRC it was marketed for use with garage doors. I forgot the exact length, but had a bunch left over from another home project. I have not removed the fan shroud since to see how it is keeping up though. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Fri Aug 13, 2010 1:58 pm Post subject: |
I use weatherstrip foam.... it lasts for years. _________________ Glenn
Member #1009
#BlueSquare |
lupin..the..3rd Samba Member
Posted: Fri Aug 13, 2010 2:17 pm Post subject: |
Does anyone have temp difference measurements of foam vs. no foam? I have no foam on mine, but I did use metal foil HVAC tape to seal all the external gaps between the doghouse tin pieces. |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Fri Aug 13, 2010 2:22 pm Post subject: |
Old carpet padding and rubber cement works quite well...the kind of carpet padding composed of several different colors of foam and the netting. |
rsorak Samba Member
Posted: Fri Aug 13, 2010 2:23 pm Post subject: |
Without the foam the space between the housing and the cooler is big enough that most of the air would go around the cooler rather than thru it I bet..... _________________ Rick '71 Westfalia & '73 Thing |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Fri Aug 13, 2010 5:03 pm Post subject: |
rsorak wrote: |
Without the foam the space between the housing and the cooler is big enough that most of the air would go around the cooler rather than thru it I bet..... |
x2 - you need the foam... _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
Bruce Samba Member
Posted: Fri Aug 13, 2010 10:12 pm Post subject: Re: Foam on your OEM Factory Oil Cooler ? |
rockerarm wrote: |
I would buy the gray foam but have to see if it will be thick enough as it may only be 1/4" wide. |
Get a roll of low density ¼" thick, ½" wide foam tape with adhesive on one side. You can double it up if it's not thick enough.
You don't have to cover the whole thing, just enough to block flow around the cooler. _________________
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Aug 13, 2010 11:04 pm Post subject: foam |
Here's an old (NOS) dealer doghouse oil cooler that I dug out of my collection a couple years ago...just the small foam strip, as mentioned earlier:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Sat Aug 14, 2010 4:19 pm Post subject: |
I used the weatherstrip too. Install the shroud over the cooler first. That way you can see the gaps that you need to patch. |
