wbrown45 Samba Member
Posted: Sun Aug 22, 2010 2:23 pm Post subject: |
If you look up the video on YouTube under Chinese truck crash test you will find this video. It is definitely a copy of a Vanagon though! _________________ OK Thang |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Sun Aug 22, 2010 2:38 pm Post subject: |
engineerscott wrote: |
nextorskater wrote: |
I´m still trying to know how this crash happened... |
Almost certainly the driver of that bug died in the crash, which is a shame.
It's also a shame for the bug as if you look at the photo carefully you can tell that the state of the paint job implies that it was almost brand new and very likely in almost pristine shape before it became one with the tree.
I too wonder how that accident played out. Looks like it was moving at a relatively high rate of speed in a turn when the wheels broke traction and it slid laterally off the road. |
Oval Window too |
tikitime Samba Member
Joined: December 12, 2006 Posts: 443 Location: New Westminster, BC, Canada
Lettuce Samba Member
Posted: Sun Aug 22, 2010 4:49 pm Post subject: |
wbrown45 wrote: |
If you look up the video on YouTube under Chinese truck crash test you will find this video. It is definitely a copy of a Vanagon though! |
Ive also read that it is a real Vanagon that had its frame weakened and loaded with bricks, to test the car launcher and wall. Either way, it isn't a normal VW.
here is a series on vanagon safety, pretty interesting http://www.youtube.com/watch?v=VJGaiOrkQwQ&feature=related |
Posted: Sun Aug 22, 2010 5:56 pm Post subject: |
Well that just goes to prove that you can't believe everything you read, or see on the internet! _________________ OK Thang |
skabonner Samba Member
Joined: May 12, 2009 Posts: 854 Location: La Habra, Ca
Posted: Sun Aug 22, 2010 7:20 pm Post subject: |
fluxcap wrote: |
Found these in the gallery of VWAdam. Sounds like maybe what you are looking for.
My 68 was hit at like 50 mph head on, luckily I wasn't in it, and it looked exactly like the severe one. And the seat does pop out of the rail just like the photos. _________________
Douglas Adams wrote: |
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. |
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Aug 22, 2010 9:30 pm Post subject: |
tikitime wrote: |
drscope wrote: |
It's easy enough to install a later collapsable shaft. |
Will it clear the gas tank on earlier models? |
Yes. The part that collapses is about the same diameter as the outer tube of the steering column. So just to make sure, pull off your left front wheel and check to see how much room you have between shaft and tank. You need about an inch more then with the stock shaft. _________________ Mother Nature is a Mean Evil Bitch! |
deaner Samba Member
Posted: Tue Aug 24, 2010 4:18 pm Post subject: |
some friends of mine hit a horse square on in their 60's bus...
luckily mommy and baby were sleeping in the back.
everyone was ok but the driver had to unlace his boots to get out!
the horse was not so lucky. |
Dropped Metal Customs Samba Member
Posted: Tue Aug 24, 2010 6:54 pm Post subject: |
i drive my 52 everyday.
its quite simple i just dont plan on crashing! _________________ BUSDROPPINGBEAMNARROWINGSTEERINGBOXRAISING"C"NOTCHINGRUSTREPAIRINGBEETLEDROPPING
@DroppedMetalCustoms |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Aug 26, 2010 10:03 am Post subject: |
drscope wrote: |
tikitime wrote: |
drscope wrote: |
Yes. The part that collapses is about the same diameter as the outer tube of the steering column. So just to make sure, pull off your left front wheel and check to see how much room you have between shaft and tank. You need about an inch more then with the stock shaft. |
Is it the same length drop in replacement?
Is it still available new since its a crash part? _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Thu Aug 26, 2010 11:24 am Post subject: |
It's been a long time since I did this, but I think they were the same length.
We had to remove the steering column from the car, remove the old shaft, load the new shaft into the column and then reinstall the column with the shaft in it. But I don't remember this being any big deal.
I don't know if they are still available new, but I would look for a fat chick in the bone yard.
I just got back from my local pick & pull type yard and there were 4 super beetles in there. (very unusual) They won't work! they had a different shaft with u-joints in it. So you need to find a 68 and up standard beetle.
I'm not sure when they started this, but I know they had them in 68. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Thu Aug 26, 2010 11:30 am Post subject: |
drscope wrote: |
I'm not sure when they started this, but I know they had them in 68. |
Thanks. Im sure I can make one work.
Im pretty sure 68 started it, when the new bumpers were intoduced at least for the U.S..... I cant speak for non U.S.
I was just curious since the new column with ignition switch was introduced in 68 along with the collapsible shaft, were they the same length as the old ones.
Funny I have owned over 100 pre 1967 Beetles, but never owned a post 67.
We cant find too many Air Cooled Beetles in our salvage yards. _________________ aka Ken {o\!/o}
Posted: Fri Aug 27, 2010 5:02 am Post subject: |
I'm not sure if they started this in 67, but I do know they had them in 68. I snagged one last summer from a 68 in the bone yard, so I know they had them. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Aug 27, 2010 5:11 am Post subject: |
drscope wrote: |
I'm not sure if they started this in 67, but I do know they had them in 68. |
Definatly not on 1967's. _________________ aka Ken {o\!/o}
mnakandala Samba Member
Joined: September 28, 2009 Posts: 245 Location: Sri Lanka
Posted: Fri Sep 17, 2010 8:14 am Post subject: |
What about this ???????
_________________ 1964 bug
1983 mitsubishi Delica |
akcapsamb Samba Member
Joined: September 11, 2010 Posts: 107 Location: East Coast
Posted: Fri Sep 17, 2010 8:38 am Post subject: |
wbrown45 wrote: |
The video labeled "bus crash" is not a VW, but a Chinese truck that looks similar to a VW product. |
I'd be very curious if you have supporting evidence for this statement... a source of some sort. It looks distinctly like a VW van. |
kombijon Samba Member
Joined: June 22, 2007 Posts: 175 Location: perth australia
Posted: Fri Sep 17, 2010 10:06 am Post subject: |
VW bus crash, it was a test of the crash system, the vw was loaded with 1 ton of concrete then slammed into the crash simulator at 100mph, normally crashes are conducted at MAX 60mph unlaiden. as you can see the crash simulator stands upto the impact very well! |
tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Fri Oct 29, 2010 7:52 am Post subject: |
60 miles an hour or more on a curve to the right. Driver over corrects or is inattentive and fish tales on wet/icey road and slides with drivers side door to front/tree side and became a taco. It was nice bug to. Most likeley not survivable, but wierd things happen.
From a old crash investigator.
Notice the WWII uniforms in the back ground and the German Lic Plate. Cool. The guy in the Trench coat is probably a CID agent. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Fri Oct 29, 2010 10:34 am Post subject: |
It's not photos, but some pretty interesting information regarding Beetle safety, at least in their heyday.
It's the Road and Track rebuttal to the Nader book about Volkswagens.
It's a lot of reading but I found it very interesting.
http://www.thesamba.com/vw/archives/lit/1972_road_track_nader.php _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana
zombie Samba Member
Joined: June 17, 2004 Posts: 1177 Location: Pothole City, CT
Posted: Fri Oct 29, 2010 10:47 am Post subject: |
Is there a link to this somewhere online? _________________ I run two fuel filters in my engine bay. |
