laughatgravity Samba Member
Joined: September 19, 2009 Posts: 95 Location: Philly burbs
Posted: Wed Aug 18, 2010 1:05 pm Post subject: body chassis bolts |
10mm right? what is is the pitch? I want to tap and die the bolts and nuts.
also Im pretty sure a few on my nuts on the inside broke off maybe one is the bulk head too... any helpful suggestions? this winter i plan to replace the pans, and am thinking that i could cut access holes to pull out the broken one and welding new ones on. |
ConchThing Samba Member
Joined: March 23, 2008 Posts: 31 Location: Jupiter, FL
Posted: Wed Aug 18, 2010 2:55 pm Post subject: |
not sure of the size but TTS has the set, all 24, for a pretty decent price, including the washers. As for the amputee...maybe a magnet some how? Only idea that comes to mind _________________ S&J
'74 Thing |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Wed Aug 18, 2010 4:53 pm Post subject: |
will have to check, some reason 8 x 1.25 pitch sounds familar.
the common 10 on the vehicle is 10 x 1.5 pitch I believe |
Tingman Samba Member
Joined: March 01, 2010 Posts: 14 Location: Massachusetts
Posted: Wed Aug 18, 2010 10:19 pm Post subject: |
Get some weld nuts, (they have flanges on them). Where the holes for the nuts that are bad drill them out to the diameter of weld nut, but not larger than the flange. Push the nut into the hole and weld the flange to the surrounding metal. _________________ 73 Thing (current project)
84 300SD Mercedes (diesel)
86 300SDL Mercedes (diesel)
03 230SLK Mercedes |
Semper_Dad Samba Member
Posted: Wed Aug 18, 2010 11:18 pm Post subject: |
Tingman wrote: |
Get some weld nuts, (they have flanges on them). Where the holes for the nuts that are bad drill them out to the diameter of weld nut, but not larger than the flange. Push the nut into the hole and weld the flange to the surrounding metal. |
_________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Thu Aug 19, 2010 6:02 am Post subject: |
63ziggy wrote: |
8 x 1.25 pitch is fender bolts.
ConchThing wrote: |
not sure of the size but TTS has the set, all 24, for a pretty decent price, including the washers. As for the amputee...maybe a magnet some how? Only idea that comes to mind |
I have a million of them, set from my car, set from donor car, 3 sets that the PO had. im going chose the best and clean the threads.
Tingman wrote: |
Thanks didnt think of those, seen em before but never installed. do I indent the metal to accept the flange? grind down the flange at all or just let it be?
I guess the body seal could handle the unevenness |
locky Samba Member
Joined: May 08, 2008 Posts: 573 Location: Nelson, British Columbia
Posted: Thu Aug 19, 2010 8:19 am Post subject: |
I just replaced about 20 of these. Time consuming to say the least. I used my plasma cutter to cut the old nuts out. Then I took some 18 gauge sheet metal and cut it to the proper width and length, leaving extra to overlap my hole. I then took my fender and bolted it on one of the old nuts. Then very carefully took my patch metal and slid it in behind the fender to the correct place and used a jiffy to mark the hole. I then pulled the piece back out and drilled a hole on my mark. Next I flipped that piece over and welded my new nut in place. I then took that piece back to it's spot and slid it back in overlapping over my hole to the correct spot. Then slid the bolt in to make sure it fit. I then took my marker and marked the edges of my patch on my fender well and pulled everything out, and lap welded the piece in. I did this procedure for all of them, taking my time to make sure they fit. Once welded in, grind down the welds with a flap wheel and fill with glass. |
locky Samba Member
Posted: Thu Aug 19, 2010 8:21 am Post subject: |
I got my nuts from Kubelman |
