nybugguy Samba Member
Joined: September 21, 2008 Posts: 117 Location: Upstate New York
Posted: Thu Aug 19, 2010 5:09 am Post subject: clutch and throw out bearing question |
I have a 1973 super beetle motor that I wanted to put on a 1962 era transmission.I know the actual case size is the same but I was wondering about matching up the current clutch and pressure plate on the motor with the throw out bearing in the trans.
The throw out bearing in the 62 doesn't have the collar to slide over and really doesn't have any bolt holes in the casing to even take one.The clutch on the 73 has the fingers without the center ring and was on a 73 trans that had the collar.Will this work? Ideas?? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Aug 19, 2010 10:19 am Post subject: |
You have to have all early model components for early trans... Pressure plate has to have ring on it to work.... There is no mix and match.....Its all one style (early) ... Throwout bearing style determines this....
http://www.mydune-buggy.com/home/dl_files/VW_Clutch.pdf
Posted: Thu Aug 19, 2010 1:31 pm Post subject: |
Thanks Dale......are the flywheels the same?Tried fitting the later model 73 motor with the flywheel to the early 62 trans and the flywheel seems to hit.Are the early flywheels a bit smaller? |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Aug 19, 2010 3:34 pm Post subject: |
Yes, a 6V flywheel is smaller in diameter. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Aug 20, 2010 9:28 am Post subject: |
Here is some reading that may help you... But you probably have already seen it....
http://www.thesamba.com/vw/forum/viewtopic.php?t=428392
