VR6 vanagon Samba Member
Joined: October 26, 2008 Posts: 93 Location: New Port Richey Florida
Posted: Thu Aug 19, 2010 6:12 pm Post subject: What are the collection of outlets on the side of a westy... |
On the side of a Westy, where you fill the water and plug into electric. My gasket is gone and it is leaking water inside my van. What is that called?
I want to replace and not put silicone or something on it. But I just can't find a description of one to see what it is called. |
kamzcab86 Samba Moderator
Posted: Thu Aug 19, 2010 7:22 pm Post subject: |
I guess I just order 3 of those?
Thank you for the link! |
madspaniard Samba Member
Posted: Thu Aug 19, 2010 9:44 pm Post subject: |
VR6 vanagon wrote: |
yes _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Sheesh Samba Member
Joined: October 18, 2007 Posts: 394 Location: New Pine Creek, Orygun
Posted: Fri Aug 20, 2010 9:52 am Post subject: |
I believe it is still recommended (and I recommend) not only replacing the gaskets, but using silicone or some other sealant as well. Solve the problem - for good. If you don't do this, you will be revisiting the problem in the near future. _________________ 1982 Westy, 2.0L AC CA emissions |
randywebb Samba Member
Posted: Fri Aug 20, 2010 12:37 pm Post subject: |
might want to use a small mirror and light source to look around at the inside of that panel
people report horrible rust problems... _________________ 1986 2.1L Westy 2wd Auto Trans. |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Fri Aug 20, 2010 5:26 pm Post subject: |
You should also carefully inspect the outlets themselves, for cracks, holes...etc., old plastic gets brittle and new gaskets wont really help if the outlets themselves are letting water in.
And while the outlets are off you should try to pull all the fiberglass insulation that you can out since it can hold quite a lot of moisture in it (ideally the insulation would be removed from the inside while the cabinets are out) rusting the panel from the inside out. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
