Full flow plumbing - ever seen this before? UPDATE W PICS
risk
risk is offline
PostPosted: Sun Aug 22, 2010 5:25 pm    Post subject: Full flow plumbing - ever seen this before? UPDATE W PICS Reply with quote
Helping a friend with his 69 bus.. Has a stock 1600 dual port w as41 universal case.
Never seen a full flow setup like this though, it has 1/4 pipe threads tapped into the main oil galley.. One is near the end of the galley by the plug and the other, return i guess is about two inches up the galley. I can post pics tonite.
grimace007
grimace007 is offline
PostPosted: Sun Aug 22, 2010 5:27 pm    Post subject: Reply with quote
sounds like a type 3 full flow setup...
and on a universal case it would make alot of sense
something like this?
http://volkshaus.com/images/typ3/63/2332_motor/short_block/tapped_full_flow_typ3_1.jpg
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
risk
risk is offline
PostPosted: Sun Aug 22, 2010 5:51 pm    Post subject: Reply with quote
Yep thats it.. Seems like the fittings are way too small though.. Also how does it work? Is there something pressed in the galley between the two tapped holes to redirect the flow?
Dale M.
Dale M. is offline
PostPosted: Sun Aug 22, 2010 5:57 pm    Post subject: Reply with quote
Look at left side of right hand hole... Note brass colored plug...
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
risk
risk is offline
PostPosted: Sun Aug 22, 2010 6:12 pm    Post subject: Reply with quote
Ok so each tapped hole has a 1/4 pipe thread street L then what looks to be a hydraulic type hose with crimped fittings going to the remote filter.. Restrictive enough to cause any issues?
risk
risk is offline
PostPosted: Wed Aug 25, 2010 6:09 am    Post subject: Reply with quote
ok here are the pics
perrib
perrib is offline
PostPosted: Wed Aug 25, 2010 6:21 am    Post subject: Reply with quote
It will work you just have to be very careful.
risk
risk is offline
PostPosted: Wed Aug 25, 2010 6:55 am    Post subject: Reply with quote
Careful? how so?
perrib
perrib is offline
PostPosted: Wed Aug 25, 2010 7:06 am    Post subject: Reply with quote
I'm sure you have already thought of it. While not fragile as glass the mag is very thin in that area, removing the fittings, hoses or supporting them when removing the engine will require ones full attention. Smile
Dale M.
Dale M. is offline
PostPosted: Wed Aug 25, 2010 7:14 am    Post subject: Reply with quote
risk wrote:
Careful? how so?
Case is very thin at the point of drill and tap for fittings, any excess leverage on case (fittings) may fracture it.... Making case a door stop....
Dale
risk
risk is offline
PostPosted: Wed Aug 25, 2010 9:17 am    Post subject: Reply with quote
i can see where that would be an issue.. but what really concerns me is the inside diameter of the fittings in the case, about 1/4". i'm wondering if this restriction in the oil flow is causing the motor to run hot.
