After 20 years ... a Thing!
waxhead
waxhead is offline
PostPosted: Fri Aug 01, 2014 4:43 pm    Post subject: Reply with quote
Looks great - nice work!
Mike B.
mkparker Premium Member
mkparker is offline
PostPosted: Fri Aug 01, 2014 8:11 pm    Post subject: Reply with quote
That's very nice, thanks for the pics!
Michael
Driver 1061 TDRA and BITD
Pit Boy 6163 Spec Trophy Truck
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Aug 05, 2014 11:12 am    Post subject: Reply with quote
Thanks for the input! The kid agrees and we are going to match the bumpers to the cage. We might just get carried away and coat the engine tin and back seat backs in the same hammered tone. Cool Back to work on it after our vacation on 8-11.
Shoyrtt
Shoyrtt is offline
PostPosted: Thu Aug 14, 2014 4:48 pm    Post subject: Reply with quote
Back from the vacation, I got the bumpers and seat backs from blasting and powder coat....turned out nice! Cool
And a close up of the powder coat:
GI Joe
GI Joe is offline
PostPosted: Thu Aug 14, 2014 9:29 pm    Post subject: Reply with quote
Well done!! Looks great man!!
Cool
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
mkparker is offline
PostPosted: Mon Aug 18, 2014 9:36 am    Post subject: Reply with quote
I agree!! Very nice!
How was your V2R this year?
Michael
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Aug 18, 2014 10:17 am    Post subject: Reply with quote
Thanks! I thought I was going to ride in a 10 car but I ended up helping out at the pit at Redlich (rm305). Good time with good friends! How about you?
Worked on the Thing on Sunday. Due to the limited space between the front of the cage and the body, we fabbed up some windshield brackets to replace the lower latches. My son and I tackled the windshield install using baby powder to slide it right in. Wink I forgot however to install the new TTS lower frame seal that is in the mail, so it looks like we will have to pull the lower section of the frame to install the seal. Embarassed
The only trouble we are having is figuring out the hood latch. We bought a new cable, tubing and the lower receiver from TTS (they were all missing on the car). The latch on the hood itself is original. When we pull the cable at the glove box, the hood doesn't pop. If we use two people (one on the cable and one at the hood to pull) it pops but we can't get it open. I messed with the spring on the hood latch and the latch position but it doesn't seem to want to get better. A little more trial and error should do the trick. Confused
Ron Domeck
Ron Domeck is offline
PostPosted: Mon Aug 18, 2014 12:53 pm    Post subject: Reply with quote
That lower windshield seal slides in, no need to take the lower part off. Fold down the windshield and slide the seal in.
Ron Domeck
PostPosted: Mon Aug 18, 2014 1:00 pm    Post subject: Reply with quote
Hood latch, I use a flashlight as I am lowering the hood down and adjust the upper latch so that the spring loaded part is centered the lower latch before pushing all the way down. To get the hood to pop up you may need to adjust down the rubber stops on both sides. If the hood won't latch adjust the spring assy.
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Aug 18, 2014 3:16 pm    Post subject: Reply with quote
Thanks for the tips Ron!!!! Cool
I may run into trouble then with the hood. The PO drilled holes on each side of the hood where the rubber stops are mounted to use posts and pins to secure the hood. Rolling Eyes I welded and cleaned up the exterior holes but didn't touch the underside. The underside of the hood might be too jacked up to put the stops in. Crying or Very sad I guess I'll put in my weekly order to TTS and add in a pair of these: http://www.thethingshop.com/RUBBER-BUFFER-FRONT-HOOD/productinfo/311823499A/
Hopefully a little Macgyvering with the underside sheet metal and we can get those mounted. Wink
mkparker is offline
PostPosted: Tue Aug 19, 2014 7:18 am    Post subject: Reply with quote
We finished our first V2R, it took three tries but we did it! I think 13th unofficially out of 39 Class 10 cars. The engine developed a miss between Pit 9 and 10 while I was driving. Our guys in pit 10 didn't have much Ecotec experience so we limped it all the way to 11, replaced an injector and headed to Dayton.
Michael
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Aug 19, 2014 12:23 pm    Post subject: Reply with quote
Congratulations! The silt this year was brutal. I was out of Redlich by 6:30 and don't remember seeing your car. The last car we pitted was the COPS C1 buggy. I know your pain. Those Ecotecs sometimes hate the heat & pump gas and go into limp mode at the worst times. Crying or Very sad
Looking at my hood latch issue again, I think the fix is fairly easy. The holes for the hood stops are fine. The PO cut out the raised sheet metal bumps in the nose. A little welding should do the trick. Wink
Ron Domeck
PostPosted: Tue Aug 19, 2014 1:18 pm    Post subject: Reply with quote
If you weld these remember the front wire harness is right there.
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Aug 19, 2014 5:11 pm    Post subject: Reply with quote
Thanks for the tip. Very Happy
With so many orders to TTS, do they offer frequent flyer miles or some other incentives? Once a week like clock work, I'm ordering some little part that I need. Maybe with my other car, I'll just send them 4 or 5K as a retainer to have on hand. Laughing
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Sep 16, 2014 3:51 pm    Post subject: Reply with quote
A little update on the progress (or lack thereof) on the yellow car. Still can't figure out the hood latch. I adjusted it with every plausible length on the plunger, lined it up (using Ron's flashlight method), got the little bumps from TTS and it still wont pop. I tried inserting the plunger without the hood, and it pops out great. Confused The only thing I can figure is maybe the lack of a hood seal somehow affects it??? Maybe a shorter plunger and increase the length of the little bumps???
Still fiddling with the brakes. After sitting 27 years they needed a lot of work. Also finding a gremlin in the starter. Again, 27 years old it was being difficult. I hit it with a dead blow hammer and it came to life, only to quit later. More new parts to buy. Razz
Ron Domeck
PostPosted: Tue Sep 16, 2014 5:22 pm    Post subject: Reply with quote
With the hood latch off adjust the rubber bumpers so they keep a good gap all the way around the hood. Then put the latch back on and then adjust the plunger starting with it short then lengthen until it latches.
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Nov 17, 2014 10:42 am    Post subject: Reply with quote
So I decided to take a spin in the 73 this weekend. Turned the key and nothing. Crying or Very sad I figured the battery was dead so I pull out my trusty jumper box...still nothing. Now on to the volt meter. Battery good, ground is good. Maybe its the switch. I pulled the lead to the back of the switch and found power. Pulled the steering wheel, pulled the turn signal and the cover to the ignition (finding lots of dirt and debris) and wala:
I'm surprised it even worked. I did a few searches here on the Samba and found a thread saying the 73 switch was different than the 74 and that the aftermarket Bug switch was too short. Now that it is Sunday and my local family owned VW shop is closed, I decided to try Autozone. Even though I was warned here on the Samba that all switches are not created equal, I tried the 73 Bug switch. It looked like it was the same size, however it had one extra terminal that the Thing switch was missing. I cleaned everything up, installed the switch and ...nothing. Crying or Very sad
So today I'm off to see if my local shop has one. If not, I have another order going into TTS.
Shoyrtt
Shoyrtt is offline
PostPosted: Tue Nov 18, 2014 7:24 pm    Post subject: Reply with quote
Local shop had the switch. I installed it late last night and still no luck. I guess I will be chasing the Current Flow diagrams (from the great technical section) to see if I can find the issue. Crying or Very sad
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Dec 29, 2014 10:58 am    Post subject: Reply with quote
Finally got through all of my wiring issues. After dealing with the old harness, brittle and broken connectors and its numerous hacks, I picked up a new harness from Rebel Wire. Very simple install. It turns out my cracked ignition switch also fried the starter. Sad After that was replaced it was time for a winter drive. If you look closely, you can see the LED parking lamps are on. Smile
GI Joe
GI Joe is offline
PostPosted: Mon Dec 29, 2014 11:18 am    Post subject: Reply with quote
Very nice!! Great to get it on the road, after All that work! Cool
'71 Beetle RPU
www.NLEOMF.com
Page 5 of 6
