vanagonjon Samba Member
Posted: Tue Sep 16, 2014 5:07 am Post subject: Vanagon 2.1 plastic coolant pipe hanger wire locations |
I have the plastic cooling lines out of my new to me '91 GL and there were none of the original stainless wire hangers on the van. The tubes were sagging real low under the rear cross member. I bought some replacement hangers from a forum member (Thanks TK) but I am not sure where they were placed originally from the factory. Does anybody know where they were originally placed? I see the original holes on the rear cross member. Also is there a best way to mount the heater hoses that does not interfere with anything else under the van?
Thanks
John F |
Posted: Wed Sep 17, 2014 8:31 am Post subject: |
The coolant pipes are heavy, so the VW engineers must have calculated how many hangers were needed to keep the plastic lines securely in place. When I purchased some from Terry Kay he said there were supposed to be four. I didn't see that many spots with holes/slots on the underside. Is there a VW drawing somewhere that shows the correct mounting of the coolant pipes and routing of the heater hoses?
Thanks,
John |
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1465 Location: Courtenay, BC, CANADA
Posted: Wed Sep 17, 2014 10:09 am Post subject: |
I'm quite sure my '89 had the original pipes and there were only 2 wire hangers, I believe at the last cross-member before either end. There was also a large wormscrew pipeclamp that went around both pipes and a hanger tab on the frame around the 1/2 way mark that keeps it pretty secure. When I replaced with stainless pipes I couldn't get the wire hangers back on as I probably didn't have them EXACTLY in the same position (looked the same but...). I reinforced with HD zip ties through holes in the cross-members and the pipes can't move now. The wire clips are in a labelled baggy for now. _________________
PUBLIC VANAGON REGISTRY: http://goo.gl/forms/QIiFT0zKhM
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Posted: Wed Sep 17, 2014 10:37 am Post subject: |
Some pictures from this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
And this: http://www.thesamba.com/vw/forum/viewtopic.php?t=546700&start=20
This is the forward end: you can faintly see one of the wire clips attached to the above cross-member about 8" back.
And again:
And again:
And the rear wire clip would go here see it on the front side of the cross-member):
And I think the hose clamp is just on the front side of the cross-member above the rear of the tank:
Terry Kay Banned
Posted: Wed Sep 17, 2014 11:25 am Post subject: |
Yea--the heater hose just runs along the coolant pipes with wire ties--
No problem--- _________________ T.K. |
Posted: Thu Sep 18, 2014 4:52 pm Post subject: |
Thanks, that's exactly what I needed to know.
John |
