matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Tue Aug 31, 2010 8:29 pm Post subject: Dual MC conversion Q's. MC port sizes?? FAG 211 611 021 A |
My question. Why do the 4 ports on my Dual port MC have different size holes going into the MC. Front 2 and rear port at ~45 degrees are 3mm while rear side ports is about 1mm. WHY and does it matter what i port where? All 4 are coutersunk for the compression fitting.
My MC is 211 611 021 A. FAG unit, older stock.
Back-up info.
Converting my 65 over to Dual MC. Following ERic & Barb's thread as well as Nates aircooled tech.
http://type2.com/library/brakes/dualmas.htm
http://www.aircooledtech.com/dual_MC_upgrade/
Seams like the larger 3mm rear port should be used for the rear brakes. The two front 3mm ports for the front brakes and the rear 1mm port for the brake sensor.
Thanks |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Sep 01, 2010 6:47 am Post subject: Re: Dual MC conversion Q's. MC port sizes?? FAG 211 611 02 |
i use a 67 master to do conversion. one line to a T fitting(found at rear on beetle) and the 2 empty ports on T are for right and left front brake lines.
one line to rear of bus to a T so 1 for left and 1 for right and i use 2 brake light switches. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Sep 01, 2010 6:59 am Post subject: |
That seems reasonable. Have you tried threading in the NPT brake switch? |
Posted: Wed Sep 01, 2010 7:06 am Post subject: |
Bill, Barry.
Thank you for the advice. My MC has 4 ports. (again type 2 part. 211 611 021 A) Following Eric & Barb i can port one to a Tee and off to both front brakes. One to the rear brakes. I am OK with that. The third would be for the brake switch and would plug the fourth. (I need to re-read how to plug that one though.)
Any advice on the hole sizes? Does that matter? Should i drill out the 1mm hole to 3mm?
Thanks |
