dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Sat Sep 04, 2010 4:54 am Post subject: Transmission differences |
I am in the process of installing a vair engine into a Beetle based buggy. As some of you know the vair runs backwards. One common fix is to flip the diff, but this results in applying load to the coast side of the gears. My question is as follows.
Does the trans from a bus that had reduction boxes run a special transmission or was it a "normal" trans with the diff flipped and running the coast side?
I do not really want to run the coast side and finding the necessary parts to reverse the rotation of the engine is proving difficult. _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sat Sep 04, 2010 5:08 am Post subject: |
You will get more reply's if you get this moved to the
Performance - Engines/Transmissions
forum.
_________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Sat Sep 04, 2010 5:59 am Post subject: |
I thought I'd get more replies from the people that drive buses with reduction boxes, as my question deals with a stock transmission. My application is irrelavent to the forum chosen. _________________ Licensed Automotive Service Technician
Current projects:
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sat Sep 04, 2010 7:13 am Post subject: |
The crown is flipped and the motion returns forward as it exits the lower axle in the reduction box. The guts are basically the same but running one backward will still give you the same problem wouldn't it? |
33 Willys Samba Member
Joined: January 28, 2008 Posts: 344 Location: Alamogordo, NM
Posted: Sat Sep 04, 2010 7:17 am Post subject: Trans diff |
It's my understanding that gears are surfaced hardened and there should be no difference in hardness between the load and coast side of a tooth. Now, if you were to do away with the RGBs you would be turning in the correct direction. Good luck with the project. |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Sat Sep 04, 2010 7:27 am Post subject: |
the bus trans has the dif flipped. so what would be the coast side in the bug is the drive side in the bus. it doesn't matter that much actually. In fact, it might be better to run the coast side. I know that a lot of trans rebuilders recommend flipping the 3rd and 4th synchro hubs to use the relatively 'fresh' coast side and the new drive side. by that logic, it would be beneficial to spin it backwards and use all the coasts as drives and drives as coasts. Does that make sense? |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Sep 04, 2010 12:54 pm Post subject: |
dan macmillan wrote: |
I thought I'd get more replies from the people that drive buses with reduction boxes, as my question deals with a stock transmission. My application is irrelavent to the forum chosen. |
eh?
since you are talking air cooled vw and you are certified on everything else in the world you need to dumb down your question to get help. then i can say your answer is "Yes" _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
BarryL Samba Member
Posted: Sat Sep 04, 2010 2:05 pm Post subject: |
The drive side is the same ramp of the crown teeth whether bus or bug. The pinion rotates the same way. Corvairing it, whether bug or bus, will still load the coast side. The thrust on the crown bearings will be reversed but could still handle it for awhile. It's the cut on the tranny gears' thrust where the action gets spooky. Better to put in the counter-rotation cam and get the reverse distributor drive and starter. |
