aldor5 Samba Member
Joined: September 04, 2010 Posts: 3 Location: Twin Falls, Idaho
Posted: Sat Sep 04, 2010 6:31 pm Post subject: Westfalia Cabinet Door Molding |
I have a 71 Westfalia Weekender, we have spent the last year reastoring it but i need the molding that goes around the doors in the cabinets, everything is stock westfalia, i have T molding, this is a different shape and i can't find it anywhere, thanks for the help. |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Sat Sep 04, 2010 7:10 pm Post subject: |
I haven't found a new replacement for that moulding. The only hope I think you have is heat. You can put the moulding in the clothes dryer for a few minutes, in a warm oven on a cookie sheet, or simply use a hair dryer. Get it warm then stretch it out until cool. A little white glue in the slot before installing will help it stay put for many more years. Good luck! _________________
busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sat Sep 04, 2010 9:36 pm Post subject: |
I use a hair dryer it works fine and you don't have to remove the trim to fix some of it.
_________________ where its cold and snowy |
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Sat Sep 04, 2010 10:39 pm Post subject: |
Nice work- I am gonna try that.
diet Dew??? _________________ Sent from a white van down the street. |
Posted: Sun Sep 05, 2010 12:23 am Post subject: |
greenbus pilot wrote: |
diet Dew??? |
I use to drink the regular dew but had to switch but I need to quite it all together. I drink WAY to much of the stuff. Iam happy the way the trim pulled out with the blow dryer and I didn't have to remove it from the door of which I think it would have broken up trying that. I have fixed many feet of trim this way its not purfect but close.
Desertbusman Samba Member
Posted: Sun Sep 05, 2010 7:41 am Post subject: |
In addition to straightening and all that is the how white and clean it looks. With soapy water it can be sanded with fine wet or dry sandpaper. Try different grits. Sand down bad looking spots. Smooth out nicks and flaws. Polish it with polish. Try different grades of rubbing compound and polish from course stuff to fine stuff. Even the toothpaste containing abrasives is a great polish. _________________ 71 Superbug
71 Westy |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Sun Sep 05, 2010 7:55 am Post subject: |
Desertbusman wrote: |
In addition to straightening and all that is the how white and clean it looks. With soapy water it can be sanded with fine wet or dry sandpaper. Try different grits. Sand down bad looking spots. Smooth out nicks and flaws. Polish it with polish. Try different grades of rubbing compound and polish from course stuff to fine stuff. Even the toothpaste containing abrasives is a great polish. |
Great tip right here
Devil is in the details. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Sep 05, 2010 1:43 pm Post subject: |
As for me Iam not building a show westy I just want the door to work right. _________________ where its cold and snowy |
tbaigent Samba Member
Joined: September 29, 2010 Posts: 6 Location: orlando
Posted: Mon Apr 11, 2011 11:04 am Post subject: hello great tip |
hello thankyou for this tip youve saved us vw lovers a fortune, i really need some help i have a 1965 so42 called layla i live in longwood fl i need to find out where i can buy the vineer to resurface my cabinets as there a little worn and marked or if some one does this and is reasonable priced that would be great thankyou |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Apr 11, 2011 11:15 am Post subject: Re: hello great tip |
tbaigent wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=101724&highlight=laminate _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jack-o-van Samba Member
Joined: April 27, 2017 Posts: 109 Location: Milwaukee
Posted: Sat Jul 22, 2017 1:28 pm Post subject: Re: Westfalia Cabinet Door Molding |
Bus Depot now sells the molding:
http://www.busdepot.com/j39432
Any tips on cutting the thin channels in the molding to fit through the hinges? |
