Westy Fire Extinguisher
advantageaction
advantageaction is offline
PostPosted: Mon Jun 03, 2013 5:45 pm    Post subject: Reply with quote
As a further for what it's worth... it is illegal in Canada to sell/purchase/refill/import halon fire extinguishers so we are pretty much left with Halotron or powdered extinguishers as options for our vans... just 'saying...
Cheers!
Barry
dhaavers
dhaavers is offline
PostPosted: Mon Jun 03, 2013 6:09 pm    Post subject: Reply with quote
FWIW - best price I've found online for 2.5# Halotron: $84 each +$27 shipping.
http://www.usaindustrialsupply.com/index.php?dispatch=products.view&product_id=32876
(I plan to get two - 1 by the slider & 1 behind driver's seat)
86 White Westy Weekender
"The WonderVan"
MootPoint
MootPoint is offline
PostPosted: Sat Jun 29, 2013 10:15 am    Post subject: Reply with quote
I did a bunch of searching here and didn't see anything about this:
http://jogrusa.com/collections/classic-vw-accessories/products/blazecut-fire-suppression-system
It's some kind of pressurized tube that goes in your engine compartment and explodes with the fire's heat. Anyone have any experience with this? There's a video on the Web link that looks interesting. Yeah, it's $225 but measure that against your $10,000 Westy.
Thoughts?
1984 Westy with tencentlife power!
http://www.silverrailsleadville.com
dhaavers
dhaavers is offline
PostPosted: Sat Jun 29, 2013 10:25 am    Post subject: Reply with quote
That ^^^ is rather amazing!
I love that it's very low-tech & obviously quite effective.
"The WonderVan"
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Jun 29, 2013 10:42 am    Post subject: Reply with quote
Interesting.
It is advertised on the Samba...
...and discussed here.
Certainly simple to install and, although spendy, I think much less than a recharge of a traditional fire suppression system.
joseph928
joseph928 is offline
PostPosted: Sat Jun 29, 2013 10:47 am    Post subject: Reply with quote
Thoughts?
Blue Bay Bus http://www.ebay.com/itm/SAFECRAFT-10-LB-FE36-FIRE-...mp;vxp=mtr That's cool but you can't beat 10 LBS. of FE-36, and it's legal in the US and up north.I just don't know if that tube will hold enough FE-36 to do the job! More is better. Very Happy http://www.thesamba.com/vw/forum/viewtopic.php?t=521827 Idea my other link still the best way to go. Have put in 9 of these so far!
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
Nachtfalter
Nachtfalter is offline
PostPosted: Sat Jun 29, 2013 11:06 am    Post subject: Reply with quote
Thoughts?
That is an incredible, easy product. My wife is alone with the van and the kids 90% of the time. That video is incredible. My only question is since the engine cover is right where the problem area is, where do you mount the tube? If you remove the engine cover durring a fire, you would obviously remove the fire suppression system.
Thoughts?
MootPoint
PostPosted: Sat Jun 29, 2013 11:20 am    Post subject: Reply with quote
Thoughts? I am buying this for sure.
Sort of OT but it is my understanding that you never remove the engine cover if you have a fire. It gives a slam of oxygen and turns a small fire into a huge fire. Shoot your extinguisher through the license place opening and hope for the best.
That said, I'm sure there's somewhere on a V'gon that would work for this.
Nachtfalter
PostPosted: Sat Jun 29, 2013 11:24 am    Post subject: Reply with quote
Oh. Shows what I know. Smile
TopaTopa
TopaTopa is offline
PostPosted: Tue Apr 03, 2018 10:35 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
Reviving a million year old thread here gang .. work with me ..
Finished replacing my fuel lines last night ('90 Westy full camper). New protector sleeves. Also new V-C billet fuel rails (..purrrdy). Replaced the plastic firewall fitting with a metal one from Terry (ILO abandoning it altogether-- call me crazy). Also tidied-and-cleaned-up fuel injectors from Witchhunter. Did it all myself, very methodical, real sano. Stoked.
Now it's time to fix in place a fire extinguisher, probably two (three?).
Anyhow, a simple, direct question: is there a bracket/extinguisher available today (April 2018) with an identical fit to the stock, already drilled mounting holes on the pillar behind the passenger seat? A thread search and study was a tad helpful, but given the spanse of time and product evolution I'd like to get an updated response. Yes, I know I can drill the bracket, or the van, or locate elsewhere .. but I remain curious nonetheless.
Gracias, in advance, to anyone who might be able to help solve the puzzle Smile
[email protected]
ahmed.aboudan@gmail.com is offline
PostPosted: Tue Apr 03, 2018 11:03 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
Don't think there was a stock one.
dobryan
dobryan is offline
PostPosted: Tue Apr 03, 2018 11:37 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
Westies came with one.
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
IdahoDoug
IdahoDoug is offline
PostPosted: Tue Apr 03, 2018 11:46 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
Failing that perfect fit in 2018, you might install a chunk of aluminum plate into the original holes, having already attached the 2018 extinguisher's mount to the plate. That way you haven't drilled holes in the van, and the aluminum plate may be an opportunity for you to also mount a flashlight, first aid kit, or hook for the car keys while camping. Bonus round opportunity.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces.
MootPoint
PostPosted: Tue Apr 03, 2018 11:50 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
My '84 came with a stock (but dead) fire extinguisher. But even if it was charged up I thought it was too small to be very useful so I bought a full-sized one.
When it comes to fire, you can't have too much "fire" power. [/img]
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Tue Apr 03, 2018 11:59 am    Post subject: Re: Westy Fire Extinguisher Reply with quote
As far as I'm aware, all Westfalia Campers equipped with stoves also were fitted with fire extinguishers. All were mounted just inside the sliding door; on Busses until 1979 they were mounted to the front of the bench seat cabinet, on Vanagons/Transporters they were mounted to the rear of the passenger seat pedestal.
In my experience, yes most compact extinguishers include a mounting bracket with adjustable screw holes to easily fit the standard Westfalia attachment points. As you say, I seem to recall perhaps drilling an additional screw hole on one van I owned in order to fit a new bracket. I'm usually a stickler for 'stock,' but exceptions must be when where safety is concerned.
Here's more info on choosing and using a fire extinguisher for your van:
http://campwestfalia.com/fire-extinguishers-camper-van/
Camp Westfalia
Camping Tips Newsletter Cool Campervan Apparel
www.CampWestfalia.com
dobryan
dobryan is offline
PostPosted: Tue Apr 03, 2018 12:30 pm    Post subject: Re: Westy Fire Extinguisher Reply with quote
That looks like it has a plastic strap holding it to the wall. In an accident that strap has no chance of stopping the extinguisher from being a large heavy projectile and really hurting someone or worse. The stock straps are usually there to keep an extinguisher from falling off the wall, not secure in an accident. (I hope that is a sturdy black metal strap firmly bolted to the wall, not two little screws).
Dave O
raoul mitgong
raoul mitgong is offline
PostPosted: Tue Apr 03, 2018 12:34 pm    Post subject: Re: Westy Fire Extinguisher Reply with quote
DaveO, that reminds me. I have extra "expired" fire extinguishers at my shop if you want one for your return trip. Still in the green but the fire dept makes me get new ones anyway.
-d
84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim))
dobryan
dobryan is offline
PostPosted: Tue Apr 03, 2018 12:41 pm    Post subject: Re: Westy Fire Extinguisher Reply with quote
-d
Yessirree!
Dave O
E1
E1 is offline
PostPosted: Tue Apr 03, 2018 1:08 pm    Post subject: Re: Westy Fire Extinguisher Reply with quote
Wonderful info, Jeff, Thanks!
1984 Westy-Ferrari firing at 33% capacity
I drive by the seat of my pants but then get behind on my steering
dobryan
dobryan is offline
PostPosted: Tue Apr 03, 2018 1:31 pm    Post subject: Re: Westy Fire Extinguisher Reply with quote
I read the article and noticed my pic was used as an example for stowing the extinguisher under the rear bench seat. He got it off the samba. Funny to see it....
Dave O
Page 5 of 6
