Locking Steering Column?
oscarsnapkin
oscarsnapkin is offline
PostPosted: Fri Nov 06, 2020 8:52 am    Post subject: Locking Steering Column? Reply with quote
I assume a ‘73 Thing would NOT have a locking steering column? I only ask because I may be picking one up next week that is without a key. Just wondering if I’ll be able to turn the wheel. I know way back in high school my Bus key would also start my friend’s Beetle, so who knows, maybe I’ll bring my keys along....Thanks.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
Dougster43
Dougster43 is offline
PostPosted: Fri Nov 06, 2020 9:32 am    Post subject: Re: Locking Steering Column? Reply with quote
The column is locking on a 73 assuming the lock pin is still in the column
oscarsnapkin
PostPosted: Mon Nov 09, 2020 12:17 pm    Post subject: Re: Locking Steering Column? Reply with quote
What is involved with ‘disabling’ the lock? If it was at my own home I could take it apart and figure it out. I will be driving about 2.5 hours to pick it up and will need to be able to load it onto a trailer with a come-along. Is it something I can figure on doing on location? My other thought was maybe throwing a pair of dollies underneath the wheels and getting a key made once I get it back home. Thanks.
- 1973 Thing
Semper_Dad
Semper_Dad is offline
PostPosted: Mon Nov 09, 2020 5:33 pm    Post subject: Re: Locking Steering Column? Reply with quote
Personally, I'd use dollies
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
mondshine
mondshine is offline
PostPosted: Mon Nov 09, 2020 6:47 pm    Post subject: Re: Locking Steering Column? Reply with quote
If I remember correctly, provided you are able to remove the steering wheel and wiper/turn signal switches, the ignition lock cylinder can be pulled out to release the steering lock. Check you tube for a video.
If you just want to turn the wheels to get the car on a trailer, a different strategy might be to remove the fuel tank and un-bolt the steering coupler.
Both of these things can be done in just a few minutes.
Plan C:
One of these under each front tire ($22 for 2):
https://shop.harborfreight.com/media/catalog/produ...098_W3.jpg
And winch it onto the trailer back end first.
Good luck, Mondshine
