noneed Samba Member
Joined: February 16, 2007 Posts: 922 Location: Roaming the Philly burbs
Posted: Tue Jan 22, 2013 8:52 pm Post subject: |
bummerbus wrote: |
In talking with the guys at peninsula glass, the felt and u channel are not normally sold so there are no part numbers for them but if you call and ask for 3/16th u-vinyl and sliding felt they will know what you are talking about. Price is $1.?? A foot for the felt |
Nice.
Does that felt channel fit the OG VW sliders or the Rivi style sliders ?
I have the late VW sliders in my camper and ONE "screw thru the seal" type screen.
I was also trying to figure out how to make it removable like someone posted previously. Nice for camping but I refuse to screw it back on through the new rubber.
Has anyone conjured up a clean way to do it ? _________________ Drive your VW... That's what it was made for.
Schwing wrote: |
Bondo is like make-up, it fools the eye from the ugly truth |
bummerbus Samba Member
Joined: April 12, 2009 Posts: 64 Location: Portland, OR
Posted: Tue Jan 22, 2013 10:51 pm Post subject: |
The felt fits the channel on the mid 70's riviera windows that I have. The channel is about 3/8ths wide so in theory if my math is right it should fit others around that size. _________________ ‘75 FI-1800cc. |
noneed Samba Member
Posted: Thu Jan 24, 2013 7:13 pm Post subject: |
3/8" sounds about right....
If it wasn't 20 degrees outside and dark I'd be out there with a tape measure right now ~
Has anyone looked into having the screw in type screen frames for the late sliders made ?
I took the one I have to a local old school hardware store that still does screen and frame work.
I showed the owner mine and just got the deer in the headlights look...
Getting similar aluminum doesn't seem to be an issue, but bending those 2 curved corners is where I lost the few people I've showed mine to. _________________ Drive your VW... That's what it was made for.
Schwing wrote: |
manikmike Samba Member
Joined: January 01, 2007 Posts: 504 Location: Boston, MA
Posted: Thu Jan 24, 2013 9:32 pm Post subject: |
Quote: |
Has anyone looked into having the screw in type screen frames for the late sliders made ? |
We have some serious custom screen shops down here, what with home outdoor pool business and all. If some of you are in need, I could bring one of my screen to one or two spots and see what they say. _________________ Mike
Boston, MA |
noneed Samba Member
Posted: Fri Jan 25, 2013 6:30 am Post subject: |
manikmike wrote: |
We have some serious custom screen shops down here, what with home outdoor pool business and all. If some of you are in need, I could bring one of my screen to one or two spots and see what they say. |
That would be awesome. Thank you !
I'd be interested in one if someone can make them like the originals.
No rush on my end...By all means take your time.
Anyone else in need ? _________________ Drive your VW... That's what it was made for.
Schwing wrote: |
Posted: Tue Jan 29, 2013 5:41 pm Post subject: |
OK - no luck at either spot - the hang up? The bend in the forward frame corners - neither place can do it... this really surprised me.
I've another place I want to hit... and then try the local RV dealer, since so many other parts of the conversion are standard RV parts. I can find bent frames online ( http://www.all-rite.com/custom-replacement-window-screens-p-101.html ), so maybe an RV dealer can narrow down a supplier... _________________ Mike
Boston, MA |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sat Mar 23, 2013 9:22 am Post subject: |
BoyWonder wrote: |
I was at a VW show this spring and saw this pass-through Riviera. The thing that I thought was the coolest was the pedestal he had for the table. The table leg rested in it just like the socket mounted on the floor of the bus.
Wow! good job finding that! I think it might be the exact OE Riviera part. Very cool idea Riviera had was to be able to set up the table outside the door , then move the stove outdoors (made possible cause the stove hooked up with a flex hose to the gas connector. Whole stove assembly stowed under the back seat when not in use. Frees up the counter space most of the time.)
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Sat Mar 23, 2013 9:26 am Post subject: |
Has anybody found a source for the white plastic molding/ seal that goes all around the pop top where it meets the steel roof? Probably some off the shelf RV part. ASI did stuff that way. Westy moved that direction as well. (Mine is a 1976, but I think many years are the same.
Vanagons:
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Sat Mar 23, 2013 11:21 am Post subject: |
69doublecab wrote: |
Al |
Mine is missing all that trim too. Not a huge priority for me, but something to think about locating. _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
EMPIFLAKE Samba Member
redbus Steve Samba Member
Joined: February 09, 2004 Posts: 133 Location: Southern California
Posted: Wed Apr 03, 2013 9:34 pm Post subject: |
Quote: |
Also has anyone ever found the white trim for the top??
I used Pinch Welt that is used on the inside of a bug's pop out window. Here is a picture I had in the gallery.
The bus is dirty and the ratty canvas has since been replaced, but it shows the Pinch Welt. It had been on for about 7 years when the picture was taken. It looks the same today, about 4 years later.
The link is for j-bugs, but I don't know what brand I used. My local vw parts store had it on a big roll behind the counter. I used the white one, it also comes in black.
http://www.jbugs.com/product/113-131B-WH.html?Category_Code=PopOutWindows _________________ Steve
1970 Westy with a Riviera Top
1969 Beetle
"Her shaft is bent and the rear end leaks, you can fix her quick with an oily rag, use a nail to start her I lost the key. Don't pay any mind to that whirring sound. She uses a little oil but outside of that she's cherry." -- C.W. McCall |
68aircooler Samba Member
Posted: Fri Apr 05, 2013 4:37 pm Post subject: |
I just bought a 75 Riveria! Do you guys know where I can get all of the info on these things? ps It has half of a westy interior, that needs to be fixed. |
type2much Samba Member
Joined: November 13, 2003 Posts: 319 Location: 65536 Missouri
Posted: Wed Apr 17, 2013 6:21 am Post subject: |
what is the purpose of the small pop top on a riviera? Is it so you can stand up in the bus?
Did a Riviera small pop top bus start as a passenger sunroof bus or a a kombi/westy body with the hole or did Riviera cut in the hole?
Did they have belly pans to compensate for the hole in the roof? _________________ Gnarly Goat Rancher |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Wed Apr 17, 2013 8:14 am Post subject: |
type2much wrote: |
Did they have belly pans to compensate for the hole in the roof? |
It is there to provide standing room, and a chimney effect for venting in warm weather. Not sure about the other questions. _________________ nothing |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Apr 17, 2013 9:21 am Post subject: |
cdennisg wrote: |
type2much wrote: |
It is there to provide standing room, and a chimney effect for venting in warm weather.. |
X2, all of the Riv's I've seen started out as Kombi's or SW's and Riviera cut the hole in the roof, there are a few on former sunroofs and even some Westfalia holes but most seem to be added later. No belly pans or extra reinforcement, the attitude seemed to be "just get that camper whipped up and fast, cheap and out the door so we can make more, the public is eating them up and don't seem to notice the difference!". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KaferBus Samba Member
Joined: April 19, 2007 Posts: 168 Location: Albuquerque, NM
Posted: Sun May 12, 2013 4:21 pm Post subject: Re: Latches!! |
bummerbus wrote: |
So I was trolling around on the samba the other day and was looking at posts about the side windows. This inevitably lead me to look up the peninsula glass co. and it's associated companies, where I found these.
http://www.boatwindows.com/shop-parts/#!/~/product/category=2987891&id=13097628
They look almost exactly like some of the window latches I saw in pictures. I ordered some and haven't have had a chance to install them, but they line up just about perfectly with the holes in the windows.
Cheers fellow rivierians! |
I was just going to post to see if anyone had come across these! I am missing just one of the screws and nut....might as well replace the latches too! I have a 77' Bay with Riviera interior.....but I suspect someone removed the pop-top and put what looks like a Adventurewagen high-top on it. _________________ 1957 Oval
1965 Kombi
1969 Beetle
69 Deluxe Bus
1971 Super Beetle |
BusThang Samba Member
Joined: November 04, 2011 Posts: 60 Location: West Georgia
Posted: Sun May 12, 2013 7:38 pm Post subject: |
Here's my '78 Rivi when I first brought it home.....
[/URL]
[/URL]
And now . . . . so far . . . . . .
[/URL] _________________ 1978 Riviera FI 2L Auto
Link to my build -
http://athensvwclub.com/phpBB2/viewtopic.php?t=1311 |
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Jun 10, 2013 7:41 am Post subject: Pondering a Rivi conversion |
Hello all,
I've located a functioning and structurally sound, complete Riviera top in my area and a seller willing to cut the entire roof off of the Rivi as it's mainly a parts bus at this point.
I have a '75 Westfalia Weekender camper (love the Westy interior, not loving the tin-top) for which a pop top would be perfect. I love the Westy interior/Rivi top combo...IMO it's the best of both worlds given the Camper I already have (knowing it's solid, well maintained and with a great interior). We're a family of 4 (kids are 8 and 4) and a dog, and it's hard to see all of us fitting in the Weekender as-is (we do have a child cot for over the front seats).
I'll be having my Camper repainted in the next year or so and thought that might be the best time to have the Rivi top installed...but before I buy the top and begin putting the wheels in motion for this I wanted to get the opinion of folks in this topic (definitely more Rivi-friendly than those in the greater Bay forum, where I'm sure I'd hear "don't do that!").
The top functions as designed, has decent usable canvas but of course the screens have some holes. All the support struts, springs and hold-downs appear to be intact. I believe the seals are there but I'd want to replace those if they're available. Because I get the entire roof I have the entire complement of trim material.
What are the hard-to-find parts that would deteriorate over time and need to be replaced?
Anyone have topic links to anyone who has tried this before (I know there's that one external 'family' blog, but I can't find any details of the conversion on the site)?
Any general concerns or benefits I may have missed?
Thanks in advance!
- Doug |
DougB Samba Member
Posted: Sun Jun 16, 2013 7:04 pm Post subject: |
Argh, Riviera top deal fell through :-/ I had been trying to contact the seller all week after seeing the top, to send my PayPal payment, and after 5 days finally hear that he sold the entire camper to someone else. Likely better for the camper and him, but I'm back to square 1.
Anyone know of any decent Riviera tips sitting atop long gone campers, or other Riviera tops that might be for sale?
Thanks!
- Doug |
Wrenchman12 Samba Member
Joined: October 26, 2009 Posts: 368 Location: Newmarket, NH
Posted: Fri Nov 15, 2013 12:53 pm Post subject: |
Nice thread! I've had a 73 Rivieria for 15 yrs or so. love camping in it! Here's a picture..
So anyways I am looking at replacing the white pop top seal and I was wondering if anyone has used this product from BD?
http://www.busdepot.com/231070100
its hard to tell from the picture what it really looks like.. you can order it by the foot which is nice. Its obviously black and not white though. wonder how that would look? Really more interested in knowing how well it goes on and stays on? _________________ 73 Riviera Camper
64 13w deluxe |
