mrm2you Samba Member
Posted: Tue Sep 07, 2010 8:30 pm Post subject: body support dolly |
anyone with advise on building a rolling support for body after it has been removed from pan |
Doodoob Samba Member
Joined: April 22, 2009 Posts: 250 Location: La Luz, NM
Posted: Tue Sep 07, 2010 9:53 pm Post subject: |
Made the one I used out of 2x4's, 4x4's, wood screws and some harbor freight castors. |
tom petersen Samba Member
Posted: Wed Sep 08, 2010 4:38 am Post subject: My body dolly |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
twotires Samba Member
Joined: March 15, 2007 Posts: 118 Location: Raleigh, NC
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Wed Sep 08, 2010 9:30 am Post subject: |
Mine...
_________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Sep 08, 2010 3:56 pm Post subject: |
Long sawhorses with casters - there's not that much weight, but get wheels that work for what you are doing. Good concrete floor can use fairly small, but hard casters - if rolling on gravel, bigger is better. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Motomazzo Samba Member
Posted: Wed Sep 08, 2010 5:30 pm Post subject: Re: body support dolly |
mrm2you wrote: |
IMHO, I think your body dolly design is predicated on whether or not you are going to be doing heater channel replacement. If you are, a design where the body rests on the dolly is no bueno. The best design I have seen by far (and I can't remember the builder now) was a 3-point design. It was built of metal. The two rear wheels where mounted on posts that came directly down from the two body mounts underneath the rear fender area. The front point came down from a "Y" from the two front mounts. Very compact, efficient, strong and allowed for access to all points of the car to include the heater channels. I wish I would have built mine exactly this way and did not. I built one of the wooden monstrosities as you typically see and while I made sure I could access/remove the heater channels, it's still a monstrous PITA.
Here’s mine.
Moto |
Posted: Wed Sep 08, 2010 5:48 pm Post subject: |
Here is the one I was refering to.
anthracitedub Samba Member
Posted: Wed Sep 08, 2010 6:16 pm Post subject: |
I built one for my ghia, very similar to what is seen here, but I left it open through the middle so the pan can be rolled in and out. I used plywood gussets for additional support since mine doesn't have any cross members at the bottom. I also bought 10" pneumatic wheels for mine…you can get them at the tractor supply sometimes on sale for $5 each…makes rolling it around a lot easier….I can not wait to get my body back on the pan…its been 20 months now! Just waiting on a few rubber body mount pads to come in and it will finally get put back on! |
Wired1 Samba Member
Joined: February 07, 2009 Posts: 48 Location: New Zealand
Posted: Fri Sep 30, 2011 12:01 am Post subject: |
Mine was originally another foot higher but my painter said it was too high for painting the roof so I cut it down to this...
_________________ 1961 unrestored Beetle - 1966 VW Baja project - http://www.youtube.com/user/wiredkiwi |
pdxeuro Samba Member
Posted: Sun May 20, 2018 9:33 pm Post subject: Re: body support dolly |
I need to build a dolly to hold the body off the chassis for a while for my slow father-son 1959 build. I like the designs where the chassis can roll out from underneath.
One quick question on this thread: is it better to have the cross supports under the fender areas (further apart), or closer together under the mid-region? Especially if it might be up on there for a while. Should the cross supports be 4x4 vs 2x4's?
I'm concerned about it denting or bending.
Thanks for any advice before I go buy supplies and start building. _________________ ----------------------------------------
Portland, Oregon
1991 Westy MV
1959 Bug
1977 Westy Bus - sold
1968 Bug - sold
2002 Eurovan - sold |
