Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Thu Sep 09, 2010 12:22 pm Post subject: Inside rear view mirror question |
My car hasn't had an inside rear view mirror in it since I purchased it, so I don't really know what the attaching end looks like. Does anyone know which mirror I need? And, how does it attach to the windshield frame? It is a 1984 Mexican Beetle, probably similar to a 1973. Pictures would be really nice, if possible. My windhield frame has a square-ish 3 notched hole in it.
Thanks in advance,
Paul _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Thu Sep 09, 2010 12:42 pm Post subject: |
I'm assuming it's similar to a post 72 US bug (as you mentioned). On my 72, there is a weird shaped opening in the metal just behind the windshield. The mirror has a weird cross shaped end that you set into the hole with the mirror 90 degrees from normal, then twist the mirror into place. The tabs on the cross on the mirror pull tight against the body, keeping it from vibrating. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Thu Sep 09, 2010 3:45 pm Post subject: Re: Inside rear view mirror question |
Paul Windisch wrote: |
Thanks in advance,
Paul |
that's it. |
66foot Samba Member
Joined: November 19, 2006 Posts: 394 Location: Pacific Grove, California
Posted: Thu Sep 09, 2010 5:38 pm Post subject: |
Paul -
Rearview Mirror for a 1972 Superbeetle:
Pat (66foot) _________________ "The perfect race car crosses the finish line in first place and then falls to pieces."
Ferdinand Porsche |
