elsyr Samba Member
Joined: May 06, 2008 Posts: 270 Location: North Florida
Posted: Thu Nov 01, 2012 4:25 am Post subject: Radiator Mounting Pads |
I'm probably not giving these things the right name, since I cannot find a listing for them anywhere on the usual parts suppliers' websites. Anyway, where the plastic tips on the radiator engage into the mounting bracket, there are rubber donuts for padding. When I replaced my radiator last time, the originals were rotted, so I made some replacements from heavy duty garden hose material. Since I'm going to have to replace the radiator again after my deer-strike, I thought I'd check and see if anybody knew where to find these. If not, I'll probably either re-use my replacements or make another set from a different material (something a little more cushy, probably).
Doug _________________ '89 Carat "Brunhilde" |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
elsyr Samba Member
Posted: Thu Nov 01, 2012 5:08 am Post subject: |
Eureka!
I forgot to check the other year/tranny categories on Van Cafe, as these do not show up amongst the radiator parts for "1986-1991 Automatic"
THANKS!
ZanaEvyPapa Samba Member
Joined: July 31, 2010 Posts: 255 Location: Gainesville, FL
Posted: Thu Nov 01, 2012 6:13 am Post subject: |
You can find the same thing at your local hardware store. Look in the hardware section for rubber washers. I did all 4 of mine for under ~$1. If you can't find the right thickness, you can double up. _________________ 82 Diesel Westy
03 Jetta TDI
Gainesville, FL |
