whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Fri Sep 10, 2010 2:48 pm Post subject: Whacking the starter |
So I made my goal of getting to Yucca Valley, near 29 Palms without cooling issues, but lost the starter in Ponoma. One whack with a hammer is doing the trick so far. Oh, automatic 1.9 84 westy.
Any thoughts as to whether this will get us through the weekend, or should I start looking for another starter here and now?
I'd rather take my time at home as I'm considering an upgrade and want to research it. For now the focus is on the cool music happening this weekend.
Camper Van Beethoven and Cracker at Pappy and Harriet's in Pioneertown!
Check it out, bring your spare old starter and I'll treat you and your date to the shows! Look for the beige westy by the stables west of the motel. |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Fri Sep 10, 2010 3:22 pm Post subject: |
Might work for a while, might not work again, it's a crap shoot.
The silinoid on the starters sticking. |
Posted: Fri Sep 10, 2010 3:30 pm Post subject: |
Come on seven, yeh I know there is not a definative answer. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Sep 10, 2010 4:04 pm Post subject: |
mightyart wrote: |
you misspelled sillynoid
Aloha
tp |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2453 Location: Southeast Kentucky
Posted: Fri Sep 10, 2010 6:05 pm Post subject: VW starters |
I've seen pre-12 Volt Beetles with a hole cut in the pan behind the back seat in order to gain access to the starter.............. with hammer laying there. If the starter didn't kick in, it go a whack with the hammer!
Those ole 6 Volt starters were terribly bad to have sticky solonoids!
I've seen 12v fans out of Computers mounted under there to keep the starter cooler! They were wired to the ignition and as soon as the key come on the fan was on! _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Fri Sep 10, 2010 9:25 pm Post subject: |
My experience with hitting starters says it will get you home, but don't get used to it unless you are carrying a spare. Too bad you're an automatic right now. Good luck. |
Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
Posted: Fri Sep 10, 2010 11:36 pm Post subject: |
My sticks when the humidity is up. I have been whacking for a year (maybe 20 times total in that time) and all is well! For some reason, I carry around the new starter with me, even though it would take a small army to change it out on my van. Pfffftttt _________________ On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter |
RadioRental Samba Member
Posted: Sat Sep 11, 2010 5:50 am Post subject: |
Mine is a little sticky. Has anyone had much luck cleaning a solenoid to solve this problem? _________________ __________________________________
'87 2.1. 125K 4spd Not rebuilt "Red Dwarf" |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10120 Location: Abiquiu, NM, USA
Posted: Sat Sep 11, 2010 9:10 am Post subject: |
Classicvibe wrote: |
I have been whacking for a year ... |
I believe there may be a 12-step program for people like you. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
