locky Samba Member
Joined: May 08, 2008 Posts: 573 Location: Nelson, British Columbia
Posted: Fri Sep 10, 2010 11:56 am Post subject: Replacement fuel line? |
Hey guys. Rebuilding a Thing. My engine is done and ready to go in. The body is almost ready to go back on. I want to put a new fuel line in. Engine is a 2017 stroker, dual weber 44's. Line between carbs is 1/4 inch. What size line should I run through tunnel from gas tank to carbs line? How does a larger size going into 1/4 affect it, if at all.
Thanks |
lupin..the..3rd Samba Member
Posted: Fri Sep 10, 2010 1:37 pm Post subject: Re: Replacement fuel line? |
locky wrote: |
Thanks |
1/4" is wrong. Replace it with metric line and metric hose. For the tunnel line, I use 7mm stainless tubing from mcmaster.com in my beetle. 2 meters is more than enough. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Fri Sep 10, 2010 2:48 pm Post subject: Re: Replacement fuel line? |
lupin..the..3rd wrote: |
if you are going to be that upity about it, Lupy, the 44's are wrong too... factory specs tend to be modified when NON factory parts are used... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
mark tucker Samba Member
Posted: Fri Sep 10, 2010 3:55 pm Post subject: |
the 7mm stainless is not oem either . just make sure the rubber line is alcohaul safe !!!! |
locky Samba Member
Posted: Fri Sep 10, 2010 4:17 pm Post subject: |
Actually the line between the carbs is 6.35m. Engine was built by Chico. I will call him to tell him it's wrong.
Aside from that, what are the effects going from smaller(line from fuel tank), to bigger(fuel line in tunnel), to smaller(6.35mm carbs), if any.
Thanks again. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Sep 10, 2010 4:19 pm Post subject: |
I used .250" OD stainless for the carbs with 7mm German hose in spots and still use the factory hardline in the body.
Engine is a 2180 w/ dual IDAs.
No need for larger unless you are building a dedicated drag racer. _________________ Glenn
Member #1009
#BlueSquare |
locky Samba Member
Posted: Fri Sep 10, 2010 4:37 pm Post subject: |
Cool, thanks Glen. |
Dale M. Samba Member
Posted: Fri Sep 10, 2010 7:41 pm Post subject: |
Generic 1/4 line is plenty.... No matter what uppity people say....
As Glenn says, just use good quality metal and rubber products....
