BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Sun Sep 12, 2010 11:28 pm Post subject: '69 Cal Look Project |
Hey guys, about a month ago I picked up a '69 cal look bug that's been sitting for 25 years or so. Since then I've been tearing it down for paint, stripping the motor, and trying to make some decisions about what I want in the long run. So far it's crazy how different this car is than my '65. Just wanted to post up some pictures and make a build thread so I can ask questions and keep everyone in the loop.
Car is a one owner '69 from Hawaii, taken to Colorado, stored in California. Has one piece windows (doors cut for clearance ), copper hurst shifter, sparco seats, all body trim had been removed, 1776 motor with dual 40 webers, oil cooler, deep sump, Lucas indicators, Empi 8's etc. Thing was pretty cool back in the late 70s' I bet. I'm gonna keep it cal-look for sure just freshen it up.
Sorry I haven't been very good with the pics lately, I'll be more thorough as the build progresses, but here she is when I rolled her into my driveway a month ago:
Here's an interesting contraption I found under the rear seat. One under each seating area, a toggle like switch with some wires running into the dash area, cut so I don't know what they were for?
Ideas? Alarm? Massager haha?
Here she sits today, semi-sanded down, about to go at the bodywork:
I'll post some pics tomorrow of the rust areas and see what everyone says about attacking them.
Here's my idea for a finished product:
My plans so far are disc breaks in the front, adjustable beam, t-bars, simplify the dash and close some holes from un-used knobs, Convert back to vent windows , stock low-back seats, Freshen up the motor with a cam and some gears, header, etc. Pretty much keep it simple, eliminate a bit of the late model stuff I don't want or need, and make it bulletproof.
Thanks for looking I'll post some more up as soon as I can,
Ben
spotco2 Samba Member
Posted: Mon Sep 13, 2010 6:45 am Post subject: Re: NEw '69 Cal Look Project |
I've gotta admit, I ain't never seen THAT before in a VW! Please tell me that you tested that optional equipment before you took everything apart. _________________ 69 Beetle
VW's are not just a car, they're an adventure! |
George Evans Samba Member
Joined: November 18, 2005 Posts: 632 Location: Flowery Branch , Ga
Posted: Mon Sep 13, 2010 6:59 am Post subject: |
Ejection seat? Man, that is going to be a nice bug! Keep us posted. |
Posted: Mon Sep 13, 2010 7:46 am Post subject: Re: NEw '69 Cal Look Project |
spotco2 wrote: |
I've gotta admit, I ain't never seen THAT before in a VW! Please tell me that you tested that optional equipment before you took everything apart. |
Haha no I didn't test it. definitely a switch though, turned on when someone sits in the seat the solid plate toggles the arm. Who knows! |
zombie Samba Member
Joined: June 17, 2004 Posts: 1177 Location: Pothole City, CT
Posted: Mon Sep 13, 2010 9:50 am Post subject: |
Seat belt light sensor? Do late models have those? _________________ I run two fuel filters in my engine bay. |
Posted: Mon Sep 13, 2010 11:30 pm Post subject: |
Haha I have no idea what those are for.
Got some more work done today. Decided that I was this far on the tear-down, so why not take the body off the pan so I could address the pan easier.
Here are the places I found rust. Some surface, some deeper. Just wanted to post them up to see what everyone thinks about them.
Have you guys had good luck knocking the paint down like I have then using phosphoric acid then priming and filling the small holes?
Here's where I think the PO cut for the one piece windows, middle of the picture inside the channel?:
I want to shave the antenna hole due to having an aux ipod cord only.
And the two holes under the radio hole since I wont have the air or heat hooked up.
And the vent in the hood to eliminate the rain catcher and all that jazz underneath.
My fenders have some minor salt damage, but are pretty solid. Problem is the bumper holes have been shaved and I want to cut them again. How would I go about finding the measurements to cut the holes for the grommets?
Here's a glimpse of that savanna beige OG Paint that remains untouched:
And a small amount of my parts pile. here's the cleaned block and tranny I just removed (filthy).
Pistons, barrels, and lifters all labeled.
And some stuff fresh out of the solvent tank to take to sandblast.
As always, any and all help is greatly appreciated. Enjoy the pics! |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Thu Sep 16, 2010 12:05 am Post subject: |
Nice progress, you're gaining on it. |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Thu Sep 16, 2010 9:37 pm Post subject: |
looks like you've got alot of the same things to patch up as me.
You doing the welding yourself?
The plan looks cool, might be easier to get some replacement parts for the front fenders and doors, not easy to reverse the old cal window's, so I hear anyway.
Keep up the work bro! |
Posted: Fri Sep 17, 2010 7:44 am Post subject: |
63Ragtop NZ wrote: |
I don't know what I'm going to do as far as the welding. The smaller stuff I might just braze up, but ya I'll probably have a friend tack in the other pieces for me.
Also, I think I'm gonna try and make these fenders work, but the doors I want to find some OG ones with glass and go from there.
Thanks man, I'll check your project out! |
