KCvan Samba Member
Posted: Mon Jun 05, 2017 11:57 am Post subject: Shore power line |
When I plug the shore line into power it does not charge the house battery. Is this normal? Is there an easy way to change it? |
danfromsyr Samba Member
Posted: Mon Jun 05, 2017 12:09 pm Post subject: Re: Shoreline |
Correct it does not charge the house battery.
you need to add an onboard battery charger/maintainer.
you can easily plug one into the 110v outlet under the sink and tie into the camper wiring at the isolation relay under the drivers seat.
KCvan wrote: |
When I plug the shoreline into power it does not charge the house battery. Is this normal? Is there an easy way to change it? |
Abscate wrote: |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Mon Jun 05, 2017 12:10 pm Post subject: Re: Shoreline |
There is no built in battery charger. The shore power connection just powers the outlet in the van and under the sink. You can buy a shore power battery charger and connect it under the sink as many people have done, then it will charge your batteries. _________________ 89 Westy 2.1 Auto |
maco70 Samba Member
Joined: March 16, 2011 Posts: 456 Location: Montréal, Québec
Posted: Mon Jun 05, 2017 6:21 pm Post subject: Re: Shore power line |
Iota DLS-55 with IQ4 smart charge was my choice, if it help. _________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
HoustonPhotog Samba Member
Joined: February 20, 2013 Posts: 1514 Location: Houston, TX
jimf909 Samba Member
Posted: Wed Jun 07, 2017 12:34 pm Post subject: Re: Shoreline |
PDXWesty wrote: |
There is no built in battery charger. The shore power connection just powers the outlet in the van and under the sink. You can buy a shore power battery charger and connect it under the sink as many people have done, then it will charge your batteries. |
Ditto. This makes it as simple as plugging in the van to keep batteries charged when it sits at home for a few days or weeks. _________________ - Jim
Abscate wrote: |
