Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Mon Apr 06, 2015 9:24 pm Post subject: |
Having mouseproofed my vanagon almost 5 years ago, I think the best advice is to defer the legends until later and for now study the photos of physically plugging holes with "metal screen" and "pot scrubbies".
1) & 2) below, are wide open on every vanagon, they are the basis for the urban legend. Once mice learn those paths, new campground mice can smell those who have gone that way before - thus locate the holes quickly.
At minimum, do 1&2 then you can pursue animal legendry in your leisure. If you do a good job plugging the holes you will get good results with your other methods too (except trapping which will be less fruitful).
1) screen the fresh air vent behind the radiator grille.
2) plug passenger and driver side battery box vents with stainless steel scrubbies.
3) check the large rubber seal at the engine ECU wiring loom and if seal is gone, repair it with silicone. And a large grommet for the headlights too.
4) I guess on some vans you need to look for rust holes too. A nightime helper inside with a bright light inside then crawl around outside looking for light.
My other vehicles have doors and windows, but mice don't come in. With kids, my other cars have a far, far more crumbs under the seats. Mice don't "jump in" the doors, thats just an assumption that spreads due to the defeatist chatter that muddies every vanagon mouse-problem thread. The desire to post home remedies is a deafening roar, especially in the Vanagon crowd. The poor vanagon owner will also need a remedy for his bleeding eyes.
I suppose mice would jump in if doors were left open for days, or years, or a blanket is hanging out, but your first line of defense is common sense: Plug the holes that every vanagon has (and other cars don't have). _________________
....KTMs, GasGas, SPOT mtb
Zeitgeist 13 Samba Member
Posted: Mon Apr 06, 2015 10:59 pm Post subject: |
Never underestimate the level and degree of sophistication in your local rodent pack. I'm quite sure the mices in my hood are all busy sipping schnapps and drafting the great American novel...clever little bastards _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Apr 07, 2015 4:57 am Post subject: |
In NY, mice will chew your wiring harness, string it between two points like a zip line, and use it to enter your vehicle as you get in to commute.
If you put peppermint in to repel them, you will get green mice.
Mice can and will chew through gaskets, wood, plastic to get a good place to whole up for winter. Its in the DNA.
Clean up food, plug holes, set traps if your car is in storage.
My EV sat in the driveway for one week, and one winter mice chewed my underhood soundproofing to nest in the engine compartment. _________________ .ssS! |
Sodo Samba Member
Posted: Tue Apr 07, 2015 10:51 am Post subject: |
Thanks to those who post photos and keep on TOPIC of locating and plugging the holes! _________________
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Sodo Samba Member
Posted: Tue Apr 07, 2015 11:49 am Post subject: |
Somewhat true, since a vanagon, in its proper setting, will sit for hours at a campsite with doors open. But plugging the holes makes a vanagon about as mouseproof as other cars, and members who have other cars are aware of how nice it is to have mice way way down on list of worries.
One thing about mice is that when there exists s mouse highway, all the other mice can smell it and follow thise who passed before. Plugging the holes solves about 90% of the problem. Most of the replies address only 10% of the problem due to the urban legend that a vanagon cant be mouseproofed. Asserting this legend is a disservice to the vanagon. This is NOT an unsolvable problem.
Mice are furtive. They choose pathways that are hidden and offer protection. I do NOT believe they jump in doors and windows. Certainly it has hapoened but choosing your actions based on banzai mice, is a waste of time, they just dont behave like that. If they get in your door is because you left a blanket hanging out or offered some other kind of mouse ladder.
New legend: Mouse Rapunzel.
However in my experience the mice came in at night, a couple hours later after the people stop moving.
Dave I thank you for posting pics, very helpful. I know how much time it takes to make an informative post and there are members who will be ever thankful. _________________
Posted: Tue Apr 07, 2015 2:37 pm Post subject: |
Well...... In the spirit of Identifying possible entry points, let's start at the front of the Van.
Here is the front door foot step area. There is a plastic pad that snaps into these holes..... No pad?
Highway to the interior is open!
My PO abandoned the "factory" drivers side antenna and installed an after market one on the Passenger side...... Look how nicely the wire seals to the body!
Mouse highway With a built in ladder to enter above the Glove box!
This is behind the LF headlamp but above and behind the fuse panel. All wires feeding the Fuse panel or leaving the fuse panel area enter and exit here.
Examine for loose or rotted grommets.........
Here is the interior side of the same wires above the fuse panel....
The "Factory" drivers antenna, abandoned by my PO but flopping around in the dash....... Easy entry for a rodent!
The interior view of the Antenna hole.....
Also Check ......
Front Heater Hose Grommets,
heater control valve wire.
Front door jamb wire boot
Rear heater hose grommets,
Rear heater fan wire entry grommet
EFI Computer wire Grommet
AC hose entry from engine area to cargo area,
AC wire Entry grommets
Rubber plugs in front of rear wheels into body (by lower suspension arm mount)
Missing seat belt bolts
Rust holes
PO made holes for all sorts of modifications, auxillary battery wiring, etc.
Ghia
Vanagon
Beetle
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Wed Apr 08, 2015 4:38 pm Post subject: |
Moderator Edit:
Moved this prevention tip to the prevention thread......
http://www.thesamba.com/vw/forum/viewtopic.php?p=7626414#7626414
This thread is focusing on preventing entry into the vehicle ....... not repelling or capturing them. _________________ D-Dubya Manx clone - 63 Short pan,1914.
addiction Samba Member
Joined: December 08, 2005 Posts: 18 Location: Northern California
Posted: Mon Apr 17, 2017 3:04 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
I scanned this thread and followed all the advice, but was still getting a mouse in the van almost every night. So I set up some trail cameras and when hunting, I found two new places that folks had not listed, see the video to see where they are
enjoy
https://youtu.be/bdgTZKyqMkI
Moderator edit: A screenshot of the above video showing the mouse squeezing through the automatic transmission shift linkage
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Apr 17, 2017 3:22 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
Nice use of technology to (hopefully) defeat the 'meeces'. |
Posted: Mon Apr 17, 2017 3:23 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
Half way through that video that mouse makes a two foot leap in mid stride. Anyone still think they can't jump in a door?
Keep your crashbar clean too, mouse love a good merlot _________________ .ssS! |
Merian Samba Member
Posted: Mon Apr 17, 2017 3:26 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
pics of how you sealed off the A/T shifter?? _________________ .... |
Posted: Mon Apr 17, 2017 3:38 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
Merian wrote: |
pics of how you sealed off the A/T shifter?? |
ah that is the challenge, I have not done it yet, I am going to stuff some SS scrunchies in it tonight and see if I can keep them out, and confirm that is the only entrance left.....either way I am thinking o f adding a rubber shifter boot on it and see who that works.
a little worried they will chew through it, if they do, I will fab up a small box to go around it....
when I get it solved I will post a picture |
blackglasspirate Samba Member
Posted: Tue Apr 18, 2017 11:02 am Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
addiction wrote: |
Merian wrote: |
I saw this thread pop up and was just about to post about this same spot. We had at least 6 mice get in through there this past year before plugging it up. Nearly lost my mind! I just stuffed enough steel wool up there to plug it without obstructing the linkage. I keep meaning to go back to it with a more elegant solution, but out of sight out of mind. _________________ '87 Vanagon GL Westfalia
IG: @holidayatsee
FB: https://www.facebook.com/holidayatsee |
Merian Samba Member
Posted: Tue Apr 18, 2017 12:10 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
mice will chew thru rubber, tape, etc. SS scrub pads will work much better
And to address a comment further back, of course mice will jump in the open door -- even "regular" mice can jump several body lengths, and this is no big deal because the forces of gravity are quantitatively different on animals with small body sizes (consider animals that land on the ceiling as a further example) _________________ .... |
Posted: Tue Apr 18, 2017 12:24 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
blackglasspirate wrote: |
I saw this thread pop up and was just about to post about this same spot. We had at least 6 mice get in through there this past year before plugging it up. Nearly lost my mind! I just stuffed enough steel wool up there to plug it without obstructing the linkage. I keep meaning to go back to it with a more elegant solution, but out of sight out of mind. |
Stainless Steel wool is my current fix as well, I am very happy to hear that it seems to have been a long term fix for you.
I also wanted to make sure everyone saw the second place where I found a yet to be documented opening.
to the left and right of where the rear seat would go, there is a opening where I put expanding foam. I opens right up to the rocker panel and is an easy highway for a mouse to get it. I have an arrow pointing to it at the 10s mark of the video |
Merian Samba Member
Posted: Tue Apr 18, 2017 1:41 pm Post subject: Re: PLUGGING THE HOLES to keep mice out of a Vanagon (mouse) |
to clarify - is that on a non-Westy? or would a Westy with the rear seat (Z-bed) have those holes also?
and... foam will help but mice can still dig thru it - or into it for nest material _________________ .... |
