Fococlimber Samba Member
Joined: September 24, 2009 Posts: 79 Location: Fort Collins, CO
Posted: Sat Sep 18, 2010 10:15 am Post subject: Engine Knock |
I just started up my Van for its regular run around the neighborhood to get her juices flowing and I noticed a "knock" I am assuming it is a piston.. I am just wondering what an average cost is to fix or refurbish the engine is.. really bumming me out right now.. _________________ 1984 Westfalia Vanagon GL Wolfsburg Edition |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Sat Sep 18, 2010 10:24 am Post subject: |
It could just be a hydraulic lifter that isn't fully pumped up. You may need to run it for 10-20 minutes for the lifter to quiet down. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Sat Sep 18, 2010 10:35 am Post subject: |
Kind of a long shot, but, check the water pump.
I recently ran into this on a friends van. Sounded just like a rod knock and turned out to be the water pump knocking! Never heard a water pump knock before but he was stoked!
It was alot cheaper than an engine rebuild. |
joeboxer428 Samba Member
Joined: December 23, 2009 Posts: 36 Location: Spokane, WA
Posted: Sat Sep 18, 2010 11:50 am Post subject: |
I had the same issue with mine after it had sat for a few weeks, and I added a bottle of SeaFoam to the crankcase and it quieted right up. There is a thread somewhere in TS about the use of SeaFoam... Most say to run it for 50-75 miles and then change the oil. Just a thought... _________________ ______________________
"Be the change you want to see in the world" -Gandhi
'83 Air-Cooled Westy "Frank" |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Sat Sep 18, 2010 12:57 pm Post subject: |
As noted, if you're lucky it may just be a lifter that needs to pump up and will quiet down in a few miles. Some add a dose of Marvel Mystery Oil to the crankcase to preclude this. I tried that and it seems to help. |
Zeitgeist 13 Samba Member
Posted: Sat Sep 18, 2010 1:09 pm Post subject: |
I'd place money on the bled down lifter theory. Mine sits for weeks on end, and always clatters incessantly upon initial start up. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sat Sep 18, 2010 3:08 pm Post subject: |
just ran it around for about 20 minutes and its still knocking, sounds like its coming from the block... _________________ 1984 Westfalia Vanagon GL Wolfsburg Edition |
Posted: Sat Sep 18, 2010 3:13 pm Post subject: |
If you rev it up, does the knocking sound mostly as you accelerate the engine, or when you let off the throttle? _________________ Casey--
y u rune klassik? |
Posted: Sat Sep 18, 2010 7:05 pm Post subject: |
oh it speeds up when i press the throttle.... in sync with the rpms.. _________________ 1984 Westfalia Vanagon GL Wolfsburg Edition |
buildyourown Samba Member
Posted: Sat Sep 18, 2010 7:16 pm Post subject: |
If your van has sat, and it just started, it's the lifters.
Relax, it will settle down.
Sometimes mine quite down after 5min, sometimes it takes 20-30. |
morymob Samba Member
Posted: Sun Sep 19, 2010 4:16 am Post subject: |
How long since an oil change, using a heavy weight oil? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Sep 19, 2010 6:36 am Post subject: |
Is this a polite little "tic-tic-tic" or a full bore "KNOCK-KNOCK-KNOCK" ...???
tic = lifters (yes, it'll go away)
KNOCK = TROUBLE (get it checked out!) _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
rotorimp Samba Member
Joined: June 18, 2007 Posts: 253 Location: Surprise AZ
Posted: Sun Sep 19, 2010 7:20 am Post subject: |
get a clean pan and change the oil--look for shiney flakes of metal |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sun Sep 19, 2010 7:32 am Post subject: |
dhaavers wrote: |
KNOCK = TROUBLE (get it checked out!) |
Good one, I was gonna ask the same thing
First a tick tick...which
Leads to a a knock knock...and
Turns into a bang bang. |
Posted: Sun Sep 19, 2010 8:23 am Post subject: |
rotorimp wrote: |
Like panning for gold dust -- only if you find it, it ain't gonna make you richer. |
Posted: Sun Sep 19, 2010 9:22 am Post subject: |
just changed the oil about a month ago myself with a heavier weight oil
it sounds like a KNOCK KNOCK KNOCK KNOCK
not TIC TIC TIC TIC
i will change the oil again and check for shiny flakes.. _________________ 1984 Westfalia Vanagon GL Wolfsburg Edition |
tencentlife Samba Member
Posted: Sun Sep 19, 2010 10:43 am Post subject: |
Check the crank endplay. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sun Sep 19, 2010 11:25 am Post subject: |
noise gone, thanks mike! _________________ 1984 Westfalia Vanagon GL Wolfsburg Edition |
sojournforchrist Samba Member
Posted: Sat Nov 06, 2010 9:30 am Post subject: |
nice!
I'm interested to hear how the noise left though and what did "mike" say to help? Is that the comment about crank endplay?
I have a knock as well and hope so solve it.
Thanks
---update---
I figured out that the little noise it wasnt an engine knock thankfully! I had bought some thinner oil by accident, and put it in the van. After a couple days i realized what I did and changed it out for the right stuff. All is well and working good.
I wonder if thinner oil will mess with the timing that much?
hmmm
Last edited by sojournforchrist on Sat Nov 27, 2010 9:34 am; edited 1 time in total |
Californio Samba Member
Posted: Sat Nov 06, 2010 11:37 am Post subject: |
As others have said, your noise is either lifters or something else. Lifters get drained of oil since the WBX has them horizontally mounted, and will make a tick tick tick noise for a long time after not running the engine for a while. You can try the various products mentioned--they work. For some theory on Vanagon lifters, go to
http://www.ratwell.com/technical/HydraulicLifters.html
If it isn't lifters, then it's something internal to the engine (expensive, not fun) or external, like a piece of sheet metal rattling around (unlikely.)
Try the lifter remedies first and don't take any long trips until you figure it out. |
