srfndoc Samba Member
Posted: Fri Sep 24, 2010 7:15 am Post subject: Spare tire in early bay single cab |
Does anyone have a photo of the spare tire under the front seat of a 68/69 single cab pickup? Mine didn't come with one and I"m curious how it mounts and if there is any hardware I'm missing to secure it.
Also, is it the same size as the other four? I'll need to pick one up so if you have a spare for sale, let me know (I'm in SoCal).
Thanks. |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Fri Sep 24, 2010 7:20 am Post subject: |
Great junjyard 760 244 9811 Hesperia Ca. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51148 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Sep 24, 2010 8:15 am Post subject: |
I don't have a pic but it's just another 5x205 14" bay bus wheel, it just sits in the well under the seat, no mounting or hardware required. The only challenge is shoving all the seatbelts to the middle of the seat so you can tip the outer end up enough to get the tire in or out _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 24, 2010 8:42 am Post subject: |
I guess that makes it easy. Seems like it will be a tight fit but we'll see.
Now to find a spare rim/tire! |
Posted: Fri Sep 24, 2010 9:20 am Post subject: |
One more question... is the stock rim from for a 68 bay 14x5.5? I found some 14x7 for sale but those sound too wide.
Edit: Looks like they are 5.5 wide - 5JK x 14 is apparently the exact code so I know those 14x7 won't work. |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Fri Sep 24, 2010 11:14 am Post subject: |
heres the one under the seat of my 69SC. as for rim you need to be measuring your rims bead to bead not to the outside edge. the stock 14 wide 5 bus wheels are 5 inch and the later small 5 hole are 5.5 inch.
_________________ where its cold and snowy |
Posted: Fri Sep 24, 2010 11:52 am Post subject: |
Bigbore... thanks for the picture as it really helps. I just picked up four 5 wide rims off a 69 bus with the stamping 5JK x 14 on them so I think I'm good to go. |
