Wipers - fuse blows
bugsy95
bugsy95 is offline
PostPosted: Sun Sep 26, 2010 5:53 pm    Post subject: Wipers - fuse blows Reply with quote
Every time I turn my wipers on the fuse blows.dave 1973 bus
VDubTech
VDubTech is offline
PostPosted: Sun Sep 26, 2010 6:14 pm    Post subject: Reply with quote
Comparatively, every time I turn on my wipers, they sweep across the glass. They then return to their original position. This is repeated over and over until I turn the switch off.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
maximan1
maximan1 is offline
PostPosted: Sun Sep 26, 2010 6:15 pm    Post subject: Reply with quote
Same thing happens with my '78. The wipers always blow the fuse in the same spot too (position on windshield, I mean). Apparently it is just the motor getting old and needing more current to power it. That was the explanation my dad gave me anyway.
If I put in a higher resistance fuse will it work and/or will it have any side effects on the rest of the electrical system?
1978 Transporter, 2.0L FI
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Sep 26, 2010 6:24 pm    Post subject: Reply with quote
Come on Max. You have been here long enough not to do something like that.
What do you think the problem is?
bugsy95
bugsy95 is offline
PostPosted: Sun Sep 26, 2010 6:26 pm    Post subject: ddd Reply with quote
My wipers did work fine until a few weeks ago. Maybe I will try a bigger fuse and see what happens. I did notice that the fuse will not blow until I start the engine.dave 1973 bus
hazetguy
hazetguy is offline
PostPosted: Sun Sep 26, 2010 6:38 pm    Post subject: Re: ddd Reply with quote
Brick wall why not just replace the fuse with a piece of 4 gauge wire. that should fix it right up.
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sun Sep 26, 2010 6:59 pm    Post subject: Re: ddd Reply with quote
Well, that clinches it. Stay home when it rains.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Sep 26, 2010 7:02 pm    Post subject: Reply with quote
why even consider using a heavier fuse than called for in the manual? Just pour gasoline on it and toss in a match.
Check the voltages up front to see if you are still getting 12V to the wiper motor. If you are then replace the motor.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
beefysal
beefysal is offline
PostPosted: Sun Sep 26, 2010 7:07 pm    Post subject: Reply with quote
Not sure why, but I haven't laughed that hard in a while
Klaussinator
Klaussinator is offline
PostPosted: Sun Sep 26, 2010 7:10 pm    Post subject: Reply with quote
Stopping or slowing at the same place on the glass means bent linkage under the dash or the wiper shafts are sticking in the bearings where they pass out thru the body. I'm sure if there's enough resistance to keep them from moving, it could certainly blow the fuse.
Mine were slowing and finally stopped, but I shut them off before the fuse blew. I suggest you check voltage like SG said, and if that's good, pull the wiper arms and clean and lube both shafts.
Been there, done that.
-Klauss
I have taken a vow of poverty. To annoy me, send money!
____________________________________________
the Klaussinator - `73 hardtop Bay custom-built camper
TRN9
TRN9 is offline
PostPosted: Sun Sep 26, 2010 7:14 pm    Post subject: Reply with quote
According to the Bentley- you should get one if you dont.
The Windshield wiper fuse is #10 counting from left to right and should be an 8 amp fuse.
'72 Panel ~ B-Bus
Camper Special Club Member
Desertbusman
Desertbusman is offline
PostPosted: Sun Sep 26, 2010 8:04 pm    Post subject: Reply with quote
Why would you think there is a problem with the motor? It's probably the mechanism that is messed up. Links, pivots, bearings, etc. There is a reason that wiper shaft assemblies are a common stocked item with parts suppliers. I had to go thru the whole mechanism when restoring my bug. The shaft assemblies were bad. A good way to burn up the motor.
71 Superbug
71 Westy
grandpa pete
grandpa pete is offline
PostPosted: Sun Sep 26, 2010 8:14 pm    Post subject: Reply with quote
had a 68 caddy for a year ...no wipers...used RAIN-X...could be a temporary fix untill u get the time and money to fix them correctley...PS parts wern,t as available for the caddy
1975 Kombi
1975 Kombi is offline
PostPosted: Sun Sep 26, 2010 8:47 pm    Post subject: Reply with quote
Pull the wiper assembly and disconnect the shafts from the motor and try to move the linkages by hand. They should glide through their range. If not you have to rebuild the transmissions or clean and lube them. They need to move freely. I have done many on the Rabbits and Jettas.
Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
WhirledTraveller
WhirledTraveller is offline
PostPosted: Sun Sep 26, 2010 8:56 pm    Post subject: Reply with quote
I just took the whole dang assembly out per the Bentley, took the shafts apart and re-greased them, lubed up the pivot points, even took the motor apart and cleaned and oiled. Wipers work great! Cost me nothing but time.
1977 Westy, Automatic. Big Valve heads, CS Cam.
Lil Lulu
Lil Lulu is offline
PostPosted: Sun Sep 26, 2010 9:09 pm    Post subject: Reply with quote
Rain-x is pupe. Like lubricatin' a rubber with barbecue sauce.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
john71westy
john71westy is offline
PostPosted: Mon Sep 27, 2010 7:44 am    Post subject: Reply with quote
I had the same problem(fuse blowing). One of the wiper shafts was seized. Removed it, cleaned it, greased it, installed it, no more fuse blowing.
bugsy95
bugsy95 is offline
PostPosted: Mon Sep 27, 2010 3:38 pm    Post subject: DDD Reply with quote
Yes I tried a bigger fuse, and now the bus went up in flames!! now what!!dave 1973 bus
Randy in Maine
PostPosted: Mon Sep 27, 2010 3:43 pm    Post subject: Re: DDD Reply with quote
I hope you are kidding us.....
bugsy95
bugsy95 is offline
PostPosted: Mon Sep 27, 2010 3:46 pm    Post subject: ddd Reply with quote
Just kidding randy! I am still trying to figure out why the fuse keeps blowing.dave 1973 bus
