Vdo Oil Sensor
Mrfun2fly
Mrfun2fly is offline
PostPosted: Mon Apr 28, 2025 7:10 pm    Post subject: Vdo Oil Sensor Reply with quote
Hey guys I thought my oil sending sensor was not grounded so I removed it to clean up all the Teflon tape that somebody put on. There was a long spring and only a couple drops of oil in there. Shouldn't this be pouring oil?
jeffrey8164
jeffrey8164 is offline
PostPosted: Wed Apr 30, 2025 2:03 pm    Post subject: Re: Vdo Oil Sensor Reply with quote
That doesn’t appear to be the stock location.
If it reaches to a pressurized galley it wouldn’t pour oil unless the engine is running.
The sender does need the engine case to provide ground, so you’re right to remove the Teflon.
Volkswagen!
(Compression 8.7:1)
