AndrewM Samba Member
Joined: February 18, 2002 Posts: 496 Location: Charlotte, NC
Posted: Thu May 02, 2002 12:09 am Post subject: old locking steering colum |
I found a locking steering colum in the remains of a chopped up bug. It has german writing on it. Something like GARAGE, FAHRT, And HALT. What kind of beetle came with this and is it worth anything? I can get it cheap and the old guy has the key. Thanks Andrew M Oh yeah, it also has the radio delete plate??? |
cbilek Samba Member
Joined: June 24, 2002 Posts: 14 Location: Garbage Grove, CA
Posted: Mon Jun 24, 2002 9:38 pm Post subject: old locking steering colum |
I have the very same thing on my 65 bug. The original owner picked up the bug in Germany, drove it around Europe on vacation, then shipped it home. I was told the lock was an option, maybe only something available in Europe. I don't know if this is true or not! |
troll77 Samba Member
Joined: July 03, 2008 Posts: 90 Location: victorville,california
Posted: Fri Oct 31, 2008 7:14 am Post subject: |
yes pick it up if it is cheap,and the key i have seen those sell for about $150.00 depending on how nice it is. |
mooks73 Samba Member
Joined: June 08, 2006 Posts: 422 Location: fontana ca
Posted: Fri Oct 31, 2008 8:06 am Post subject: |
most def, pick it up and that radio delete plate also. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
towd Samba Member
Posted: Fri Oct 31, 2008 9:20 am Post subject: |
In Germany theft was much worst than here ,,, " back then " it was common to see locks on the steering, shifter, glove box, hood pull ,, sun roof and engine.
If you get this ,, get the steering shaft also, That has a oval shaped hole in it for the lock.
the car I had with all this was 1947 and that was in germany.. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Fri Oct 31, 2008 9:29 am Post subject: |
The column tube and internal shaft are different for the locking type. Try to get it all or you will have to cut and weld parts (and you might not get it to work right if you are off a little bit). |
raempi Samba Member
Posted: Sat Feb 14, 2009 8:00 pm Post subject: Early locking column |
Does anyone know how to remove this thing?
I want to repair mine and get a key made, but the mounting screws don't have any head. I really would rather not drill them out to remove it. |
Posted: Sat Feb 14, 2009 8:07 pm Post subject: |
try and notch the heads with a thin chisel.then you can put a screw driver on it and turn it.thats how i did my buddies. |
KTPhil Samba Member
Posted: Sun Feb 15, 2009 11:42 am Post subject: |
The screws HAD a head; it was twisted off as part of normal installation, for anti-theft reasons. You might be able to go at them from on top, but likely you have to drill them out. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Sun Feb 15, 2009 1:20 pm Post subject: |
I've got some reverse-rotation drill bits that I've used on that sort of thing before. You have to have a steady hand but often times after you've drilled into it a while, the vibration and the drill bit applying reverse torque and catching in the hole it is drilling will pop the fastener loose and unscrew it. If it doesn't you just drill the old head out and pop it off.
-Andy |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Feb 15, 2009 2:00 pm Post subject: head vs. noggin |
X2- but spray those bolts with PBnJ well in advance- I finally had to resort to utter bug destruction removing one from a wrecking yard once... _________________
EverettB wrote: |
FU#5 |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Sun Feb 15, 2009 3:37 pm Post subject: |
Wolfsburg West sells the "sheer bolts" so you can return it back to a "factory" installation. _________________ Justin |
hitest Samba Member
Posted: Sun Feb 15, 2009 4:53 pm Post subject: sheer vs. oh deer |
And let me tell you- that is something you don't want snapping off prematurely- make sure the column is mighty snug whilst snugging the new shear bolts... _________________
EverettB wrote: |
FU#5 |
