Californio Samba Member
Posted: Wed Sep 29, 2010 1:53 pm Post subject: Fabricate onboard generator using Honda GX-25? |
We do a lot of solo camping in our Syncro, often way out in the middle of nowhere, and I'm always thinking of emergency solutions if and when we get stuck on top of a mountain someplace. I've been thinking about making a generator out of a tiny Honda GX-25 engine mounted to the old spare tire clamshell (my spare is on the rear lid) and connected (with a piece of heater hose?) directly to a 12v 90 amp alternator. This would provide power for the Propex in the event the batteries wore down.
The Honda is rated at 80+ decibels, so for sure not for campground use.
The one I really want, the Honda EU1000 (59dB), is way too high to fit in there. By contrast, the GX-25 engine is only about 9" tall, probably less without the gas tank. So it could be permanently installed under there. A long piece of metal tube connected to a t before the fuel pump would supply gas. To use, just drop the clamshell and pull the starter.
Anybody done something like this? Any reason it wouldn't work? |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Wed Sep 29, 2010 2:53 pm Post subject: |
I belive 90amp needs about 3hp . |
madspaniard Samba Member
Posted: Wed Sep 29, 2010 3:15 pm Post subject: |
a great idea in concept but if you get stuck there is also a chance you will run out of gas eventually, why not go the renewable energy route? a 135w solar panel coupled with nice aux battery will serve as well. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Wed Sep 29, 2010 3:17 pm Post subject: |
Maybe so, looks like the 1000 w generator uses a 50cc motor as opposed to the GX-25cc.
Back to drawing board. Smaller alternator maybe. |
Posted: Wed Sep 29, 2010 3:20 pm Post subject: |
Only problem with solar is when there isn't any/enough sun. As in winter camping at night. Yes fuel is an issue but these engines would run full throttle for a week on 5 gallons of gas. They're tiny. |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Wed Sep 29, 2010 4:21 pm Post subject: |
Why spin an alternator? Why don't you just use a 110 generator and feed your outlets with a charger connected? _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Posted: Wed Sep 29, 2010 4:30 pm Post subject: |
There's only about 10" between the clamshell and the shifter box, IIRC. The usual generators are higher than that. I'd like it to be permanently mounted so the boyz in the hood don't steal it. Where else to put it? The Honda EU1000's are way too big for example. |
buildyourown Samba Member
Posted: Wed Sep 29, 2010 4:40 pm Post subject: |
I would look at your power requirements and decide what your goal really is. A good sized house battery will keep a Propex going for a long time. Maybe look at just adding battery capacity. It will be useful all the time (vs only in emergencies). It will also be silent, cheaper, and easier.
If your goal is to stay warm for a week in the winter, propane and a battery will solve that problem. If you are looking to stay alive if your car breaks down, a down sleeping bag will do the job. |
andy syncro-nutz Samba Member
Joined: August 22, 2010 Posts: 539 Location: Upper Ottawa Valley
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Thu Sep 30, 2010 8:49 am Post subject: |
http://gardenequipmentreview.com/blog/post/12-Volt-Mini-Generator.aspx
That's pretty cool, but I normally just idle my engine for 40 minutes to charge my batteries. I usually want a generator to provide 120v ac so that I can run other higher powered 120v things. That's pretty sweet though! _________________ 89 Westy 2.1 Auto |
Posted: Thu Sep 30, 2010 8:59 am Post subject: |
Yeah, I guess its all down to many factors and persoal requirements. |
Posted: Thu Sep 30, 2010 9:02 am Post subject: |
That's it! Way more ambitious size-wise than my idea, but the same basic notion. I wonder what he does about the exhaust. |
Posted: Thu Sep 30, 2010 9:08 am Post subject: |
The only problem with idling to recharge is the gas usage. I'm talking about an emergency device that could save your butt in the snow for a week. RIP James Kim...hard to forget that story. |
Posted: Thu Sep 30, 2010 9:09 am Post subject: |
I'm sure he just stores it in the battery box and takes it out for use. _________________ 89 Westy 2.1 Auto |
TheBusBarn Samba Member
Posted: Thu Sep 30, 2010 9:11 am Post subject: |
why dont you just get the EU1000i, I have a set of them (EU200i's) in tandem and they can power my whole trailer. You could just carry it as cargo, and then pull it out and run it aside your van and run your shore power to it. Or, you could do a Jerry can rack off the rear end for a rack solution. These are amazing little machines and you can run em anywhere.
Posted: Thu Sep 30, 2010 9:12 am Post subject: |
Californio wrote: |
I think it is intended to run outside and away from the van, Email John and ask, He's a really nice guy and good costomer |
Posted: Thu Sep 30, 2010 9:18 am Post subject: |
Why not get the EU1000? It's too big (17" tall IIRC) to fit into the clamshell. Yes I could stick it on the roof rack but in my neighborhood it wouldn't be there the next morning. Where else to store it? NOT inside the van...
I want something permanently mounted so the enterprising young lads around here can't walk away with it.
The EU1000 would be my first choice except for the size. |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Thu Sep 30, 2010 10:20 am Post subject: |
Californio wrote: |
This is an interesting thread, no doubt.. A couple great ideas for small generators.. But I am wondering how a generator is going to help you much in surviving a week in the snow?
What use is electricity when your car is stuck? It can not provide much heat and you can not eat or drink it.
There is one device that will save your butt if truly stuck out in the wilderness.. and that is an EPIRB 406 beacon.. The type of beacon used offshore and in back country trekking.
The Kim family story is tragic, no doubt.. But some basic survival skills and tools would have helped them much more than an electricity generator.
In the Kim's case, they drove up the wrong road in a building snow storm.. a road whose gate should have been locked... Given the weather forecast they should have never even headed up that county road.
Communications/beacon, a gps, a weather radio, emergency rations and some sleeping bags would be a wiser plan.
I say go for it on the generator idea... but please make sure you have the basics for survival covered, too. And for gawd's sake.. don't go driving into a snow covered unmaintained road at the out-set of a winter storm. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Posted: Thu Sep 30, 2010 11:18 am Post subject: |
I usually go out with 10 days + of food, full water tank, 6 gals of propane, three house batteries aside from the starter battery, down bag, and a few bottles of my favorite zinfandel. The latter, to greet rescuers when and if they arrive.
But a generator that would run for a week or so on a few gallons of gas would supply heat and light way beyond what the batteries can do, esp. in cold weather.
The Kim story is pretty extreme but it illustrates to all us city boys how nature doesn't f..k around. Easy to forget when you aren't out there.
I was up in the Sierras a couple years ago, early December, me and the dog, way back on a snowy road in Toyaibe Nat Forest, 11* at night. A day later back home the throttle cable broke. Coulda stranded me up there. Us I should say. |
GBA 88West LA Samba Member
Joined: September 04, 2008 Posts: 1279 Location: New Hampshire
Posted: Thu Sep 30, 2010 11:29 am Post subject: |
if you have electricity you have heat if equipped w/ portable heater. _________________ 88 Westy GL Vanaru 07 2.5 EJ25/AA Trans/oiling plates, 1.14 3rd-.77-4th..solar powered cabin |
