vertdrvr50 Samba Member
Joined: February 10, 2005 Posts: 80 Location: San Diego, Ca
Posted: Wed Sep 29, 2010 2:59 pm Post subject: Do I need cooling flaps |
I'm not finding much info on the cooling flaps and thermostat for my 1600. Maybe a dumb question. Do I need the cooling flaps under the doghouse and the thermostat? |
Randy in Maine Samba Member
Posted: Wed Sep 29, 2010 3:02 pm Post subject: |
Depends on if you intend to actually drive it.
Show cars (that are not driven) really don't need anything.
The rest of us need all of that stuff installed correctly. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Wed Sep 29, 2010 3:05 pm Post subject: |
It depends if you want your engine to last as long as the engineers designed it to last.
It will run for years but it will wear quicker and take longer to warmup.
If they weren't needed, they would of left them off at the factory. _________________ Glenn
Member #1009
#BlueSquare |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
Posted: Wed Sep 29, 2010 9:23 pm Post subject: Do I need cooling flaps |
Thanks for the replys. I knew it was a dumb question and thanks for making sure I knew. I have trouble finding any refrence to the equipment. I will find them. |
scrapmetalvw Samba Member
Posted: Thu Sep 30, 2010 4:21 am Post subject: |
Yeah great idea till they fail and close up and over heat your motor. I always take mine off when I have the motor out and have never had a problem. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Thu Sep 30, 2010 4:27 am Post subject: |
scrapmetalvw wrote: |
Yeah great idea till they fail and close up and over heat your motor. . |
parrots say this all the time... Poly, I gotta ask ya, how many times have you had an engine overheat due to a failed thermostat? Hell, how many times have you heard of it happening? Stop spreading "urban legends" _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin
Glenn Mr. 010
Posted: Thu Sep 30, 2010 4:28 am Post subject: |
Yeah great idea till they fail and close up and over heat your motor. |
Not true when you use the original style thermostat. They fail in the open mode. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 30, 2010 4:49 am Post subject: |
Glenn wrote: |
Not true when you use the original style thermostat. They fail in the open mode. |
Really they NEVER stick closed? I hope you are right, for his sake. |
Posted: Thu Sep 30, 2010 5:10 am Post subject: |
it's amazing how folks can be talked into fearing something that rarely, if ever, happens, but they still get into that car and drive down the road disregarding the very real fact that driving a motor vehicls is dangerous... _________________
GEX has. Just sayin |
Glenn Mr. 010
Posted: Thu Sep 30, 2010 5:18 am Post subject: |
Glenn wrote: |
I bet there was one set of the tens of millions that VW produced that jammed in the closed position. But the OE thermostat fails OPEN. There's also a return spring that by default pulls them open.
My proof is all the stock VWs still on the road that have not cooled their engines. Show me one engine that overheated due to the thermostat failing and closing the flaps.
My proof is the 470,000 miles i've personally driven without a problem. Or the hundreds of other VWs i've worked on that had the flaps and never reported a problem.
Just show me one, that's all I ask.
Oh and just to be clear, i'm talking about the original OE thermostat, not the crappy Mexican one. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 30, 2010 5:35 am Post subject: |
Glenn wrote: |
Glenn wrote: |
Oh and just to be clear, i'm talking about the original OE thermostat, not the crappy Mexican one. |
My experiance is, I have never had a problem in all my miles I driven. Never ran the OG Therm. Never had a problem and all my heaters have been great.
Glenn what color are the OG VW ones just so i know what to look for, thanks. |
Frankie Pintado Samba Member
Joined: April 02, 2008 Posts: 372 Location: Lake of the Woods, VA
Posted: Thu Sep 30, 2010 7:36 am Post subject: |
I agree, I've seen a hand full of failures, all open. _________________ 1972 Karmann Ghia, 1985 Vanagon GL, 1989 Cabriolet |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Thu Sep 30, 2010 7:54 am Post subject: |
Note in the picture of this T-3 engine, that the cooling shutters are wide open.
Here is the thermostat.
The design worked like it should. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Glenn Mr. 010
Posted: Thu Sep 30, 2010 7:59 am Post subject: |
Here's a OG thermostat.
There's plenty of them in the classified. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 30, 2010 8:09 am Post subject: |
BTW, there is a specific length bolt that attaches the thermostat to the bracket. Too long a bolt can damage the thermostat. It is about 2/3 the length of a clutch bolt. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Glenn Mr. 010
Posted: Thu Sep 30, 2010 8:34 am Post subject: |
Russ Wolfe wrote: |
BTW, there is a specific length bolt that attaches the thermostat to the bracket. Too long a bolt can damage the thermostat. It is about 2/3 the length of a clutch bolt. |
It's M8x15 _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 30, 2010 8:41 am Post subject: |
Yes, that would be about right. I did not take the time to look it up in the parts book. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Sep 30, 2010 10:49 am Post subject: |
Glenn wrote: |
Glenn: Do you mean the "crappy Brazilian one"? from 1973 to 1995 Volkswagen of Mexico installed only thermostats made in Germany, the "new style" thermostats for sale in shops like Cip1 are made in Brazil. _________________ Parts VW
"From Volkswagen of Mexico factory..."
Genuine VW Sedan parts
Genuine VW Ultima Edition parts
Genuine VW Type 2 watercooled parts |
