vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Wed Oct 13, 2010 7:00 am Post subject: |
volksguy wrote: |
AL's headers Makes the Scat, CB Performance, AND Kymco headers, amongs other shop (that i wont mention) that claim that they make them in house. |
Mine came from CB.
volksguy wrote: |
Maybe , just a thought, but what size engine did you try to put this 1 3/8 header on? Thats a small header, and if fitted onto a wide stroker engine, i can see how it would be short, since its probably not supposed to extend to the sides that far. Maybe your engine is wide? |
69mm stroke. 1641 but 100% aftermarket. Hip Roof Case, scat heads, and so on. Yes it could be wider BUT, in test fitting and clamping to a straight surface for checking, I found that #4,#1,#2 fit just fine. #3 headed off into the wild blue yonder. I don't think it was a width issue or wider engine problem. The collector, when header finally could bolt on, headed drastically to the right. It may have been purposely that way because the only effect would be the muffler tucks under the car more. My problem with that was , what if I wanted run a stinger on Saturday night. The exhaust would have blown the skirts up on the pedestrians walking on the sidewalk.
volksguy wrote: |
Just out of curiosity, how come you went from 1 3/4" all the way down to 1 3/8" ? Thats a huge difference. |
I got the (A1) 1-3/4 because it looked so damn good and was labeled as "lowdown" designed to clear rear apron. It was (according to the samba pro's) way too big for a small 1641. Also HotVWs article on HP said the CB 1-3/8 merged added a small amount of magic to the small engine they tested. I read the article and saw AL's logo but my brain read A1. I honestly thought I was buying A1.
volksguy wrote: |
Also, the dents on the muffler, doesnt that end up under the apron/fender where it wont be seen?
If the muffler was to have been welded fliped around, you would have that ugly seam where the muffler shell is joined together, and personally, i think that seam would look ugly showing out the rear of the car. |
Your right, body does cover it and the seam has to be hidden to look good. Muffler is fine the way it is. I might also make an adapter flange spacer to mount other brands of mufflers in the future.
Final word, AL's is great. I just think I got a reject or a repaired one or maybe just a fluke. |
mark tucker Samba Member
Posted: Wed Oct 13, 2010 7:22 am Post subject: |
I use the all stainless muffler.it,s shiney.!!!and retains the heat like ceramic. |
Posted: Wed Oct 13, 2010 7:27 am Post subject: |
I think the baja collector with the down turn would of looked better, but it wont unbolt to run a stinger.he should probably give that option for the street headers that wont use a stinger. cleaner looking and no gasket. |
Posted: Sun Oct 31, 2010 9:41 pm Post subject: |
Just an update. The header is now all sanded down and ready for coating. I go to the coaters in the morning with a truck load of other goodies. I will show you guys how it turns out.
Posted: Mon Nov 01, 2010 6:54 am Post subject: |
mark tucker wrote: |
not a abja header, but just a baja style collector with the ubend to go to the mufflerbuilt on to the collector, it's much cleaner looking then a pair of welded on flanges, and would flow better. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Mon Nov 01, 2010 8:07 am Post subject: |
vaughn bros. wrote: |
Lowdown is the one that fits under the apron. Be carefull of that promise with a merged, all cars are a bit different. Motor mounts can even affect it.
Heres the 1-3/4 Ceramic A1 I just took off. Come to the Farmington bash and get it dirt cheap. For now I'm having to stick to my modified AL's 1-3/8.
I would have bought this at the Farmington show had it NOT been bashed-in heavily,for clearance on the top And bottom of the collector. Before you posted this pic, you should have removed the yellow rag that is coving up the dents in it. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Posted: Mon Nov 01, 2010 9:08 am Post subject: |
When I sold it for $100.00, I told the guy that they were strategic adjustment impressions. |
Posted: Mon Nov 01, 2010 11:35 am Post subject: |
I thought the price was $50.00? |
Posted: Mon Nov 01, 2010 11:45 am Post subject: |
I got lucky. |
Posted: Mon Nov 01, 2010 12:18 pm Post subject: |
I got lucky. |
I better not read too much into that one.
havent seen your cars in a while ,whats new??( I been bussy worken on the house) |
Posted: Thu Nov 11, 2010 10:13 am Post subject: |
The last update. Got the header back from the coaters today. Damn I feel good now.
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Thu Nov 11, 2010 10:16 am Post subject: |
Looks sweet! I'm jealous of your sunshine though (it's a few degrees above freezing, cloudy and damp here in Vancouver). _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Posted: Thu Nov 11, 2010 10:26 am Post subject: |
have you used those guys before for coating? howmuch? Ive used airborne coatings in NC. havent had any problem with thier coating on my 4 wheeler. we used to send the race car stuff from the speed shop to jet hot, but I dont like them, looks like squat & dont last real long. where are the guys locate that you used? |
Posted: Thu Nov 11, 2010 11:36 am Post subject: |
$125.00 - about 8 days. I told them no rush. Yeah we have used them before. They are perfect. They also offer koolkrome.
Posted: Thu Nov 11, 2010 1:49 pm Post subject: |
how long have you seen thier coatings last?? |
