instrument cluster - dangling foil connector
dabaron
dabaron is offline
PostPosted: Wed Sep 19, 2018 5:09 am    Post subject: instrument cluster - dangling foil connector Reply with quote
It appears at some point the instrument cluster has been fiddled with... I'm guessing the speedometer was replaced with that of an older Vanagon. The foil connector that connects to the back of the speedometer on some clusters is just dangling.
1. I have no idea how many miles are on my Vanagon - this is not cool.
2. When was this speedometer used in Vanagons?
3. Is it worth trying to find a different speedometer?
1990 Vanagon GL
mdege
mdege is offline
PostPosted: Wed Sep 19, 2018 5:51 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
Looks like someone tampered with the dynamic oil pressure circuit. Maybe the buzzer was going off all of the time. I would check the oil pressure switches, the cabling in the engine compartment and reconnect the connector to the pins of the little pcb under the speedo.
- Michael
Restoration of a former '65 firetruck (21F)
[url=http://www.vw-mplate.com/mplate2-46747.png]Click to view image[/URL]
1983 Jetta C Diesel (daily driver)
1988 Multivan Magnum 112i
1965 21F
dabaron
dabaron is offline
PostPosted: Wed Sep 19, 2018 5:53 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
the speedo does not have a connector... thus the reason this a dangling.
1990 Vanagon GL
mdege
mdege is offline
PostPosted: Wed Sep 19, 2018 6:10 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
This is what your speedo should look like:
Someone must have replaced it with an earlier/different version.
- Michael
1965 21F
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Sep 19, 2018 7:07 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
With that unplugged your van has NO OIL LIGHT unless someone did something else to allow the oil light to still function.
You should make sure you have a working oil warning light.
Mark
dabaron
dabaron is offline
PostPosted: Wed Sep 19, 2018 8:45 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
The face of the speedometer is labelled 805 so i know it's not from a syncro - it appears to be an 83-85 model since it lacks the oil pressure circuit connector.
1990 Vanagon GL
crazyvwvanman
PostPosted: Wed Sep 19, 2018 8:56 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
That is a speedo from an older van.
Mark
dabaron
dabaron is offline
PostPosted: Wed Sep 19, 2018 9:18 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
Mark
yeah, that's what i figured. i'll check to see if the oil light comes on with the key... i suspect it does not.
1990 Vanagon GL
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Wed Sep 19, 2018 11:59 am    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
that is a speedo from an air cooled van.
all speedos are clearly date stamped. i can almost make it out in the bottom pic in the OP.
you should get the right one and have a functioning oil pressure warning system.
71 Bus - 71 Ghia - 86 Van - 88 Van - 87 Syncro Adventurewagon
BAY PRIDE
VAN MAN
dabaron
dabaron is offline
PostPosted: Wed Sep 19, 2018 2:50 pm    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
No oil light on key on... drat
1990 Vanagon GL
AZ Landshaper
AZ Landshaper is offline
PostPosted: Wed Sep 19, 2018 3:43 pm    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
Older vans had a screw on speedometer. My 81 had a screw on speedo and my current 85 has the same version you show (push on). I bought a newer one a few months back but was never able to make it work. Between the diff speedo connector and the buzzer and the rearranged 14pin it was too much work for very little bang.
Ive never seen brown foil. Is that even a bus connector?
Its a slow ride. Take it easy
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug.
crazyvwvanman
PostPosted: Wed Sep 19, 2018 3:59 pm    Post subject: Re: instrument cluster - dangling foil connector Reply with quote
85 vans don't need the wires on the 14 pin moved for later clusters or any tach cluster to work.
80-84 use one 14 pin layout.
85-91 use another 14 pin layout.
84 Wolfy vans came with a tach and use the 85+ 14 pin layout.
86+ 14 pin uses an extra wire for a 2nd oil switch, simple to work around if needed.
Different year tachs sometimes don't work with other year vans, the tachs have different electronics in them.
The brown foil is just the back side of the blue foil.
Mark
