Batan Samba Member
Joined: March 10, 2003 Posts: 1637 Location: Vancouver, BC
Posted: Mon Apr 08, 2013 4:38 pm Post subject: |
obnoxiousblue wrote: |
Done
Nice! Do you know what size are the nylock nuts? I want to change mine as well. I have the Euromax one and it too will set off the horn sometimes if the bus is stationary. I can tell it's bending too much. So, I'm changing it. I thought I might as well switch away from cotter pins, they are a pain to get in there. _________________ '69 Riviera Bay
'03 20th Anniversary GTI
'74 Super Beetle
Badzak Creative – Still and Motion Pictures |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2942 Location: East Northport, NY
Posted: Mon Apr 08, 2013 5:05 pm Post subject: |
Yup, they're M8, on 30mm 1.25 bolts. I bought stainless steel, grade 8. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Mon Apr 08, 2013 5:40 pm Post subject: |
hey mike, you forgot to screw down the steering column cover to the floor. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Posted: Mon Apr 08, 2013 5:41 pm Post subject: |
Yeah, I caught that.
Thanks for the keen eye! _________________ Mike
1964 Beetle
Posted: Mon Apr 08, 2013 6:16 pm Post subject: |
got a wise arse quota to fill _________________ [email protected]
Batan Samba Member
Posted: Mon Apr 08, 2013 6:19 pm Post subject: |
Yup, they're M8, on 30mm 1.25 bolts. I bought stainless steel, grade 8. |
Great, thanks! _________________ '69 Riviera Bay
'74 Super Beetle
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Fri May 17, 2013 10:49 am Post subject: |
I picked up this "German" coupler from a local parts house today. They said the brand was German when I asked them on the phone. It has the HARD rubber feel to it, and a VW logo, but it's also got an elephant logo stamped in to it. I've never seen this logo before. Anyone seen one of these?
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
larryducas Samba Member
Joined: October 25, 2011 Posts: 233 Location: Fallbrook, CA
Posted: Fri May 17, 2013 11:20 am Post subject: |
looks like the right one. looks like mine. I don't remember if mine had the elephant. _________________ 71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb |
Islero Samba Member
Posted: Fri May 17, 2013 1:54 pm Post subject: |
asiab3 wrote: |
It must be some german rubber manufacturer, I have seen it in some water hoses and rubber parts of my '81 BMW too
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1397 Location: Arizona
Posted: Fri May 17, 2013 3:00 pm Post subject: |
Islero wrote: |
asiab3 wrote: |
It must be some german rubber manufacturer, I have seen it in some water hoses and rubber parts of my '81 BMW too |
How about that. Learn something new here everyday. Maybe Scott at German Supply will chime in. I'm betting he knows. _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours? |
Posted: Sat May 18, 2013 9:18 am Post subject: |
Thanks so much Islero!
I'm glad I checked- the local shop I got it from tries to stock good stuff... But sometimes.... I'll let y'all know if there are any issues with this one. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Thu Jun 06, 2013 1:09 am Post subject: Replacing Steering Coupling Disc 211415417 (coupler) |
A new development? Every time I work on the underside of my bus, I peel factory undercoating off. The bus has 90k documented miles, with DMV records and receipts. (Parked in a barn unregistered from 19484-2008ish.)
When I peeled the waxy gunk off the castellated nuts and cotter pins, I was cussing at finding a way to get a wrench on the upper bolts. The lower ones were no problem using the "clutch pedal hold down" technique. I did not want to f'up my #14 plastic clip, so I didn't even open the driver door to access anything. I eventually got a 13mm wrench on each, and did the deed this way:
Can't see it in this pic. But there is a ground wire that connects from the steering box flange bolt to the steering shaft bolt for the horn.
Tools required, start to finish:
But what have we here
The elephant logo on my disc, which SHOULD be the factory coupler! It's not in the worse shape, but when I saw this thread I checked mine and did see one crack. It's WAY worse when I bent it. Anybody think the Elephant Group was an OG supplier, or do you think my bus got a dealership coating after a steering coupler replacement??
Edited 9/8/15
Tcash _________________ Learn how your vintage VW works. And why it doesn't!
curtis4085 Samba Member
Posted: Thu Jun 06, 2013 7:20 am Post subject: |
That's got to be original. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
dgizzle2 Samba Member
Joined: February 03, 2005 Posts: 129 Location: kingsport,tennessee
Posted: Mon Jun 22, 2015 6:26 pm Post subject: |
I should of done some research before I put my steering coupler on I bought a rebuilt box from wolf gang and I ordered the coupling and I told him to give me the best one he had so when I got it I didn't think to bend it or anything so anyways I put it all together and drive about 20 miles and turn into a parking lot and it broke In half! The coupler says "kafer" on it and has the same part number as the og one above so just beware of the cheap ones. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jun 22, 2015 6:37 pm Post subject: |
asiab3 wrote: |
... Anybody think the Elephant Group was an OG supplier ...
Beer Chang
Aloha
tp |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Jun 23, 2015 3:55 am Post subject: |
The cheap aftermarket ones are easily identifiable by bending them. If they fold trash it. The good ones will not bend and have reinforced innards in the rubber. Cracking is not necessarily indicative of failure. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
1970fun Samba Member
Posted: Tue Jun 23, 2015 4:19 am Post subject: |
asiab3 wrote: |
This is a OG part and they were made by the Metzeler gummiwerke in Munchen.
https://de.wikipedia.org/wiki/Metzeler |
Patrick Metsker Samba Member
Joined: February 15, 2005 Posts: 112 Location: Indiana
Posted: Tue Sep 08, 2015 6:41 pm Post subject: Re: Steering Coupling Disc |
It seems there is a washer on the top, between the coupler & steering shaft?
is that what I'm seeing there?
Mine had no washers, but my coupler is cracked & I broke it while removing it. |
Posted: Tue Sep 08, 2015 8:10 pm Post subject: Re: Steering Coupling Disc |
Patrick Metsker wrote: |
I've seen buses with and without; the bus parts book does not show them.
HOWEVER, if you use the castellated nuts with the cotter pins, you MUST use washers under the nuts. Without them, the nuts will be too drawn on to the bolts and the cotter pin will not index with the nut enough to lock it properly. _________________ Learn how your vintage VW works. And why it doesn't!
