Brian Samba Moderator
Posted: Tue Sep 08, 2015 8:20 pm Post subject: |
Damn Robbo, your coupler was almost as bad as mine.
Washers on everything man, they distribute the force. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Patrick Metsker Samba Member
Joined: February 15, 2005 Posts: 112 Location: Indiana
Posted: Tue Sep 08, 2015 8:22 pm Post subject: |
Brian wrote: |
Washers on everything man, they distribute the force. |
so why then only 2 on top, and none below?
mine were not castle nuts, on a 78.
I never saw any washers above or below listed on any diagram.
I won't worry about them then |
Tcash Samba Member
Posted: Tue Sep 08, 2015 9:54 pm Post subject: |
that's odd,
one link you provided shows a washer,
the other link you provided doesn't..
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/4-018.jpg
what would the 2 bolts be for?
it seems if they go 'under the steering shaft', wouldn't that bend the coupler down on those two sides?
any idea what the part # is, if I were to need these washers? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Sep 08, 2015 9:55 pm Post subject: |
Patrick Metsker wrote: |
Uhh, last time I checked, they're just M8 washers. Again, thickness is important if you use the castellated nut/cotter pin setup like the early quality buses did. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Tcash Samba Member
Posted: Tue Sep 08, 2015 10:43 pm Post subject: |
Posted: Tue Sep 08, 2015 11:07 pm Post subject: |
thank you for the help.
"the new guy" |
1967250s Samba Member
Posted: Wed Sep 09, 2015 12:00 am Post subject: |
Bolts should ALWAYS have a washer under the head, and according to everything I've seen on a VW, a spring washer under the nut to both lock the nut and spread out the force. Remember that all these rubber pieces are over 30 yers old now. _________________ '72 Elm Green Deluxe |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Wed Sep 09, 2015 9:15 am Post subject: |
one of my steering shaft tabs is bent a good deal.
think this is cause for concern?
should I heat it & bend it back, or just leave as is?
Tcash Samba Member
Posted: Wed Sep 09, 2015 9:38 am Post subject: |
Put a crescent wrench on it and bend it back. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Thu Aug 25, 2016 6:06 am Post subject: |
1970fun wrote: |
This is a OG part and they were made by the Metzeler gummiwerke in Munchen.
Good catch!
Metzeler is well known in the motorcycle world for tires and inner tubes, especially among BMW motorcycle riders. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Fri Sep 02, 2016 8:06 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Can anyone suggest a current source for the best quality coupler available?
German Supply is out of stock as is WW. Bus Depot lists the Euromax version.
It seems the WagenWerks part has performed well for the OP of this thread, but curious if there are other options currently?
Thanks _________________ '78 Westy - 2.0 FI |
Tcash Samba Member
Posted: Fri Sep 02, 2016 2:19 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
THall wrote: |
Can anyone suggest a current source for the best quality coupler available? |
Vintage Parts in Santa Clarita CA (my home town!) sells over the phone only. They had the "elephant" coupler last time I was there.
Vintage Parts
25011 West Ave. Stanford
Unit C
Valencia, CA 91355
Info (661) 295-3927
Fax (661) 295-3928
Order By Phone
(800) 898-VNTG (8684) _________________ Learn how your vintage VW works. And why it doesn't!
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Sep 02, 2016 7:11 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
if you zoom in you can see the vw logo on it, but I can't seem to tell f that is the elephant on the right side of it or not. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Tcash Samba Member
Posted: Fri Sep 02, 2016 7:37 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
TomWesty wrote: |
if you zoom in you can see the vw logo on it, but I can't seem to tell f that is the elephant on the right side of it or not. |
Ya I seen that, thank you. I am worried they changed the part but did not change the
picture.
Guess I will call on Tuesday and see if I can get someone to put a hand on it, to confirm it is VW.
Thank you
Tcash |
SGKent Samba Member
Posted: Fri Sep 02, 2016 9:02 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I got some generic ones a couple years back that were from Europe and were supposed to be genuine VW. When I finally found a genuine VW one it was a perfect match for the generic ones and the the grind mark on the generic ones was where the VW logo was on the genuine one.
I found an old thread from 2011 and someone had really good luck with the Wolfsburg West ones. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Sat Sep 03, 2016 12:37 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
SGKent wrote: |
I found an old thread from 2011 and someone had really good luck with the Wolfsburg West ones. |
Here is mine from WW purchased in October 2013. Looks like they carry the other version pictured earlier in this thread (the one with fibrous edges) now though.
_________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Tcash Samba Member
Posted: Sat Sep 03, 2016 8:13 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
The bonded rubber fiber joint like WW list (out of stock), is the one's I remember seeing in the old days.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211415417
With the composition of rubber now days. I am going to see if I can source a urethane coupler.
Thank you
Tcash |
