Steering Coupling Disc 211415417 (coupler)
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
captincanuck
captincanuck is offline
PostPosted: Tue Sep 20, 2016 10:31 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Thanks for the tips. I bought the only on Bus Depot listed. It was the "Premium Quality" on. It is to soft and easily distorted. Ordered two "OE Quality" ones from CIP1 today.
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
Hoody
Hoody is offline
PostPosted: Tue Sep 20, 2016 10:53 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Until we publicly call these purveyors of Chinese Garbage out they will still sell these parts to the masses. It's a real shame that the market has gone in this direction. I am hopeful that things may go in the other direction now that the "cheap" VW owners are being weeded out. But I am not going to hold my breath.
sixer
sixer is offline
PostPosted: Tue Nov 01, 2016 3:58 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Does anyone have a source for these at the moment? Cip1, WW, bughaus, German Supply, all list the acceptable units as out of stock. My original looks to be in pretty rough shape and I have a road trip coming up in a few weeks... any leads appreciated. Thanks!
1976 Transporter, Stock 2.0L
http://instagram.com/sixer.bus/
Hoody
Hoody is offline
PostPosted: Tue Nov 01, 2016 4:27 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
ECS Tuning shows genuine VW for 44.00. If they say it's genuine then it is.
mikedjames
mikedjames is offline
PostPosted: Wed Nov 02, 2016 12:00 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I have read of people managing to drive with the coupler in pieces - the bolts and inserts manage to interfere with each enough to provide steering without the rubber ....
You still have two crude forks interlocking with each other,.
I am glad I was able to buy a VW marked coupler five years ago and fit it and it is still good.
The couplers punched out of sheets of fabric reinforced rubber remind me a bit of somebody getting creative with a square of rubber cut out of a large tire, or an inflatable ship's fender or conveyer belt ..
Ancient vehicles and vessels
1974 VW T2 : Devon Eurovette camper with 1641 T1 engine, Progressive carb, full flow oil cooler.
static
static is offline
PostPosted: Wed Nov 23, 2016 8:29 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I just ordered what appears to be a "real" one from Custom & Commercial.
https://www.customandcommercial.com/vw-baywindow/b...68-79_673/
Like VW campers? Join us!
https://www.facebook.com/groups/2362239654/
tristessa
tristessa is offline
PostPosted: Wed Nov 23, 2016 5:18 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Looking forward to the report on this -- mine is still OK-ish but needs replacement at some point.
HelmutofBuffalo
HelmutofBuffalo is offline
PostPosted: Fri Nov 25, 2016 8:14 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I had the same problems described here with the Euromax coupler sold at BD, massive twisting under load and horn blowing or completely tearing wire off. Called them and explained the problem, after trying two of theirs (and solution...fiber bonded is much stiffer) yet it seams they are still selling the junk part until they run out Mad . Thanks to WW for getting me the correct one !
1970 Westfalia,
BayCreamPuff
BayCreamPuff is offline
PostPosted: Sun Nov 27, 2016 4:15 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Out of curiosity I just ordered one from http://www.ebay.co.uk/itm/221534063811
Looks like it might be the right material. I'll let you know when it gets here. About $28 shipped total.
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 Stock 2.1 Westfalia
BayCreamPuff
PostPosted: Sat Dec 03, 2016 10:13 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
It arrived. Not as solid as the ones I got from cip1 that are now out of stock.
This one bends a bit, not sure how it compares to some of the others that bend.
Cream Puff
Earl Grey
Amskeptic
Amskeptic is offline
PostPosted: Sat Dec 03, 2016 11:51 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
BayCreamPuff wrote:
It arrived.
It is supposed to bend in the horizontal plane. It has to overcome any slight misalignment between the box and the steering shaft, and perhaps give a you an option of a little more steering (if you are still trying) after the hideous front impact.
This coupler is not really a high-demand moment in the realm of material science.
Colin
www.itinerant-air-cooled.com
alman72
alman72 is offline
PostPosted: Sat Dec 03, 2016 12:12 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
^ holy crap! it looks like all the plasticizer is bleeding out on that part. not sure what kind of lifetime you could expect with that.
Amskeptic
PostPosted: Sat Dec 03, 2016 12:14 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I think ? that may be glycerine.
Colin
static
static is offline
PostPosted: Sat Dec 03, 2016 7:26 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Received my spiffy new steering coupler from Custom and Commercial in the UK.
Appears to be the real thing. I cannot flex it as shown in the photos above (though I will readily admit that I am a weakling)
Cost? A helluva lot.
24.99 UK pounds + 21.22 UK pounds postage = 46.21 or US$58.12
static
static is offline
PostPosted: Sat Dec 17, 2016 11:41 am    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Success! My bus drives again and now it doesn't scare the crap out of me in turns.
Driving down to The Kombi Haus before the repair was very scary; I was weaving all over the road. ("the road" being Hwy 50 through Sacramento during the morning commute).
The mechanic was quite astonished that I had managed to make it there without crashing. (yes, I know, I should have had it towed in)
Apparently, the steering coupler thingie was only held together with two bolts.
And yes, the shop approved of that (pictured above) "inobtanium" OEM part.
Thanks again to The Kombi Haus! My steering is like new!
BayCreamPuff
PostPosted: Mon Jan 02, 2017 7:06 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Finally got around to replacing my coupler with the CIP1 I got a while back. It looked okay from below, but I could hear it flexing when turning the wheel. Once I took the cover off the top I could see it was torn pretty badly in 2 places. As expected it was the dreaded "PREMIUM QUALITY" coupler.
Used M8-1.25x40 Cap Nut Screws Grade 10.9. Partially threaded. HD washers on top, spring washers on the bottom with nylock nuts. Screws are a little long, but worked fine.
Cream Puff
Earl Grey
vwwestyman
vwwestyman is offline
PostPosted: Sun Feb 26, 2017 1:05 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
I just put in a request for a quotation for total order from Custom and Commercial as others have stated that these are supposed to be very nice. We shall see.
I did notice that the pic still shows a VW logo but the text states they are a very nice aftermarked part.
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
Santos
Santos is offline
PostPosted: Wed Mar 01, 2017 3:34 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
By any chance, is there a company out there that might offer a polyurethane version of this coupler? In fact, would that have any advantage? I've previously driven lowered cars where a variety of bushings and spacers were swapped out with polyurethane rather than rubber replacements.
I use to take the bus to school.
vwwestyman
PostPosted: Wed Mar 01, 2017 6:10 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
Seems that was discussed somewhere in this thread and nobody knew of a Bus one, and someone reported seeing a broken one on a Type 1-based car. Also postulated that it would transmit a lot of vibrations up the steering column and be unpleasant.
Dave Cook
1973 Wild Westerner
My Thing
lil-jinx Premium Member
lil-jinx is offline
PostPosted: Wed Mar 01, 2017 7:10 pm    Post subject: Re: Steering Coupling Disc 211415417 (coupler) Reply with quote
If you were to put a metal strap with one slightly oversize hole over one of those bolt ends and secured it with slightly loose lock nuts,and the other end tight on the other bolt,the rubber flex joint would still flex and if it failed you would not loose control.use 2 straps one on each set of bolts.
1968 Dune Buggy
1974 parts bus
Page 7 of 13
