TRN9 Samba Member
Joined: September 29, 2006 Posts: 309 Location: Where its rainy
Posted: Wed May 12, 2021 10:02 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
airschooled wrote: |
They're also a "local" business, owned by real VW people that put on a casual meetup every week in the SF Valley. Good people to support these days!
https://daftenclassic.com/ |
Purchased from them and what arrived is a kafer brand coupler. Now my horn blows because of the metal mesh in the coupler. Here is a link to a thread where others have had the same problem. Page 3 of thread. https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
Any ideas how to insulate the coupler from grounding out the horn circuit? Or am I simply using plastic washers and putting tape on the bolts? _________________ '72 Panel ~ B-Bus
Camper Special Club Member
rayroc Samba Member
Posted: Thu May 13, 2021 8:12 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I just got this german made one on ebay seems like the real deal
https://www.ebay.com/itm/372563061171 |
Zeta Samba Member
Posted: Thu May 13, 2021 8:42 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
rayroc - have you had time to install it? If so, any issues as described in other posts regarding conductivity and affecting the horn? If you have not installed it yet, do you mind giving us an update if you experience same issue as others with other brands?
Thanks,
Z _________________ -----------
1974 Westy
1800 cc Type4 Engine
Single Weber Carb |
rayroc Samba Member
Posted: Thu May 13, 2021 4:47 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I will definitely follow up
Did you happen to read the lengthy description of the coupler it really goes into detail regarding the differences between an good and inferior one. You might want to email them with any questions about it I'm sure maybe they could explain what causes the issue with other brands |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu May 13, 2021 9:21 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
That seems to be the same one being sold by Richard Davies, see p. 16 or so in this thread.
One has to ask why there's a counterfeit VW logo on that label? The one I got from Davies had that
exact same label, except in English, and the logo had been marked out. The images match exactly with
the one I got from Davies also. One also has to ask why there are no mfr. markings on the coupler.
Is it really "made in Germany"? Why should anyone believe that it is, with all the other hanky-panky
being associated with that coupler? That said, my test of the one I got (related earlier in this thread)
showed no evidence of conductivity, so it should be of interest to those with the early bays where
that matters. _________________ '67 bug: seized by the authorities
TRN9 Samba Member
Posted: Sat May 15, 2021 6:10 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
TRN9 wrote: |
Any ideas how to insulate the coupler from grounding out the horn circuit? Or am I simply using plastic washers and putting tape on the bolts? |
I was WRONG! The coupler is not at fault. My turn signal switch/ housing was grounding out the circuit.
Horn now works! Now to figure out why my tach moves when you honk the horn... but that’s a different thread. Carry on my coupler reading friends. _________________ '72 Panel ~ B-Bus
sherpa7200 Samba Member
Joined: January 09, 2010 Posts: 43 Location: Stanford, CA
Posted: Sun Jul 11, 2021 8:59 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Here is a look at the sheer stress on one of these poorly made reproduction steering couplings. It was installed with a rebuilt steering box about 900 miles ago. At first I didn't notice but the coupling must have stretched and become increasingly malleable over time. This is getting changed as soon as I get my hands on a decent one.
https://youtu.be/pWNEJ8VN5o8 _________________ 1978 Westfalia |
airschooled Air-Schooled
Posted: Sun Jul 11, 2021 9:12 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
sherpa7200 wrote: |
Shit, where did you buy that one? Got any close-up pics? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
raygreenwood Samba Member
Posted: Sun Jul 11, 2021 10:39 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Not a "shear stress" issue. Its just made with a rubber that has too high of a coefficient
of elasticity......too much elongation.
This is why I keep saying....that the vast majority of seat of the pants specifications being stated for this part....are just that.....seat of the pants.
You can buy a part like this.....and have it pass the holy grail test of not being easily "foldable" in the hand (whose hand....how long were the fingers....how powerful were the muscles....see what Im saying?).....and still have the rubber used in the part....have excessive elongation like the one in this video.
You can have the correct elongation.....but have incorrect durometer (too hard)....and most likely pass the fold test but not shear apart on impact....because the density is too high.
You can have correct durometer on the surface...but have excessively low or high durometer on the inside core (density imparted by molding pressure).
And.....who knows how much of this is actually important for the part function....as long as it not sloppy soft like that part.
It would be nice to find the original design spec. And no.....you cannot measure a 40 year old NOS part and discover the spec. Rubber changes over time.
Ray |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Jul 11, 2021 10:48 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
raygreenwood wrote: |
Ray |
And would the original design spec even translate to today’s processes, materials and specs? _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
SGKent Samba Member
Posted: Sun Jul 11, 2021 12:04 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Richard Davies sold me one and it worked well. This was when he owned OeVeeDub. I bought two, they were identical in every way except one had the logo ground off. The part is supposed to allow some flex, if you aren't rolling or the tires are old and low on air pressure it will flex more than new properly inflated tires that are rolling. Over the years one will find that VW factory ones were made by more than one manufacturer. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Joined: January 01, 2007 Posts: 16885 Location: sticksville, ct.
Posted: Thu Dec 16, 2021 1:12 pm Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
i bought a shitload of these in about 2016, like 250 bux worth from a couple different vendors, one being CIP1 who were out of stock for a long time.
rolled the dice and bought 2 more on a recent order. they will be going back.
dude on the phone was nice enough, but "never heard of an issue and they are made in germany"
no, the stamp says that but clearly they are chinese.
i don't need any, i have more than enough for my fleet but like to have a couple kicking around for other buses that wander in here.
WW couplers are junk too, customer had one i was going to put in. didn't bother to take it out of the bag.
WW actually called me, but same deal "never had a problem" and the guy on the phone said the ones he had he could fold like a fucking hot dog bun. no refund was offered from WW
i'm at a point now where i'm going full asshole and shoving these shitty parts up vendors asses. if they refuse a RA i'll do a chargeback with my CC. fuck em. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
VWLover77 Samba Member
Joined: June 20, 2003 Posts: 999 Location: North Canton, Ohio
Posted: Fri Feb 04, 2022 6:24 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Has anyone found a decent source for these recently? All I can find are the junk ones mentioned in this thread.
I'm about ready to buy a used one from The Bus Co! It's not great, but it's better than what I have and at least it's OE VW! _________________ Don
1978 Westy
1971 Super Beetle Convertible
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." - J.R.R. Tolkien |
Abscate Samba Member
Posted: Fri Feb 04, 2022 6:51 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I would not worry too much about the crash protection aspect of this part. In a pathological crash where the steering column gets upward force and skewers you, that would be between you and the creator, she probably already has tattooed a bull’s-eye on your back if you look in the mirror. _________________ .ssS! |
Posted: Fri Feb 04, 2022 7:19 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
I'm not worried about crash protection at all. I'm worried about steering issues should the cracks in the current coupling cause it to fail. _________________ Don
1978 Westy
GS Samba Member
Joined: October 16, 2018 Posts: 21 Location: Middelburg, Netherlands
Posted: Fri Feb 04, 2022 9:46 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
VWLover77 wrote: |
I'm about ready to buy a used one from The Bus Co! It's not great, but it's better than what I have and at least it's OE VW! |
I bought this one last year and it’s great, only downside is the
shipping outside of europe.
https://bus-ok.nl/Hardy-schijf-T2-211415417 _________________ 1971 Baywindow westy m-plate
1972 Bug |
Posted: Fri Feb 04, 2022 9:50 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
VWLover77 wrote: |
I've been casually looking and haven't found anything. I would like to have 3-4 more for others that may need them.
CIP did take them back.
I have not had a chance yet, but it may be worth reaching out to FCP Euro. IF you do that make sure to track down Brian. he was my counterman when their brick and mortar store was 10 mins from me.
they DO sell good ones:
https://www.fcpeuro.com/products/vw-steering-shaft-flex-coupling-disc-corteco-251419417b
i can tell you that was 100% the real deal.
perhaps he can reach out to the mfgr and see if they offer it for the bus _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Feb 04, 2022 10:01 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
skills@eurocarsplus wrote: |
VWLover77 wrote: |
perhaps he can reach out to the mfgr and see if they offer it for the bus |
I pretty sure that is the brand I picked up for my bay. It seems to be the real deal. |
SGKent Samba Member
Posted: Fri Feb 04, 2022 10:29 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
Richard Davies (OeVeeDub) helped me out here with some good original ones but last time he tried to help folks here, a member here with a big batch of his own he was trying to sell for $$$ flamed him so I think he is completely soured on getting them for us. Jeff at BusOK tries to sell things that are the equal of NOS or are NOS. He is in Europe however so postage is a but more. I don't know about FCP. The one in their image looks like it is made by SGF in Germany. The ones Richard had were genuine VW. That said, here is a post from another thread. Notice the VW emblem on one side, and SGF on the other.
Dead 1 wrote: |
Just received my new NOS coupler. 😁
here is a link to the image at FCP
https://www.fcpeuro.com/public/assets/products/312...1554238216 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Feb 04, 2022 11:40 am Post subject: Re: Steering Coupling Disc 211415417 (coupler) |
SGKent wrote: |
I don't know about FCP. The one in their image looks like it is made by SGF in Germany. |
to clear things up the link i posted was for vanagon, and they were SGF. those couplers fit bugs/ghia/everything but a bus.
those were the real deal and as i recall, the VW logo was shaved off.
that said, it may be worth a call to FCP. the one they list for a bus is the "jopex" brand as i recall.
i've done business with Richard on a recommendation from SGKent and couldn't be happier. it may be worth reaching out to him as well.
to be honest, this really and truly is one of those parts that will literally park your bus forever. it's a must have part and must be made properly.
so if you find one, fuck the price. if it's 100 bux it is what is... either that or park the bus.
the soft ones are 100% junk and straight up unsafe _________________
Jake Raby wrote: |
Brian wrote: |
