easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
twurts Samba Member
Joined: September 30, 2016 Posts: 11 Location: Chester Springs PA
Posted: Wed Jan 18, 2017 10:15 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Thank you all for the very useful and helpful guidance. |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Fri Feb 10, 2017 9:01 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Maybe said before... sorry.
Going stock height again in my 67 westy.
Want to go Big nut trans, prefereably a 67 one that has longer to gear ratio (am I correct?).
I'm having troubles in finding one locally (Spain).
Will a Brazilian Split bus transmission work? Opinions?
Thanks in advance
Xavi _________________ 1967 Split SO-42 Dormobile |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Feb 10, 2017 9:38 am Post subject: Re: How to keep a Bus stock and all stock height questions |
xavi_242 wrote: |
Is the transaxle in question brand new from the factory? If not it could have been rebuilt since new with any gearing.
There are places that will rebuild a transaxle for you with lots of gearing choices you can go with. Any VW 1961-72 tunnel transaxle case will do for a core. You can even go with non-stock for that era of transaxle case with 3.875 or 3.44 R&P for higher geared and higher MPH. _________________ In Stereo, Where Available! |
grizpdx Samba Member
Posted: Mon Mar 20, 2017 2:21 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Found this helpful.
rennie Samba Member
Joined: October 06, 2016 Posts: 246 Location: Orange County, CA
Posted: Thu Oct 05, 2017 3:05 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
I'm in the process of using online tire calculators to determine how tall of a tire I can get (to increase MPH a little bit) while still being able to get under my tilt up garage door.
When folks speak of tire height or 'Average Height" (as in above table), does it mean diameter with weight on wheels, or is it the approximate tire diameter on the rim, but off of the bus? |
Posted: Thu Oct 05, 2017 3:22 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Pretty sure "average height" means among the tire manufactures the average size is... Just like some tires have more of a balloon shape to the sidewalls and some less, so one could figure out the average between them for total width.
Tallest/widest tire depends on the rear wheel wells in question.
1. 1955-early 62 a 205/75R15 is about as big as you can go.
2. Later 1962 thru 67 with the ribbed rear wheel wells you can get as big as 235/75R15.
3. Cut out wheel wells you can go bigger if willing to offset the rims enough. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Thu Oct 05, 2017 4:10 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
rennie wrote: |
I have an original Bus Continental spare tire.
It's loose - no rim, not on Bus.
I measured the circumference and it matched what is listed in the VW Bus shop manual.
So my understanding is it's the tire, unloaded. _________________ How to Post Photos
rennie Samba Member
Posted: Thu Oct 05, 2017 6:57 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Thanks, E&B and EB. I too was thinking it's likely an 'unloaded' measurement as various weight loads would surely create a differing height. |
rennie Samba Member
Posted: Thu Oct 12, 2017 4:59 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Jacked up the bus yesterday and the P185/75 14's measure 1/2" taller at 24.5 than when all the EZ Camper bus weight is on them.
Seems my tilt up garage may fit an LT205/75 14, though perhaps LT's have a stiffer sidewall and less height loss when loaded. If that's true, the 205's may be too tall.
I realize it's a nominal difference but has anyone experimented with height on the same bus (same size tires and air pressure) but differing tire ratings of P vs. LT? |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Thu Oct 12, 2017 6:09 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
rennie wrote: |
I've been running Yokohama Y356 LT 195/75 14's on my 67' camper and they're a HUGE improvement over the P rated tires I had on there before I knew better. 8 ply rated sidewall, load range D. The bus handles so much better with the right tires. _________________ Brandon |
rennie Samba Member
Posted: Thu Oct 12, 2017 9:19 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
oakman wrote: |
I've been running Yokohama Y356 LT 195/75 14's on my 67' camper and they're a HUGE improvement over the P rated tires I had on there before I knew better. 8 ply rated sidewall, load range D. The bus handles so much better with the right tires. |
Good to hear. I've seen those mentioned in threads. At your convenience, could you share the loaded tire height on that bus? |
oakman Samba Member
Posted: Thu Oct 12, 2017 10:02 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
rennie wrote: |
oakman wrote: |
Looks to be just above 25" from ground to top of loaded front tire laying a small level flat across the tread. Tire has about 35 psi. _________________ Brandon |
rennie Samba Member
Posted: Fri Oct 13, 2017 7:14 am Post subject: Re: How to keep a Bus stock and all stock height questions |
oakman wrote: |
rennie wrote: |
oakman wrote: |
Looks to be just above 25" from ground to top of loaded front tire laying a small level flat across the tread. Tire has about 35 psi. |
Thanks very much oakman - really helpful to know this! |
Posted: Wed Dec 06, 2017 5:54 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Went to stock height some weeks ago...
Super happy with my new bus! _________________ 1967 Split SO-42 Dormobile |
derRHDmeister Samba Member
Posted: Wed Dec 06, 2017 7:28 am Post subject: Re: How to keep a Bus stock and all stock height questions |
xavi_242 wrote: |
Super happy with my new bus! |
love the tires! where did you get them. I see they are for 14" wheels _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote: |
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt. |
Check us out @
Instagram: DeafVolks & BarndoorBuggy |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Jan 09, 2018 4:07 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
xavi_242 wrote: |
Sexy Beast! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
oakman Samba Member
Posted: Fri Jan 12, 2018 2:39 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Those tires look great on your bus. What size are they? _________________ Brandon |
