xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Mon Jan 22, 2018 3:20 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
oakman wrote: |
Those tires look great on your bus. What size are they? |
185R14 _________________ 1967 Split SO-42 Dormobile |
mark-s Samba Member
Posted: Tue Jan 30, 2018 12:41 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
xavi_242 wrote: |
Went to stock height some weeks ago...
Super happy with my new bus! |
I don't know if it's a maturity thing (AKA getting old), but I think this looks a million times better than any lowered bus. I love everything about your bus! I'm even going to check if yellow lenses are legal in the UK! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20268 Location: Sandpoint, ID
Posted: Tue Jan 30, 2018 7:11 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
mark-s wrote: |
I like 'em low and high, but I agree that bus looks fantastic. _________________ nothing |
mykillcykill Samba Member
Joined: March 06, 2012 Posts: 50 Location: LOs Angeles
Posted: Fri Jun 15, 2018 12:41 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Recently bought Hankook Optimo H724 in 205/75/15 I'm very happy with them and they were under $60 each. I balanced with Dynabeads, my freeway drive has never been smoother. |
der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
Posted: Wed Jun 27, 2018 8:55 am Post subject: Re: How to keep a Bus stock and all stock height questions |
So I recently changed out the lowered suspension for stock. The trans I traded for did not have any gear oil in it so I will need to fill it up. How much gear oil do I put in the reduction boxes? _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Strictly Vintage 2s |
EverettB Administrator
Joined: April 11, 2000 Posts: 69804 Location: Phoenix Metro
Posted: Wed Jun 27, 2018 9:16 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Thanks Everett. I tried searching but didn't see that thread. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Posted: Wed Jun 27, 2018 4:00 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
so I have another question.
Does anyone have a picture of the clip that bolts to the backing plate that keeps the e-brake cable tube in place? I tried searching the gallery and didn't see a picture of this setup. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Posted: Wed Jun 27, 2018 5:11 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
der58SC wrote: |
Does anyone have a picture of the clip that bolts to the backing plate that keeps the e-brake cable tube in place? I tried searching the gallery and didn't see a picture of this setup. |
Do you just need to know what that clamp looks like, or do you need a shot of it in place? _________________ nothing |
Posted: Wed Jun 27, 2018 5:14 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
These are for small nut boxes according to the info with the gallery photo.
Posted: Wed Jun 27, 2018 5:17 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Here is a shot of them installed.
Posted: Wed Jun 27, 2018 5:19 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Big nut clamps are pretty much the same, but they may be slightly different. Not sure on that. Beetle clamps look nearly the same, too. Experts, please chime in and school us. More knowledge is good. _________________ nothing |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 27, 2018 6:20 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
You can also do a search of just the split bus forum. Tried "E brake cable" and checked the "Titles Only" box to keep the results down to an easy to go thru amount.
Got this among others:
https://www.thesamba.com/vw/forum/viewtopic.php?t=656985&highlight=brake+cables _________________ In Stereo, Where Available! |
Posted: Wed Jun 27, 2018 10:30 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
cdennisg wrote: |
der58SC wrote: |
Do you just need to know what that clamp looks like, or do you need a shot of it in place? |
Thanks. I was more interested in what they look like at the fingers that hod the tube. Also seeing how the are installed from the other side would be nice too since I am concerned that the cable will rub inside the drum. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Eastside78 Samba Member
Posted: Mon Aug 06, 2018 12:23 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
Hi guys, happy to be in your thread. After passing 40 and finishing a 3 year resto, I`m tired of lowered buses..
Just want to take my family of 5 out for some cruises and camping. Lowered just don’t work for that.
Todays set-up on my 59´camper is:
Engine: Stock AS 1600 engine (dual port, 50 HP)
Front suspension:
CE adjustable beam
Flipped spindles
Rear suspension:
IRS conversion from an early bay, chassis legs from CE
AH Gearbox from 1500 beetle (final ratio 4.125)
Adjustable spring plates
Will try to raise the front beam to max and se how high it will be, (how close to stock) before I eventually swap to my stock beam (have that in the garage)
Questions to you is:
Can I let my IRS conversion stay? (Will I be able to raise it enough?)
Will my AH gearbox work fine with my engine and tires as close to stock size as possible? (6.40X15)
Pics of the lowered bus:
mark-s Samba Member
Posted: Mon Aug 06, 2018 12:59 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
I have a very similar setup and have just gone back to stock height. You can keep the CE IRS setup, but you might have to swap the adjustable spring plates for stock early bay ones, I'm not sure you'll get enough angle.
You'll definitely need to change the gearbox output flanges and fit off-road type 4 CV joints and boots. The flanges are VW Trekker (or Thing as you call it over there), the CV joints are from CSP in Germany, but I think they're the same as the EMPI off-road ones that most places sell. They have a max operating angle of 25 degrees, my axles are sitting at 17 degrees.
I'm guessing you have the CE shock mounts? I had to change to the standard type (non-lowered) mounts which makes the rear eye-to-eye shock measurement 370mm which is the same as an early bay.
For the front I switched back to standard spindles and used the beam adjusters to get the height the same as the rear.
Tyres are Hankook Vantra 185r14.
Posted: Mon Aug 06, 2018 1:42 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
mark-s wrote: |
Tyres are Hankook Vantra 185r14. |
Thanks for good information and many tips. Good to hear that I can keep the IRS.
Is there the CSP CV joints with "long travel" you mean? https://www.csp-shop.com/en/rear-axle/cv-joint-501-331-211hd-27087b.html
This will only fit my stub axl, I run Beetle CV joints inner at the gear box.
Do you mean I need to swap the flange to make a Type 2 CV joint fit also inner?
I can see CSP also sell Type 1 CV joints with long travel, maybe this can be used instead of changing the flanges.. https://www.csp-shop.com/en/rear-axle/cv-joint-501-331-113hd-29716b.html
Yes, I run CE rear shock mounts, but the stock ones is still there (thank god!)
Unfortunately do I need a set of stock spindles. I swapped mine with a fresh rebuild set (flipped) from Type2 Detectives. (does a set of flipped lower as much as 3,5"?) |
mark-s Samba Member
Posted: Mon Aug 06, 2018 2:07 pm Post subject: Re: How to keep a Bus stock and all stock height questions |
https://www.csp-shop.com/en/rear-axle/heavy-duty-j...1533588488
They are the flanges you need if you want to use the type 2 long travel CV joints.
You might be able to keep your flanges and use bug CVs, but I wouldn't risk it, swapping then is an easy job. You could email CSP and ask what the maximum angle is.
You can't use the original upper shock mounts unfortunately, they don't line up with the bay hub.
Looks like you'll have to get some new standard spindles, dropped spindles lower the front by 3.5". Nothing is cheap if you want to do it properly!
I assumed you were in the USA, but it looks like you're in Europe? |
Posted: Tue Aug 07, 2018 12:36 am Post subject: Re: How to keep a Bus stock and all stock height questions |
Thanks again Mark!
My spare stock beam off course has stock spindles, I totally forgot. Just need to get them re-packed. (I kept a complete stock suspension after selling my 56" SC, and got another one with this bus). Has two split case RGB and one beam laying behind the garage
And yes I'm in Europe:
Some parts to be ordered before starting I guess.. $$$ |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Tue Aug 07, 2018 3:54 am Post subject: Re: How to keep a Bus stock and all stock height questions |
I'm running my bus with IRS and on original height. CV joints are Thing type.
The driveshafts might be too short, due to the angle, they need for that height. I have spacers between the flanges and CV joints.
My workshop guy that did several similar conversions before told me, there is no chance with beetle CV joints, they don't allow the angle that is needed. |
