Monster8724 Samba Member
Joined: November 22, 2016 Posts: 1 Location: Tucson,Az
Posted: Tue Nov 22, 2016 3:21 pm Post subject: Re: Engine Builds / Combos |
vugbug68 wrote: |
My friends 1968cc (I picked the combo)
Late dual relief case, factory savers, 8mm studs
CB 74mm crank
AA thick wall 92 "B" pistons / cylinders
AA 5.5 rods
CB 2243 cam
CB straight cut gears
German flywheel, 8 dowell lightened to 13lbs
CB Los Panchitos (pretty much out of the box, chambers @ 56 cc)
1.1 rockers on CB solid shafts, CB chromoly pushrods
New EMPI HPMX 44's
1-1/2" sidewinder
8.8:1 compression |
Nice build, pretty close to the 1915cc I have in the works.
Has your buddy done any dyno pulls? |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Thu Dec 08, 2016 10:19 pm Post subject: Re: Engine Builds / Combos |
Monster8724 wrote: |
vugbug68 wrote: |
CB 74mm crank
AA 5.5 rods
CB 2243 cam
New EMPI HPMX 44's
1-1/2" sidewinder
8.8:1 compression |
No dyno yet, It is plenty of power for his 66 bug with the 4.37 R&P and smaller tires, It revs really fast too. I'd guess about 130 hp _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Fri Dec 09, 2016 12:21 pm Post subject: Re: Engine Builds / Combos |
My mild 2007cc
C25 cam
1,1:1 solid Scat rockers
044 heads with 3 angle valvejob. (Came with a shitty seat job from CB)
IDF 40 copies, with 32 venturies
SVDA dizzy
78mm crank (Whole rotating assembly balansed)
Scat conrods 137mm (5,396"?)
Forged B-pistons
26mm oil pump fullflowed through HP-3001 oil filter. (8 micron filtration)
All in a brand new Alu case from Auto Linea.
CSP Python exhaust
JPM valve covers
Stock cooling tin + flaps and thermostat. Sandblasted and painted. Fan shroud massaged and welded to fit the carbs.
KEP stage 1
Fuelfilter is moved to the electric fuel pump next to the trans.
Result; an almost vibration free powerful monster that pulls like a tractor from 1000 rpm. |
Eoin Samba Member
Posted: Mon Dec 19, 2016 4:16 pm Post subject: Re: Engine Builds / Combos |
Type 4 2056 in a '72 Westy Camper. This is the original Type 4 1700 cc that was bored to 1911 cc and then stroked to get 2056 cc. Outline spec:
96 mm bore x 71 mm stroke
9:1 CR
Ported 1800 heads heads 41 x 34 valves
Eurorace C cam, 270 degrees x 0.425" lift
40 mm IDF pattern throttle bodies with multi point injectors
TPS
CSP manifolds, match ported
CSP bell crank linkage
The Dub Shop loom and crank fired ignition
Megasquirt 2
Cylinder head and ambient temperature sensors
Oxygen sensor
Stock heat exchangers & exhaust
228 mm clutch
Uprated oil pump
Remote underside oil cooler with thermostatic plate
The dyno run was part of what was supposed to be a final setup of the map on the rolling road after I had street tuned it for a couple of thousand miles first. After the dyno run, I re-did a lot of the map on the road. It is noticeable on the road that the torque comes in around 3,000 rpm, but it's certainly not gutless below that. It pulls hard to the red line and has seen an indicated 85 on level road. 0 - 60 time (full camping interior) using the data logger is 15.35 seconds, still in 3rd gear (longer FD) at just under 5,000 rpm.
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Fri Aug 11, 2017 10:24 pm Post subject: Re: Engine Builds / Combos |
2276
Cb 82mm crank
94mm AA pistons grant rings
SLR XR310 cam with SLR treated lifters
Cb 1.4 rockers
Cb chromoly pushrods
Straight cut cam gear from CB...very quiet by the way
CB super pro heads 44 x 37.5
Brazilian mag case
CB Hbeam rods
Dual Dellorto 45's
Bugpack 1 5/8 header with Mondo muffler
Bosch 010 distributors witb points
10.4:1 compression.......runs cool....head temps averaging bout 315......oil temps coming down as the new build loosens up.
Rancho transaxle with chromoly short axles and 3.88 ring and pinion. Gear set out of a 73 superbeetle.
Stage 1 kennedy pp. Solid disc without springs.
Horsepower? I'm guessing somewhere between 185 and 195......motor won't stop pulling.
Low end torque loss from the long duration cam? Nope. Motor "comes alive" at about 3 grand and will break your neck. Lots of power and lots of fun. _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
bilboa Samba Member
Posted: Wed Aug 23, 2017 10:58 pm Post subject: Re: Engine Builds / Combos |
coming on at 3 grand ??? That's Is not would I call bottom end. |
Posted: Wed Aug 23, 2017 11:31 pm Post subject: Re: Engine Builds / Combos |
bilboa wrote: |
It is if you drove it. It pulls harx from the start and really hits hard at around 3 grand. Hard wnough at the start to easily spin the tires without dumping the clutch. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Posted: Thu Aug 31, 2017 10:49 pm Post subject: |
vwsb74 wrote: |
fivelugshortaxle wrote: |
2276.....on the stand waiting on the car to be finished at the upholstery shop.
NOS Brazilian AS41 case from NSR(Nick Sisson Racing)
AA 94mm P&C's-iron rings
CB Performance 4340 forged 82mm crank
SLR XR310 cam-lobes deburred. With 1.25 rockers that measured out to 1.34 (.525 inch lift at the valve)
Udo Becker tool steel lifters
Chromoly pushrods
Dual Dellorto 45's
Mofoco 050 cylinder heads, hand ported by Roy, not as cast. Dual springs 42x37.5
Bugpack 1 5/8 merged header with single Mondo muffler
Glen Ring rebuilt Bosch 010 cast iron distributor
All of the cooling tin...Modified Doghouse shroud with venture ring, all powder coated black hammer finish(getting done now)
Doghouse oil cooler
Full flowed
Brad Penn 10-30 racing oil(the green stuff)
AN 8 fitting on the 1-2 valve cover and at the stock fuel pump location for the breather
Kennedy stage 1 PP with solid daiken disc
Swingaxle rebuilt by Rancho with 3.88 ring and pinion and super beetle gear set, super diff, steel shift forks, heavy duty side plates(Currently being built, should be done around the second week of July)
No numbers yet, just an example of a different combo.
Not a clue how much power but will have it on a dyno within the next month and a half or so. I'm sure it will be enough to give me a big grin when I step on the long, skinny pedal.
Image is prior to taking the tin to the powder coater. Test fitting and trimming....and the cylinder went in the trash...I opted for OE German cylinder tin....better fit...much better fit.
This combo can easily get 180plus hp . |
I'm guessing about 185....wideband tuning this coming week and then it'll be going on a chassis dyno. I'll post up the dyno slip as soon as I get it. _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
vwsb74 wrote: |
Chromoly pushrods
Dual Dellorto 45's
Doghouse oil cooler
Full flowed
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
The Dubbernaut Samba Member
Joined: June 01, 2011 Posts: 163 Location: Kennewick, Wa
Posted: Thu Sep 07, 2017 2:17 pm Post subject: Re: Engine Builds / Combos |
Im looking to make some engine stickers and need some help. Ive been looking through photos and threads here all day at work.... what, its slow right now and I didnt have anything else to do
Can anyone help link or point me in a direction of a beautiful type 4 engine I could use the jpg of, to make some stickers? Ive found a huge amount of type 1 engines but cant seem to find any "show quality" type 4's to use.
Sorry if this isnt the right place to ask! _________________ 2012 Tiguan 4motion
2 Corrado's
3 Beetle's
76 Bus
2 Baja's
66 Pigalle Squareback
80 Rabbit
80 Rabbit Pickup
and still collecting! |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Wed Nov 15, 2017 11:39 pm Post subject: Re: Engine Builds / Combos |
1914 cc buggy engine.
AS41 engine case, linebored.
CB 69 mm counterweighted crankshaft.
200 mm flywheel, lightened 1 kg.
Stage 1 pressure plate.
All baklanced.
Rebuilt stock rods lightened to 550 gr.
Engle VZ14 camshaft installed on 106 ILC.
Scat ultra light lifters.
26 mm CB filter pump. “O” ringed
CB 1,5 qrt oil sump.
AA 94 mm pistons & liners.
Fast Fabs pushrod tubes.
ACN aluminum Pushrods.
311 cylinder heads, Ported, chambers reshaped. 35,5 x 32 mm SS valves. 132 cfm @ 0,550” and 25” Oteva S90 sgl valve springs, Ti retainers. 9,5-1 CR.
Stock rockers, Porsche style adjusters on bolted axles.
009 distributor, locked w. CB Black box. Pertronix 3 ohm coil.
40 mm Dellorto carburetors on 45 mm shortened CSP manifolds.
Bugpack 1½” buggy header w. 2 cherry bomb mufflers. LOUD when you hit the right pedal
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Nov 22, 2017 3:52 pm Post subject: Re: Engine Builds / Combos |
Nice curves! That torque is so flat, I'm very envious. Great flow for 35.5mm intake! Very nice, bravo. |
guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Wed Dec 20, 2017 6:12 pm Post subject: Re: Engine Builds / Combos |
Valve cover venting / breathing??
I am building a 1915 engine for my 69 Doublecab. Do I need valve cover vent??
Previous engine for 15 yrs ( random use) was 1776 with no vents and seemed to be fine.
Thank you _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Thu Dec 28, 2017 12:42 pm Post subject: Re: Engine Builds / Combos |
Here is my 1679cc Turbo build with dyno videos.
Engine specs.
AE case uncut
8mm studs
Flow Flowed
External filter
External oil cooler
Stock German 69mm crank
AA 88mm P/C's .062" deck
1679 cc's
Stock German rods
Engle W-100 Cam w/ .420 lift at valves
Standard lifters
Solid rocker shafts 1.1:1 stock German rockers
HD Single Springs
Stock pushrods
Stock 35.5/32mm German Heads flycut to 52cc and 90.5/92
Stock German flywheel w/8 dowels
Kennedy Stage I Clutch
CB Super Disc
Transmission
1967 Swingaxle
1-4 gearing is stock
Stock diff 4.12:1
Welded 3rd & 4th gear hubs
Bearing caps at end shaved .038" for disc brake caliper mounts.
FI Specs
Megasquirt Ver. 3.0 with MS-2
B&G Relay Board
DubShop Relay Cable
Rev Limit
Launch/Flat shift control
Fan control
Dual Table Switching
Boost Control
Fuel injection
Crank fire ignition
Dubshop hidden Crankfire trigger wheel and VR sensor on Scat Aluminum pulley
Ford EDIS coil wasted spark
Ford F150 Plug wires
CB FI endcastings
CB fuel rails
Dubshop Rail holders
45# Bosch injectors (support 360 hp @ 100% DC)
Used 94 Turbo Volvo EFI fuel pump
Stock German Bug fuel pressure regulator
VW Golf EFI pressure side Fuel Filter
Napa Fuel Filter for pre-pump
5/16ths fuel feed line
Stock fuel line for return
Turbo specs
Homebuilt single TB intake
Stock 76-79 German Bug 45mm Throttle Body
Homebuilt cold side intake
Sedan exhaust header with 2 inch diameter extension to turbo
MHI TD04L-13T Subaru WRX Turbo
Audi V6 TT Intercooler
Homebuilt Water/Alcohol Injection system 3.0 gph using 2 nozzles.
Baseline run at stock wastegate of 6.0 lbs
112.13 whp 133.0 lbs. torque
Best pull at 20.5 lbs boost.
187.22 whp and 201.69 lbs. torque
Two baseline runs of 6.0 lbs on stock wastegate
Two 20.5 lb. runs with W/I.
20.5 lbs. was as high as it would go.
We couldn't get the dyno to load hard enough to hit my 22-24 lbs boost I usually run on the street.
Mario thought it would go over 200 whp at the higher boost.
That's for another day........... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Fri Dec 29, 2017 10:57 pm Post subject: Re: Engine Builds / Combos |
Amazing results Clone! Seriously well done mate. They are some great numbers. You're really showing us all what mild spec parts can do with the help of a little boost...well...quite a bit of boost really.
My guess would be that the hot side of the turbo is holding you back now. I've been told by people that know more than me that air cooled motors need a bigger than normal hot side. _________________ "...swingaxle...transaxle...same diff." |
Posted: Mon Jan 01, 2018 8:10 pm Post subject: Re: Engine Builds / Combos |
fastfil wrote: |
My guess would be that the hot side of the turbo is holding you back now. I've been told by people that know more than me that air cooled motors need a bigger than normal hot side. |
Thanks Fastfil..... _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Thu Apr 05, 2018 6:43 pm Post subject: Re: Engine Builds / Combos |
I figured out the reason I could only get 20.5 lbs boost on the dyno.
The whistle at idle on the dyno was not a bad bearing in the alternator but was a leaking intake boot on the right side.
I tightened the clamps a bit and I am now back to 22.1 lbs boost but the clutch is slipping when it hits full boost in third gear.
I will be picking up a Stage II pressure plate this weekend to fix that issue.😁😎 _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sun Apr 15, 2018 9:19 pm Post subject: Re: Engine Builds / Combos |
2165cc
New standard dual relief Brazillion case, full flowed, lifter bores sleeved, and Hoover lifter galley Mod, bored and decked for 94's, hand clearanced for 78mm crank, inside webs and case openings opened up and debured. 8mm OEM head studs
78mm USA made Bugpack crank
Stock size Berg Equalizer pulley
Berg lightened and 8 dowelled flywheel, Kennedy Stage 1 PP w/Daiken disc
5.4 CB rods ARP 2000 bolts, notched to cool pistons
94mm forged Mahle pistons with 5cc dish
Barrel bases cut down to reduce deck height and give pistons more support at bottom of stroke, .007 deck height
9.7 to 1 compression
WEB 86 B cam EP12 blank
CB light weight lifters, Hoover oil mods
ACN HD aluminum pushrods, Vallero sprinkler mods
DRD 1.4 Rockers w/CB adjuster screws, Hoover mod to shafts
Tims Stage 2 heads 42x37 Mexico 043 castings, dual springs, 50cc chambers, match ported Berg 580 IDF manifolds
.040 cooper head gaskets
Weber 44IDFs w/velocity stacks, 36mm vents, 55 idles, 150 mains, 200 airs, F11 tubes, CB air cleaners and Berg linkage
30mm Berg O-ring pump and pressure relief full flow cover
stock springs and plungers
1.5 quart Berg sump
ACN modified Bosch SVDA, Bosch wires, NKG plugs
A-1 1 5/8 Sidewinder w/ matching 1 5/8 heater boxes and Magna Flow muffler
All factory tins, thermostat and flaps
NOS Mahle, Gylco or Kolbenschmidt bearings
All balanced
148 HP 149 FT TQ at the wheels on pump gas, (4.12 R&P, .89 4th gear, 205 55 15 tire on test car)
[img][/img] _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Posted: Sat Apr 21, 2018 9:06 am Post subject: Re: Engine Builds / Combos |
Teeroy wrote: |
2165cc
1.5 quart Berg sump
All balanced
148 HP 149 FT TQ at the wheels on pump gas, (4.12 R&P, .89 4th gear, 205 55 15 tire on test car) |
You have a dyno sheet pic you can add to your combo?????.....it would be nice to be able to reference the torque and hp curves for each build combo. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Teeroy Samba Member
Posted: Sat Apr 21, 2018 4:27 pm Post subject: Re: Engine Builds / Combos |
Added a copy of the best pull by itself, the other copy is too hard to read with several of the pulls on it. He said we lost tach signal on this one just before 6000 rpm _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
www.autosportsnorthwest.org |
