rudygetz Guaperia Ful Tine
Posted: Sat Oct 16, 2010 1:20 pm Post subject: Rear Passenger Side Squeak!!! |
I have this insanely annoying squeak on my passenger side rear. I jacked up the car and turned the tire, no squeak.
it only happens when I drive the car...any ideas? _________________ 1965 Standard Sunroof Bus build
1967 Beetle |
Daddybus Samba Member
Posted: Sat Oct 16, 2010 1:24 pm Post subject: |
torsion bar rubber bushing. Grease them. |
oarse Samba Member
Joined: August 21, 2009 Posts: 530 Location: Washington DC
Posted: Sat Oct 16, 2010 6:34 pm Post subject: |
Are you sure it's suspension related?
Could it be that the distributor needs to be lubed? This causes an unbearable squeak until the cam follower fails. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Sat Oct 16, 2010 7:23 pm Post subject: |
Daddybus wrote: |
You should use graphite on those, not grease. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sat Oct 16, 2010 9:44 pm Post subject: |
Could it be the shock absorber? _________________ Don't worry; be happy. (Baba) |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Sun Oct 17, 2010 4:58 am Post subject: |
Worn out axle bearings. _________________ Some people are so busy being clever they don't have time enough to be wise. |
don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2830 Location: West Palm Beach, FL
pyrOman Fire Master
Posted: Tue Nov 02, 2010 9:21 am Post subject: |
Is that a suicidal rat or is it just riding shotgun? _________________ Some people are so busy being clever they don't have time enough to be wise. |
clubtreb Samba Member
Joined: June 18, 2007 Posts: 554 Location: miami beach
Posted: Tue Nov 02, 2010 12:55 pm Post subject: |
so what was it. I just had the samething. thought it was a bearing. but the fluid ran low in the rgb |
Posted: Tue Nov 02, 2010 1:01 pm Post subject: |
clubtreb wrote: |
scratch that, the squeak may be internal within the transmission.
Apparently the wheel was loose, even though it had been tightend not so long ago. I tightened the axel nut and the squeak went away but there's still a problem on why the wheel came loose. The axel nut had the cotter pin in so it couldn't have come loose. _________________ 1965 Standard Sunroof Bus build
1967 Beetle |
Posted: Tue Nov 02, 2010 1:36 pm Post subject: |
I had had a bad hum when I got the bus. then changed the gear oil. hum went away. then got a sqweek a few years later. took apart and saw nothing wrong. put new gear oil in, thinking what the hell. drive away and never heard sqweek again. good luck |
pyrOman Fire Master
Posted: Tue Nov 02, 2010 2:27 pm Post subject: |
rudygetz wrote: |
clubtreb wrote: |
Apparently the wheel was loose, even though it had been tightend not so long ago. I tightened the axel nut and the squeak went away but there's still a problem on why the wheel came loose. The axel nut had the cotter pin in so it couldn't have come loose. |
How do you know it was torqued enough? Did you use a torque wrench? _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Nov 02, 2010 2:32 pm Post subject: |
pyrOman wrote: |
rudygetz wrote: |
clubtreb wrote: |
How do you know it was torqued enough? Did you use a torque wrench? |
Used a breaker bar and tightened the hell out of it... _________________ 1965 Standard Sunroof Bus build
1967 Beetle |
oarse Samba Member
Posted: Tue Nov 02, 2010 7:51 pm Post subject: |
rudygetz wrote: |
pyrOman wrote: |
rudygetz wrote: |
clubtreb wrote: |
Used a breaker bar and tightened the hell out of it... |
Whatever works... I never trust my own judgement as to the torque of the rear axle nut, because brake drums are too expensive. I use my 3ft. torque wrench to get it to 250, then use the breaker bar to get the cotter pin to line up. Make sure you tighten the nut further to line up the cotter pin, rather than backing it off, or you might encounter the same issue (or worse, you might strip out your brake drum.) |
pyrOman Fire Master
Posted: Wed Nov 03, 2010 6:38 am Post subject: |
oarse wrote: |
rudygetz wrote: |
pyrOman wrote: |
rudygetz wrote: |
clubtreb wrote: |
While "tight" is good, too tight may strip the threads. Though it's best to use a "calibrated" torque wrench, if one is not available the formula for torque is quite simple: Weight X Length = Torque. So if you weigh 250 pounds and stand on a 1 foot long breaker bar, it will apply 250Lb-Ft of torque. If you are a lightweight like me, then figure out how long a bar is needed. So if you only weigh 125 pounds, then a 2 foot long bar will torque it @ 250Lb-Ft. _________________ Some people are so busy being clever they don't have time enough to be wise. |
