tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Tue Jul 15, 2014 8:22 am Post subject: |
Added a GPS enabled Stereo while leaving the stock 6v AM radio that works in the dash. The door closes and the dash looks stock.
_________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
nautha Samba Member
Posted: Tue Feb 17, 2015 1:29 pm Post subject: |
Fully CNC alluminum billet custom made 3 Bars.
Made in Italy.
Hand polished or chromed.
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Feb 17, 2015 1:56 pm Post subject: |
Hope I can throw this in. Its for my dual carbs. The round shaft was boring looking plus the cable connection was too close to the left carb for my setup, so I used 2 auger bits and cut the to allow my cable to pull straight. I cut off the square ends of the bits and fit them into the original ends.
Polished them and sent the out for chrome.
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Tue Feb 17, 2015 2:00 pm Post subject: |
Not sure this is in keeping with the thread theme; isn't this just an advertisement? Very nice nonetheless.
nautha wrote: |
Made in Italy.
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Tue Feb 17, 2015 2:14 pm Post subject: My snubber has brass balls |
The snubber holder rotted off long ago, I took a nut and bolt and built up brass using a acetylene tourch.
Jimmy_JDM Samba Member
Posted: Tue Feb 17, 2015 9:03 pm Post subject: |
DIY Teak cupholder mounted on the ashtray.
nautha Samba Member
Posted: Wed Feb 18, 2015 12:47 pm Post subject: |
Dangermouse wrote: |
nautha wrote: |
Made in Italy.
Actually not, 'cause i really made them at home. |
vamram Samba Member
Posted: Wed Feb 18, 2015 1:06 pm Post subject: |
Where does the 3 bar part go? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
nautha Samba Member
Posted: Wed Feb 18, 2015 2:09 pm Post subject: |
vamram wrote: |
Where does the 3 bar part go? |
Instead the original beetle horn holes.
It is my own interpretation of the stamped Koch grills, but these are solid, not stamped metal.. |
oe_tuner Samba Member
Joined: January 01, 2008 Posts: 55 Location: Central Ohio
Posted: Wed Feb 18, 2015 6:12 pm Post subject: |
Made my own fuse box opening cover for use with my EZ wiring harness/fuse block.
Not bad for my first go at using my new Eastwood bead roller.
DHMaher Samba Member
Joined: November 16, 2009 Posts: 787 Location: Portland, Oregon
Posted: Sat Sep 19, 2015 1:13 am Post subject: |
How about another bump? _________________ Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green
See my ads |
kai.scott98 Samba Member
Joined: August 29, 2015 Posts: 514 Location: lincolnshire
Posted: Sun Sep 20, 2015 10:25 am Post subject: |
Haha, wow here all you guys making awsome things, and i cut and mounted some wood in the back where the seats would have been:
grandpa pete Samba Member
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Oct 27, 2015 7:07 am Post subject: |
grandpa pete wrote: |
Reverse light bracket
bend , drill , paint
That's a good idea. Mounting to an existing bolt. I was thinking of mounting one of these with a toggle switch and wondered how to mount it. cool. |
Posted: Tue Oct 27, 2015 7:14 am Post subject: |
Made some parts to mount a supercharger on my 1385. Also changed some parts ( the 009 doesn't go to full advance ). Nothing fancy. didn't even grind the tack welds. More concerned with making it work.
The rag was there because the carb was leaking fuel after I shut down. I finally figured there was still suction there after shut down. So now when I turn off I give it a good blip !
2T2-Crash Samba Member
Posted: Tue Oct 27, 2015 10:38 am Post subject: |
homemade apple burl shift knob and dash plates:
Anduril Samba Member
Posted: Tue Oct 27, 2015 11:11 am Post subject: |
From the first page... This is cool. With the bamboo tray down there it will make it so much easier to get to the lever quickly. It goes on the to do list.
zabo wrote: |
fuel tap extension - $6
bluebus86 Banned
Posted: Tue Oct 27, 2015 4:26 pm Post subject: |
I made my own outer window scraper out of some garage door seal some 35 years ago and installed on my old but still nice aluminum trim pieces, still looks good and seals the water out, much longer lasting than the stock rubber which had rotted away. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Tue Oct 27, 2015 7:29 pm Post subject: |
2T2-Crash wrote: |
Nice Craftsmanship!
Take it a step further...
...create a proportionally matching feature for the bare, left side of the speedo that both blends in and fully compliments the right as if the Factory themselves did it _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
pezthing Samba Member
Joined: December 21, 2015 Posts: 37 Location: California
Posted: Wed Dec 23, 2015 9:35 am Post subject: Re: Home made parts on your Bug? |
I read this on some VW site "You know you're a redneck if you shop at Home Depot for VW parts". Made me laugh because I run to Home Depot, Lowe's and Walmart often to pick up something for my Bug. |
